Question about Aiwa NSX-D9 Shelf System
AIWA NSX-V90 CD NOT PLAYING
LASER HAS BEEN RENEWED
  • 298 Answers
SOURCE: Aiwa NSX-KT9
Try replacing the Carousel belt.
Posted on Feb 29, 2008
SOURCE: AIWA CD Problems
Sounds like the lasers need a POT (potentiometer) adjustment. Tools you will need are a multimeter with Ohms (preferably digital) either a #1 or #00 and #2 philips screwdriver. You will need access to the bottom of the laser. On the units I've worked on the POT faces the back of the unit. It will look like a philips head screw in a square metal casing. You should not need to completely remove the CD tray assembly but you can if you wish though I recommend removing the tray bezel Look for two legs on the side of the POT casing that go to the laser PCB. Measure the resistance across the two legs for an initial reading. On mine it was exactly 1kOhm. Now take the #1 or #00 philip screwdriver and adjust the screw to lower the resistance. POT screws are typically EXTREMELY sensitive so 1/16 of a turn can make a big difference. Start by lowering it by about 20-25%. So if the initial reading was 1kOhm aim for 750-800Ohms and test. You should use several disks for testing. If your unit is capable of CD-R/RW playback then have those available as they are generally more difficult to read. If you have playback gradually increase the resistance 5-10% until the disk is no longer readable or struggles to read. Now lower the resistance again 5-10% and retest. If all works well reassemble and enjoy. It is necessary NOT to lower the resistance too much as it will shorten the life of the laser and if too low could damage the disks. If you must go lower than 25-30% the laser is not worth salvaging. Typically 10-15% is all that is required. If you need more detail I recommend doing a search for 'xbox POT adjustment' as the procedure is essentially the same for all lasers and some xbox sites have good pictures so you can see what your doing before you dive in. Total repair time per unit will be 1/2 - 1hr, mostly spent in all the testing. Hope this helps. Good luck
Posted on Jan 29, 2009
Suraido
  • 195 Answers
SOURCE: The CD player won't recognize CD's.
Most of those CDs they sell are just a gimmick, nothing can replace a good hand cleaning with a cue-tip done by taking the whole thing apart. Take it to the local technician to get it cleaned properly first and foremost, or do it yourself if you feel safe enough taking all this apart and cleaning a tiny fragile little lens with a cue-tip and windex yourself. If a good hand cleaning like that does not work, then it means the reader head itself is defective and need to be replaced. If this is the case, don't bother. A cheap head will go for around 200$ usually and sometimes more, and at the price you get a new complete system it will be better buying a whole new sound system.
Posted on Jul 07, 2009
  • 7 Answers
SOURCE: aiwa nsx-999 display and cd changer problems
replace lazer ever 2000 hours the display may have a dry joint on the 18 volt input ps the lazers are all the same in all the nsx moduls
Posted on Mar 23, 2010
dunnbiker
  • 8546 Answers
SOURCE: It is possible to connect a "AIWA NSX V70" as a
Use VIDEO/AUX instead. MIC is for the smaller input signal that a microphone would typically produce.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-NSX-V70-manual/id/1076ci461/t/2/
Use your PC soundcard controls to adjust the output to something useable (max?).
Posted on Apr 30, 2011
After following instructions on how to renew by entering product key ..to complete what then? how do I know it is renewed???
If it is renewed, u will see a message which says "Renewed successfully". You can also reconfirm by checking the subscription period.
Feb 27, 2015 | Symantec Norton Internet Security 2008:...
Renewed norton 360 but not on computer
You renewed your norton 360, are you asking to renew through another PC? if so you can simply go to the norton website
https://www.mynortonaccount.com/amsweb/default.do
and sign in to renew your account license key
when logged in you should be able to....
  • Get the latest product updates
  • Protect additional computers
  • View your Norton Product Keys
  • Access online features and services
Jul 17, 2013 | Computers & Internet
My printer all time replace toner displayed but i am refill my catridge please answer for me
dit you refilled the cardridge or renewed it? If you refilled it it needs new chips on to the cardrige you can supply them via samsung or from a refill stor.
Apr 18, 2011 | Samsung SCX-4300 Monochrome Laser...
I need to uninstall my nortons and then reinstall it. i renewed my subscription. is the original product key the same as the renewe. if not how to i find the renewed product key
Norton used to be very hard to uninstall. When I used it I went to the Symantec website for the uninstall information. Not sure about the renewed product key, sometimes under the "help" and then "about" there is info.
Nov 19, 2009 | Symantec Norton 360 Version 2.0 for PC
Aiwa NSX-D9 Shelf System Logo
98 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
