Question about RIM BlackBerry Curve 8310 Smartphone
Static during calls
Is anyone else having trouble with calls?  the majority of my calls have an annoying static in the background.
  • 6 more comments
  • daisy 86 Jan 23, 2009
    1. The phone will have static during calls then turn itself off. I have to remove the battery to turn the phone back on. Sometimes it will show a low battery even if the phone is fully charged.
  • khiachannell Feb 03, 2009
    My Blackberry Curve has static during calls also. AT&T sent me a new phone and I got a new sim card, but that doesn't seem to fix the problem. It's so annoying. Help :(
  • LadiiJ08 Feb 11, 2009
    What is a font screen sticker protection?
  • cre8ov Mar 05, 2009
    Static starts after a couple minutes on a call. I will see if it stops when the phone is plugged in.
  • Anonymous Mar 20, 2009
    It might be from when I dropped it. but ive noticed that if I have my hands covering the top part near the camera the sound is a bit stornger. its very annoying and it makes me feel like im radioactive :P
    also I have the 8300
  • kmsulcer35 Mar 20, 2009
    I have been having the same problem. I have a lot of static and the battery goes down fast. It will also just cut off while I am talking, then I have to take the battery out and put it back in. I contacted AT&T, they sent me a replacement phone. I put the battery in that one and the phone began to have static too. I called AT&T again and asked them could it be the battery causing the phone to have static and he said no. After reading the other comments and answers to this problem. I believe the battery is causing the static. I will replace the battery and see if this works.
  • Anonymous Apr 08, 2009
    I had the same problem also
  • Anonymous Apr 26, 2009
    static during calls, then the phone shuts off, seemingly randomly. plugging it into a charger or pulling the battery is the only way to make it reset.
  • 3 Answers
My 8320 had the same problem as daisy's. In addition to that..my camera's colors were wacked. Like negative images or something...Anyways..I noticed when my phone was plugged in, the problems disappeared. So i purchased a new (non-OEM..paid like 15$) battery online and the problems disappeared. Has been fine for about two months since doing this.
Posted on Feb 11, 2009
It could be that you still have the font screen sticker protection on?
take that off if you do and it should work fine, i had the same problem with a different phone.
Posted on Feb 08, 2009
Cursor Problem
Background running programs must be the reason for that you must use some start up manager or background application manager to avoid your PC from annoying issues, The one well known and reliable program is Reginout.
Oct 29, 2013 | Computers & Internet
On incoming calls rings once then stops then person calls again comes thru. also after talking sometime u can hear the system dialing? there are 7 phones in the house one has the FWD light on? could...
The first symptom of an incoming call ringing once then stopping is called trip and ring which is caused by a partial short on the phone line. The second symptom is called crosstalk caused by the two phone lines being shorted to each other. The service provider is most often the cause of these troubles. Often this type of trouble happens during wet weather or shortly after. The third symptom of static on the line cna also be caused by the same conditions. All three symptoms are likely caused by the same trouble from the service provider. Advise you report the trouble to your service provider.
Dec 09, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
User hears faint static while on a call. It's not load enough to make it hard to hear the caller, but a noticable crackling/static noise can be heard in the background. happens on every call.
Cell phones transmit the sound as digital data. The data when converted back to analog to listen too CAN have "digitizing noise" which will sound like static.
WORSENING the problem is if there is noise in the background of the person sending the voice and the worst possiblle is to have MUSIC in the background. These both drive the CODEC (the analog conversion system) crazy and will create what you describe. The CODEC is designed to transmit ONLY voice.
Oct 23, 2009 | Motorola Mobility Moto Q
Degen DE1103 background tone
the background tone is due to frequency static...the design of the stereo is not good... it lack of noise destortion cirquit..and almost all stereo that is analog usually poor in in design..change the stereo.try stereo that is digital in design..
Oct 13, 2008 | Kaito KA1103 SW/FM/AM Radio
Background noise
Check the cables in the back If i remember the Component Red jack is right next to the audio out jacks (also a red jack) if the audio cable is hooked up to the component jacks this will cause a humming static noise
Apr 12, 2008 | Samsung DVDR120 DVD Recorder
T-629 Background Static/They can't hear me
You had a bad speaker and need to be replaced
Dec 04, 2007 | Samsung SGH-t629 Cellular Phone
Squeaks from drum area during operation
We have a Bosch Nexxt dryer and it, too, squeaks during operation. We have not been able to find a permanent solution for this problem although we've had the repairman come out 3 times now. We have however found a temporary solution that lasts for about a week. We spray Static Guard (in an aerosol can) in the inside lining of the dryer... kind of in the lip of the front. (You shuld be able to feel it if you put your hand right inside the door.) We've just been spraying the static guard all the way around that area and the squeaking stops! Hope this works for y'all. May not be permanent but at least it stops the annoying sqeaking!
Oct 25, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Background static
1. How old are you phone lines in the house?  Check the "main" terminal connections.  Clean and reconnect.  (Make note how the wires are connected).
2. The power transformers for the phones maybe you trouble also. Unplug all except the main unit.   Check each transfer one at a time. Do you have static?  One or more may be your problem.  Replace the bad ones if needed.
Oct 04, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
Lots of static heard during use of this phone.
Time for a new phone. Most likely there are some bad solder connections and they could be anywhere. A 2 year old battery should not cause such severe problems so I'd spend the money on a new phone before a new battery.
Jun 27, 2007 | Motorola Mobility MA580 5.8GHz Digital...
Static on screen and then turns itself off then on
My first aproach will be to see if the tv reacts to tap on the sides if you see a reaccion when you do it most likely you have a loose conection and need to call someone to find it and resoldered it.Dont do it yourself if you dont know how.
Sep 11, 2006 | Proscan PS27125 27" TV
RIM BlackBerry Curve 8310 Smartphone Logo
1,362 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
