Question about Panasonic Viera TH-50PZ80U Plasma TV
Panasonic ph42px6u 2 blinks
Have a Panasonic ph42px6u 2 blink any suggestions?
    Producer:
    Uploaded 30 video answers.
  • Panasonic Expert
  • 155 Answers
panasonic ph42px6u 2 blinks - 1_17_2013_3_40_20_am.jpgTry this link
Posted on Jan 17, 2013
4 Suggested Answers
djchillsnyc
  • 151 Answers
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Posted on Dec 14, 2008
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-50PZ80U tv, error- 2 blinks
1. Reseating the connector P25 may solve the problem. If it does not.
2. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
3. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown.
Posted on Dec 06, 2009
RixsFixes
  • 2200 Answers
SOURCE: panasonic hd tv light blinks 7 times
Unfortunately this appears to be a common issue developing with these Panasonic sets i.e the '7 blinks of death'!
Several customers are complaining about it. The problem is caused by one, both, or all of the following boards: SC board, SD board, and SU board.
Most commonly, the SC board is the one that has failed and because Panasonic have received so many complaints about this issue they are now agreeing to replace the SC board under extended warranty.
However this is not widely known amongst the general public and Panasonic have kept it very quiet.
I would suggest that you make contact with the Panasonic Concierge service centre. Make them aware that you are aware of the SC board issue and that there is an extended warranty on this and ask them to replace it.
However if it happens that one of the other boards has failed be aware that Panasonic are not covering these under warranty and you will be charged for the repair in this case.
The Panasonic Concierge service is available from here
Thanks for using FixYa.
Posted on Jul 09, 2010
While viewing my 50 inch Panasonic (2 yrs old), it clicked and turned off. The pilot light blinked 7 times, paused and continued to blink 7 times, pause etc. That's it. It will not turn on. I look...
7 blinks Driver SOS 2 SU / SD / SS Boards. (SC floating voltage area)
This is the fault. 7 blinks of standby light denotes it. If you wish to get more details about the blinking codes to Panasonic TVs, check the site
linked here. It has details and some troubleshooting hints. google.com/+GopakumarGopalan
Nov 25, 2013 | Panasonic Televison & Video
Panasonic 42 inch television
HEY !!
ITS A CIRCUIT BOARD PROBLEM ... IC MAY HAVE BLOWN OFF ...
Jan 01, 2008 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Panasonic tv Th5opz81b flashes red twice will not turn on
Two times blinks to Panasonic Plasma indicates 2 blinks 15v SOS D Board. Check this site for more details about blinking codes to Panasonic Plasma displays.
Jan 16, 2013 | Panasonic VIERA Televison & Video
Red Blinks - No Power
2 blinks is one of the power sources not coming up. most likely thje power board,but a short on a periphael board can mimmick. Only a Panasonic auth service should be used and expect a repair of $200 to $400. Since the set is not very old,call the panasonic number in your book......they will give you a case number and in some instances may cover it!!
Jun 04, 2010 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
1 blink STV 5v sense DG Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
No picture and the led ligth is blinking panasonic veita 52
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
BLINKS PROBLEM MALFUNCTIONING PART
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Jun 11, 2009 | Panasonic (TH-50PZ700U) Television
The tv wont turn on
PT-44LCX65
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Panasonic Power Light Blinks Orange twice
sounds like the lamp driver or ballast is defective. That was a major issue on these model.
Dec 11, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic TH42PZ70B
Flashing RED lights in Panasonic TVs means a fatal error code. Unplug the TV, wait 1 minute and replug. If the LED still flashes it needs professional service.
Sep 04, 2008 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Panasonic Viera TH-50PZ80U Plasma TV Logo
24 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
