Question about Uniden D1484-4 DECT 4-Handset Cordless Phone
Base shows 88 8 nothing works
Handsets show searching all charging stations ok landline working no response using any base key no dial tone .
2 Suggested Answers
SOURCE: Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
Posted on Jan 21, 2007
At&t dect 6.0 all 4 handsets say no line
check base unit .
Check phone line is plugged into base and wall
Check base unit has power going to it
If it all looks ok try plugging a normal landline phone into the base unit locations phone line to see if there is dial tone .
Jan 28, 2017 | AT&T Lands Phones
How do i fix my landline phone?
hmm im not sure if there's an issue with the base for your wireless phones but it maybe that the phones arent able to determine if the base is active (EG the right base for the phones) some may need to be paired up to the base or the base maybe malfunctioning due to the lightning storm (Phone lines are prone to being struck at times which could send a surge to some types of phone bases and ruin them)
Aug 22, 2017 | Siemens Gigaset Digital Cordless Phone...
Hi, Bruce Kelly I have a Uniden DECT1480-3 That the screens on all hand set's say's SEARCHING. I can not get a dial tone so I am unable to make a call or recieve a call. Their is no dial tone and all of...
All of the handsets appear to have lost their
registration to the base and will need to
be first de-registered then re-registered.
It may be necessary to do this in three stages.
First be sure that all of the handset batteries
are fully charged.
1.
Clear one of the handsets of its registration:
hold down both the [END] and [#] keys
at the same time until the display shows the
SYSTEM RESET menu.
Since the handset is not recognized by its
base, select "Base Not Available".
Confirm the choice by selecting "Yes".
This handset will now display
"Handset Not Registered"
2.
With "...Not Registered" displayed, place
the handset into the base unit cradle.
The handset should now dieplay
"Handset Registering"
After ~30 seconds the display should show
"Registration Complete" and will have a
handset unit number.
If the unit shows "Handset 1" (doubtful)
then just repeat steps 1 & 2 above for each
additional handset in turn. This can also be
the route if you do not care what the numbers
are and do not exceed the maximum count
for your system ( some are 4, 5, or even 12 ).
If the handset is a number other than 1 you
may want to clear the base & re-register
all of the handsets:
3.
Using the now-registered and working handset
(number x), press both the [END] and [#] keys at the same time until the display shows the
SYSTEM RESET menu.
This time, choose "Deregister HS" and the
System Reset Menu will prompt you to
select from the list of registered handsets
which one you want to deregister: choose
one that is NOT the one you have working.
Cycle around deleting them all until only the
one that is working is left: select that one and
the system will be ready to start re-registering
all handsets again from Handset #1.
Start at process (1) above, then (2).
Good Luck!!
Apr 07, 2017 | Uniden Dect1480-3 Dect Cordless Phone, W/3...
Additional handsets will pick up calls from mobile phone but not landline calls
Try registering your older handsets with your new base station per the manuals instructions. Also your new base station might be transmitting on a different frequency or some other coded transmission is not recognized by your old handsets. Did the manufacture say the older handsets would work with the new system? They might not even if they did say so.
Jan 09, 2014 | Avaya 3920 Phone
Uniden 5.8ghz cordless W/2handsets has no dial tone cannot call out or recieve calls
There can be a lot of different things that could cause this. The first thing I would do is disconnect the telephone cord from the Uniden phon eand connect it to another telephone and see if you get a dial tone from it. If you do then we know that the telephon eline and the cord are OK so we go back to the Uniden telephone. Next, does the unit light up when you plug it in? are you sure that the telephone is getting AC Power? Are the displays on the handsets working? Does the handset display show "Handset XX" or does it show "Searching"? If it shows "Handset XX" then the base unit is getting power, if not the base unit may not be getting power.
If the base unit is getting power and the handsets are working and the power cord and jack were proven good by conecting another phone to them, then you would need to call uniden Customer Service for further trouble shooting or repair/replacement. the number is 1-800-297-1026
Jan 26, 2010 | Uniden Cordless Phone
Handset Won't Connect to Base Station
Here's is the fix, I just had the same problem.
I have 2 handsets here and just had replaced in 1 of the handsets.
Here's the trick, make sure the correct handset is in the correct base. The way this is done is when one of the handsets are in their bases, they will show either HS1 or HS2 in the upper right hand part of the display.
When they are in the correct base, then go push the Find HS button on the main base and you will hear the page feature paging the other base.
When the 2nd handset starts beeping just push the Find HS button again and other handset should work.
After that it don't matter which handset is in which base.
Let me know if this works for you.
Thanks,
Brian
Nov 12, 2008 | Uniden EXI 7960 Cordless Phone (EXI7960)
My landline phone does not work. I tested it outside on the company's jack and the phone works. I have 3 jacks in the house and it will not work on any of them, including the one I get the internet. The...
One of the phone handsets of the Panasonic KX-TG563 trio gives me static w/ dial tone and then shuts down or it gives me the message that "System is busy/Line in use" with no dial tone. If I get closer to the base unit it seems to work but w/ alot of static. The base unit phone works good and the other handset works ok too. The battery shows fully charged however, when I take the battery out to try a reset when I put it back in the battery indicator show very low. I tried switching batteries w/ the othe hand sets it doesn't help.
Thanks
Jun 07, 2008 | Lands Phones
STILL SAYS "PLEASE REGISTER"
I think this may be the answer. With multiple handsets reading "Please register" and a "working" base station (w ith dial tone). If you bring the remote units to the base station and place them on hte base, they will register and stay registered after you return them to the remote base. It doesn't say this anywhere in the instructions as it gives you the impression the remotes will register from their own base.
Jan 04, 2008 | GE 25932 Cordless Phone
Uniden D1484-4 DECT 4-Handset Cordless Phone Logo
132 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
