Question about Health & Beauty
Conair FB23R bubbles not working
I hear what sounds like the motor but no bubbles come up....
My bubble box areator wont make bubbles
If you can hear the motor operating the problem could be the rubber diaphragm in the pump. Check it to make sure it isn't damaged or torn, especially where it mounts to the arm. If so, you can purchase replacements. Trying to repair it most likely won't work as an adhesive could introduce toxic fumes into the air and into, into your bait.
Jun 15, 2014 | Bubble Box Compact Bait Aerator
I was given a CONAIR model SU5T SOUND THERAPY TRAVEL SYSTEM, but without an operating manual. I am hearing impaired & can not find a travel alarm clock loud enough to wake me up. I wish to try this...
There are at least three different Sound Therapy systems and two of them have manuals available on-line:
SU1W:
http://www.conair.com/instruction_booklets/07PS078_su1w_IB.mech.pdf
SU7:
http://www.conair.com/instruction_booklets/07ps111_su7_ib.pdf
Aug 03, 2011 | Cameras
Need an operator/how to manual for the Conair Body Benefits Bubbling Foot Spa
If you know the model number you can type it in on the website just to the right for the user manual:
http://www.conair.com/cnt_ib.php?action=filter&type=category
But this one seems closely related to what you have so it might work just as well as guide:
http://www.conair.com/cnt_ib.php?action=download&id=980
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Health & Beauty
How do you turn the alarms off and on for the Conair model SU7?
Link to set up for SU7 alarm sound therapy clock: http://www.conair.com/instruction_booklets/07ps111_su7_ib.pdf
Nov 07, 2010 | Conair SU7 Sound Therapy and Relaxation...
Dear sir when ever i drive long distances and shuts down the engine i can hear the radiator bubbling.
Thats not necessarily a problem. I'm assuming your not overheating while driving. The bubbling sound you hear is most likely thr sound of coolant bubbling into or outoff the overflow tank. If you losing coolant, however, you may have a leak. Next time you park and turen the engine off cxheck underthe car and see if any coolant is leaking.
Dec 21, 2009 | 2000 Honda Civic
My mothers beko fridge freezer making bubbling sound
Sounds like the evaporator fan is doing its job. Nothing to worry about. Good hearing is a blessing all fridges make different sounds some click loud while others gurgle loud. Some pop and snap. Till I got my hearing aids I didn't know mine ran so loud and clicked.
Dec 15, 2009 | Refrigerators
What do I put in conair ultrasound jewely cleaner. I do not have any instructions in box.
To begin the cleaning process, the cleaning tank is filled with warm water or a cleaning solution Cleaning solutions can consist of non-ionic surfactants, detergents or ammonia. Note that cleaning agents with bleach and acids should be avoided.
Place jewelry items in the basket or directly into the cleaning tank.
Turn the machine on. Once on, the machine's motor produces ultrasonic energy which is transmitted with vibrating energy waves. On average, ultrasonic jewelry cleaners emit at least 40,000 sound waves per second.
The vibrating motion of the ultrasonic waves creates microscopic bubbles in the water or cleaning solution. millions of tiny bubbles knock into one another and into the items resting in the cleaning tank. The motion is very effective at penetrating the tiny crevices in jewelry that traditional cleaning cloths and topical cleaners cannot easily reach.
After a few moments, the cleaning process is complete. Once the motor is turned off, the dirt and debris from the jewelry will settle and collect at the bottom of the cleaning tank. Remove the basket or jewelry from the cleaning tank and rinse with clean fresh water. You can complete the process by drying the jewelry with a soft cloth.
Oct 23, 2009 | Kitchen Appliances - Others
Kia Sedona - Bubbling Sound
SOUNDS LIKE YOUR HEARING WATER FLOWING THROUGH YOUR HEATER CORE TRY RUNNING THE CAR WITH THE RAD CAP OFF UNTIL THE COOLING FAN KICKS IN THEN SHUT IT DOWN AND TOP UP THE RADIATOR AND RESIVOIR.
Oct 16, 2009 | 2002 Kia Sedona
Every now and then when I turn off the car I hear water surging from the motor for about a couple of minutes and the temp gage reads normal? 3.0 Liter V6
sounds like u hav an air bubble in radiator from cold take radiator top off then rev engine to see if it bubbles if it does do this till it stops bubbling then top up wen it cools down then put radiator cap on then check heater gets hot wen warm then this is solved
Aug 24, 2009 | 2005 Lincoln LS
No whirlpool jets
It sounds like the motor needs to be lubricated or there is debris keeping the impeller from turning without the help of a littl force. I would have a professional that deals with whirlpool tubs come and lube the motor.
Mar 20, 2009 | Home
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
