Question about Vizio VP504F 50 in. Plasma HDTV
Vp504 fhdtv10a wire kit
Does anyone have a vp504 fhdtv10a wire kit? My brother pulled all the pins out of one of the plugs Maybe just some photos of the wires and the order that they go in.
Problems with bosal towbar wiring kit....
bosal kits
claim to be plug and play to your vehicle
no wires meant to be cut
the wiring instructions might be generic and not truly specific to your C-Max
save time
wire in indicators old school
pick up the left and right indicator wires at the back of the car
make sure there is a good earth on the 7 pin plug
Mar 07, 2017 | Cars & Trucks
Visio VP504 fhdtv10a - When I plug it in, it has an amber logo light and makes a click noise (like a relay). When I press the power button nothing happens.
These are problems gradually developed in TV over the years. You may have to look for any dry solder, change the capacitors that look 'puffy' and try.
Jul 30, 2012 | Televison & Video
Vizio VP504 FHDTV10A Power problem.
It is showing some protection error and might need attention by a qualified service technician.
Jul 21, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Need wiring color codes, cord pulled out.
form top to bottom, for the wires on the power connection side (right) Aqua (A), Brown (S), orange (LR), yellow (LG), black (G), red (L). The letters in parenthesis indicate the letter by the connection on the circuit board.
Oct 06, 2010 | Griffin Technology iTrip Auto with...
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
Need to wire tow bar into 1999 LT35
Hi ebrown80
You can splice into each wire in turn at the back of the lamps.No need to cut right through the origional loom completly. For a really good joint you should spot solder each connection and insulate all joints well. Tow bar sockets operate on a common earth, so no need to loop each one.
Check back of socket and you will find each pin has a number. 1---7
The wiring colours from the socket back to the loom are as follows
No 1 Pin--- Yellow Wire---Left Side Flasher
No 2 Pin--- Blue Wire------Fog Lamp.
No 3 Pin--- White Wire--- Earth. Must have good contact or nothing else will operate.
No 4 Pin----Green Wire--- Right Side Flasher.
No 5 Pin----Brown Wire---- Left Side Park Light
No 6 Pin----Red Wire-------Brake Lights
No 7 Pin----Black Wire----Right Side Park Light. Centre Pin.
I hope this helps you out
Best of Luck with it
John
Sep 13, 2009 | 2004 Volkswagen Eurovan
Need wire diagram 4 altec lansing acs295 4 red connctor
I have the same speaker set. maybe we can help each other. My plugs are all fine but my sub is not connected to anything at all and I need to know were they must go on the pc board. Maybe we can trade some photos on the wiring diagram?
Mar 14, 2009 | Altec Lansing ACS 295 Computer Speakers
Installing a 7-pin trailer towing recptical on a 1991 Ford F150.
I believe you can look up the manufacturer of the trailer plug kit and find the wiring diagram there. On alot of the trailer plug kits, they have pics and diagrams in the package. The 7 pin plug (truck side) is available with the pig tail set up that plugs directly into the wiring harness for the lights. Then all you would have to worry about is the 2 wires for the electric brakes.
Nov 29, 2008 | 1991 Ford F150
Kenwood 8pin harness
looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Sep 27, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Vizio VP504F 50 in. Plasma HDTV Logo
18 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
