Question about Dell E173FP 17" LCD Monitor
I just bought a dell flat planel monitor its coonnected fine but unable to see any vedio on the screen
  • 55 Answers
I'm assuming the monitor switches on, ie the the orange light comes on when plugged in or turns green once the pc is booting up? If not check the plug fuse or cable connecting monitor to pc. If all is ok can you see the bios screen as the pc boots up, you should at least be able to see that as this doesn't require any drivers. If not, try the monitor on another computer, if it works on another pc then its something to do with your graphics card. Hope this helps.
Posted on Jan 24, 2009
I just bought a flat screen monitor 15 inches and have a acer tower. I have a dell monitor now but want a flat screen will they work together
it should work just fine ..... if not identify the connector DVI- VGA- Etc.but in most cases monitors and towers are pretty compatible
Aug 26, 2012 | HP Vs17 17" LCD Flat Panel Monitor
Mointor dell flat screen
flashing amber normally just means it has gone into standby because it's not getting a valid signal, when you bought the other monitor did you use a different vga/dvi cable when you plugged it in? are both inputs the same? for more information on the padlock please read this page http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Apr 29, 2012 | Computers & Internet
When i turn it on it says ' cannot display this video mode '
try to play the vedio on diffrent players or try to download the different code of the player that you used
try downloading media player classic or km player
Oct 22, 2010 | Dell UltraSharp 1504FP 15" Flat Panel LCD...
I have a black screen with a slow blinking green power button. I checked the connections they are good. I have another monitor that works fine with the same computer, and cable.
Please check your screen resolution the best resolution is 1024 x 768 on xp or if ur vedio card supports set it on 1260 x 768 for the display setting.
Mar 30, 2010 | Dell E173FPb 17" TFT LCD Monitor
My dell P2210t will only light up the top half of
it may be better to bring your LCD to where you bought to claim the warranty. don't try to open the LCD and try to fix it because you will lose the warranty.
Oct 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Giving green light and there is no display
disconnect the video cable that coonnects the motherboard and monitor...now switch on the monitor ..now a screen saver like video will come on monitor that says to connect the cable this means your motherboard has a prblem call the service center.. if not and still the monitor is on green light it means your display driver in your monitor would have got fried and your motherboard has no problem...
Apr 28, 2009 | Dell OptiPlex GX270 PC Desktop
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Blank screen
Disconnect the monitor , from the computer, switch the monitor on , if you have some kind of Dell self test box running on the screen. The monitor is OK . The problem can be with the video card or resolution settings.
Also, try connectin the old monitor you had hooked up with the system to check ,if you see anything
Thanks
proton
Mar 14, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Dell monitor
Who manufactured it? Better call them to check if the monitor's still under warranty. Im thinking it has to be replaced and may eventually fail completely.
Oct 03, 2008 | Dell Computers & Internet
Dell 1703 FPi 17" TFT LCD Flat Panel
you have snap frame around the screen itself use flat screw driver fine edge, theres about four locations that snap into slots work them away and remove frame, then remove screws on back will seperate ,you will have to remove monitor button panel board to, once inside, four screws around screen itself once in side,this will lead you to power connection inside main screen frame, the board and the connections
Sep 06, 2007 | Dell 1703FPt 17" TFT LCD Flat Panel...
Dell E173FP 17" LCD Monitor Logo
Alun Cox
