Question about Noritz Residential Heaters Tankless Water Heater N-0751M-DV-LP
My Noritz N-0751 M-DV makes a loud vibrating noise when I first turn on the hot water. I was advised to flush the system and did but the noise is still there
  • snap101
    snap101 Feb 13, 2014
    try cleaning the fan, if its not that you need to adjust the gas manifold pressure
    New Friend:
  • 51 Answers
This sounds like "water hammer"
You can fix this by adding an arrester to the water line. here is a link to what they look like and how they work http://www.plumbingsupply.com/waterhammerarresters.html
You may want to check you water pressure and see if its over 80 psi.
If so then your regulator needs to be adjusted or replaced. If you home does not have a regulator and the city has upped the pressure then you will need to install one. water hammer will break pipes over time and can damage that nice water heater you have.
Posted on Jan 12, 2013
tborn6
  • 700 Answers
SOURCE: Noritz not staying hot
How many faucets do you have on when this happens? Turn on more than 1 and if it still does the samt thing than I would check to see if the inlet water screen has debris in it. Valve off the unit and look at the inlet water side and theres a screeen that you should be able to remove and clean undeneith some running water and then replace. Good Luck
Posted on Jan 07, 2009
SOURCE: Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Posted on May 12, 2009
heatman101
  • 43501 Answers
SOURCE: have hot water for a
The problem may be the flame sensor or the control.....
Check that the flame sensor is clean and also that there is a good ground from the burner to the control....make sure that the wiring to the unit is correct polarity, and then the ground is hooked properly also...
Is it flashing a code and if so, check what the code means....
heatman101
Posted on Dec 21, 2010
  • 17 Answers
SOURCE: I have a Noritz model#
hi there
if the unit is a few years old it or if you have hard water it may be the heat exchanger or the domstic hot water sensor.
hope this helps
Posted on Dec 22, 2010
heatman101
  • 43501 Answers
SOURCE: Noritz tankless gas water heater.
The unit is plugged up with mineral buildup from the water going through it... it will need to be cleaned internally....this is done by running an acid solution through it to clean out the mineral buildup...
Then it will work again...
heatman101
Posted on Feb 03, 2011
N-069m pulsating when hot water is turned off.
Do you have a well our on city water? Check in coming water pressure make sure it is not over 60psi
Sep 14, 2014 | Noritz 6.9 Gallon Residential Tankless...
Very loud foghorn sound
Loud rumbling noises are often caused by either water boiling in the burner or by entrapped air in the system. To help prevent water boiling make sure that the boiler system has a pressure between 15 - 30 psi. Also check for sufficient water flow and remove any sediment from the in-line filter. To remove entrapped air, install an automatic or manual air vent at the highest point in the heating system and also make sure you have a properly working micro-air vent installed. With the unit turned off and cooled down, you can also try flipping the lever on the pressure relief valve to try and flush out any air in the heat exchanger . Hope this helps.
Sep 06, 2014 | Noritz Water Heaters
Lound vibration when running
Check gas control valve.
Good luck,
Marty
Feb 18, 2013 | Rinnai Water Heaters
Noritz NR98-DVC tankless water heater won't give hot water thru a single valve fixture. Gives us all the hot water we want on a double handled fixture. Any suggestions on what to do?
Replace single-handled faucet cartridge, and see if hot flows to that faucet again.
http://waterheatertimer.org/Crossover.html
Exposing tankless to hard water causes reduced efficiency within a few months, and can cause Total failure of parts within two years.
Do not expose tankless to more than 11 grains hard water.
Here is research pdf conducted by water softener industry comparing tankless andf tank-type:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
To solve problem long-long term, install tank-type gas water heater from local box store for $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 12, 2012 | Noritz NR98-DVC-NG 100W Freeze Tankless...
I have a Noritz model# N/084m/DV Serial# 200412-000328 and the water does not stay consistently hot it fluctuates in temperature very annoying please advise
hi there
hope this helps
Dec 22, 2010 | Noritz Water Heaters
Loud Vibration/Noise when System Starts
This happen when there is air in the gas line...if the problem is still there after a couple of days you will have to return the unit for an exchange the gas control is giving problem...contact rheem first before making a exchange decision..they will walk you some step first to ensure there is not a problem
Jul 03, 2010 | Rheem Direct Vent Natural Gas Tankless...
Noritz Tankless error code 16
The trick with these hot water heaters is to keep the filter screen clean and flush the system with CLR periodically. Code 11 is ignition error. Is your gas valve turned on?
Oct 17, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
When hot water is turned on the pipes make this vibrating sound.
A rumbling more than a vibration? If one in the same, the heating elements may have calcium build up which causes perculation like the perculator coffee pot which causes the heater to vibrate or rumble. If the elements can be removed they can be cleaned by soaking in lime away or a descaling solution. All said and done it will work like new.
May 03, 2009 | Water Heaters
Jan 04, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Noritz Residential Heaters Tankless Water Heater N-0751M-DV-LP Logo
1,855 people viewed this question
Top Noritz Water Heaters Experts
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
