Question about KitchenAid KSSC48QMS Side by Side Refrigerator
Need new main control board for kitchen aid fridge model kssc48qms01
Need to order a new control board part # 2303934
  • 142 Answers
SOURCE: Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Posted on Oct 01, 2008
  • 113 Answers
SOURCE: I have a kitchen aid side by side refrigerator.
try part # ap3182816 it is a whirlpool part #
Posted on Apr 29, 2009
SOURCE: Kitchen aid refigerator: door won't seal then lost power.
The GFI had becme stuck - yes we had plugged the fridge into the GFI which is apparently a bad thing to do. Replaced the GFI (and moved in away from the fridge) and all is well.
Posted on Jun 03, 2009
SOURCE: ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Posted on Jun 27, 2009
mgprice
  • 744 Answers
SOURCE: Problem with Kitchen Aid side by Side
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 11, 2009
I have a kitchen aid KSC24C8EYY the problem is that the refrigerator does not cool stay cool below 40 degrees, Holding 43-45 range. The freezer maintains freezing but not to the 2 degree setting.
well, how full is your fridge. if your fridge is blocking any of the return air vents, thats usually where the problem lies with side by sides. you need good air flow in these models for proper temps in the fresh food compartment
Dec 18, 2016 | Refrigerators
Refrigerator kitchen aid model KSCS231NSS00
You need a new main control board- the capacitors go bad on these whirlpool built controls quite often, they have replaced it with a three part kit, but I would send the board you have to a refurbisher like Corecentric Solutions or Fix-your-board... They offer a warranty with the repair also. Main Control Board WPW10219463
Jul 05, 2016 | KitchenAid Refrigerators
Refrigeratory cycles on and off & beeps
You will need a main control board W10219462 either rebuilt or replaced. Now there are companies who rebuilt these but not approved by Kitchen Aid to do so. As a certified repairman I would advise you to call Kitchen Aid to see if your unit have a board replacement yet. As of December 2015 your model hasn't made the list yet. I would call them and check, what will happen is your unit will start being erratic with temps and had to control for food. I wish I had better news for you, good luck.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Feb 13, 2016 | KitchenAid KBFC42FSS Stainless Steel
Kitchenaid KSCS251 from 2004 suddenly stopped cooling/freezing all interior lights work.
If the previous posts do not solve the problem, these fridges frequently have failures in the control board. The control board is no-longer-available from Kitchenaid however is can be rebuilt at www.fixyourboard.com. The rebuild comes with a 2 year warranty. The turn around time is a few days. The control board may be one of (depending on your full model number): 2252159, 2215946, 2221501, 2221522, 2252071, 2252095, 2252097, 2254739, 1548001, 2223443, 2252111, 2303934, 2307005, 2307028, 8201521, 2304135, W10121049, W10219462, W10219463, W10185291
Aug 07, 2015 | KitchenAid Refrigerators
Is this a Kitchen Aid? Is it possible to buy this circuit board from somewhere?
This is a kitchen aid. BUT!!!! it is an international model that was sold in countries with 220 volts. Look underneath the mixer for a white tag it should have a model number and a serial number, if you can get us those numbers then we can help with the parts. Hope this helps.
Nov 05, 2014 | Food Mixers
No i am not, need info on Amana refridgerator
(Without a specific model responses are generic.)
Controls should come ready to install (coding is pre-installed).
Oct 22, 2014 | Amana Refrigerators
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
Whirlpool GC5SHGXK Fridge Compressor will not run - part 2252159
You cannot find this part since it is no longer available from Manufacturer. Now you can get your board repaired instead.http://www.partsimple.com/2307028-wpl-r-12.html
Also, I was able to find the link for the part number mentioned 2252159.
This 2252159 control board is available for replacement purchase as well as repair.
I have mentioned both links for reference:
http://www.partsimple.com/2252159-wpl-r-12.html
http://www.partsimple.com/2252159r-wpl-r-12.html
Whirlpool Kenmore Refrigerator Control Board Repair service 2307028
Oct 05, 2012 | Refrigerators
KitchenAid KSSC48QMS Side by Side Refrigerator Logo
207 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
