Question about Harman Kardon Audio Players & Recorders
Avr 1700 factory reset harmon kardon - Harman Kardon Audio Players & Recorders
SOURCE: Harmon Kardon AVR 630
I ever had this problem, so I contact the service center and they re-program all setting. So,would you like to ask the nearest service center.
Posted on Oct 10, 2007
SOURCE: harmon kardon avr 25 II
hey i also had this problem, i don't know the name of these but they are basically plugs that you have to block output from the front rear and center speakers of the white/red cables... sry for bad description but its on the left side when looking at the back of the receiver, while all of the other speaker wires should be hooked up to the right with the twisting knobs... it took me forever to find this out but yeah it was a simple fix
Posted on Oct 30, 2007
SOURCE: Harman Kardon AVR 7000 loosing memory
This is what's in the AVR7000 service manual:
Subject: Backup Memory on AVR/DPR/HK series receivers.
In the event of the complaint: “the receiver is losing its memory (any programmed system settings)
when the unit is turned off, or after the unit is unplugged (briefly*)”:
Check and replace:
Model: AVR7000
Designator: C730
Description: 0.047 Farad 5.5v capacitor
Part number: # P10790-ND or # J3432147324X
I'm having the same problem and this is how far i got so far. I don't kwow how to get and replace this part.
Posted on Nov 16, 2008
SOURCE: was using the harmon kardon avr 225 receiver and the front panel went out. .... screen display of the channel number, volume, or menu item does not work. ...
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
Posted on Mar 21, 2009
SOURCE: My Harman Kardon AVR 330 is locked. Can't unlock
youtube
myspace
facebook
Posted on Feb 12, 2010
Why does update say the usb folder is empty?
formatting wipes everything off the device usually, you may have deleted what was on there, hope this helps.
Jun 23, 2014 | Harmon Kardon Harman Kardon - Avr 1700...
My Cox HD/DVR controller will turn off but will not turn on my new HKAVR1700 using the AUX button on the Cox supplied URC-8820-Cisco remote.
This is a documented problem with the Harmon/Kardon AVR-1700 and the Cox remote. Here's how I solved it. On the HK1700, go to System Settings and turn on HDMI Link. This will allow your TV (if it has the feature) to put the HK in standby mode when you power down the TV. Go to your setting on your TV and turn on HDMI link, or equivalent. I have a Sony TV and the setting is called "Control For HDMI." Then, use code 0110 for your Cox remote. This code will only turn on the HK, not turn it off. BUT, the HDMI Link should put the HK into standby.
Jan 06, 2013 | Harman Kardon Harman/Kardon AVR 1700
Avr-1700 airplay
I have the same problem. Please let me know if you were able to find a solution. Carzev@yahoo.com
Dec 21, 2012 | Harmon Kardon Harman Kardon - Avr 1700...
My Harmon Kardon AVR 500 sound doesn't work, I disconnected speakers, re connected & reset protection. Nos ound not even on test mode
Hi it is seem there is no output from your device. Please check the circuit components and wires for malfunction in your Kardon then. Regards
Feb 09, 2011 | Harman Kardon AVR 500 Receiver
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
1,006 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
