Question about SanDisk Sansa c200 MP3 Player
Equipment...........I hsve a Sandisk MP3 player............. 2.0 GB It was working all right the night before,,,,,,,,,,,,,,,then all of a sudden when I shut it off and went to turn it back on would not go on . Plugged it into the computer and use to light up to recharge...........nothing absolutely....... Do they take batteries of any sort........? Could u please advise as I have Cerebral Palsy and many nights can\t sleep due to pain and use to depend upon it to help get some sleep Many Thanks,,,,,,,,,,,,,,,Joseph D, Marshall
  • 8,596 Answers
Make sure the lock switch on the side of the player has not been activated.
If it is unlocked, you can use the following methods - the only revisions I would make for the c200 series is that you may have to use the REC instead of the volume button to get the computer to recognize the device again, and you can format the player directly from the player's settings menu itself (if you find it necessary to format the player in order to save it):
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Feb 28, 2009
Only one of my earphones work for my mp3 player
Make sure that you've pushed the earphone plug all the way in. Some Sansa players have very tight earphone jacks. If that doesn't work, it's likely that the player is broken.
Jan 28, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250 mp3 player connects and will not charge
It takes a while. Try leaving it charged over night, then tell me if you have any problems.
Sep 05, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
I need operating instructions for a SanDisk c250 2 GB MP3 player.
You can download the manual from the following link. All the operational instructions will be provided in the manual itself.
Cheers.
http://www.devicemanuals.com/guide/Cameras%20and%20MP3%20Player/SanDisk/SanDisk-Sansa-c250-MP3-Player-2GB-SDMX7-2048-TlRrNE56Yz.html
May 05, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
I have a sansa sandisk mp3 player. when i bought it it was working excellent.but all of a sudden it stopped working.this mp3 has no reset button i do not know how to fix the problem. sansa sandisk...
1. Are you able to turn it on ?
If so, press the the "power on" button the second time to activate the menu.
Still no luck ! Try putting in a new battery and try again.
2. You cannot "reset" anything.
3. Open up "windows explorer"
4. Scroll down the left pane of the window till you see the "sansa" removable disk
5. Right click it and select "format"
6. After formatting, try adding your files back again.
7. Use the >= button on the player tp play the songs.
Hope this has been helpful to you.
Aug 29, 2008 | SanDisk Sansa m240 MP3 Player
Sansa 250 2 gb
your USB might not be getting charge to it. might be, but see.
May 22, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Its dead with no special reason
try pressing the down button followed by the power button. the idea is this unlocks "reserve battery" so the player can tell you what the problem is.
May 16, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Connection/ Transferring tracks problems with Rhapsody.
left it charging over night and all the music erased...
Nov 26, 2007 | SanDisk Sansa e250 MP3 Player
Mp3 sandisk 150 player/trouble with the playback on recording
sandisk should be able to help you under warranty. call sandisk 1-866-726-3475 or 1-866-sandisk
Aug 04, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c200 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
