Question about Dremel Stylus Rotary Tool
Dremel stylus will not turn on and now will not charge
Went to use it this morning for small project, it would not turn on. Thought maybe battery was dead so I put it on the charger and a green light came on dock so I left for a couple hours. Now trying it again to find it still does not work and now the dock light doesn't come on either??? thanks mark
  • 132 Answers
SOURCE: Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
Posted on Nov 16, 2008
rowdy45176
  • 2176 Answers
SOURCE: useing a dremel stylus
I would call Dremel tech service at 1-800-437-3635 and ask them and also get a copy of an instruction manual for future use.
Posted on Jan 29, 2009
SOURCE: Battery on my cordless dremel will not charge.
Dremel Stylus AC/DC Adapter 230/240V Transformer primary is open circuit any idea what the AC output of the transformer is. I should be the same for 110V input transformer. If I can find the output voltage from the transformer I can probably get a replacement
Posted on Dec 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Dremel Stylus model 1100
I would contact Dremel.com and talk to their tech department about a warranty repair for this tool.
Posted on May 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: My dremel 10.8 lithium ion
The battery has been overcharged.
You will need a new one.
Thanks!!!!
Posted on Aug 18, 2010
How can I locate capcisator for Dremel Stylus Lithium-ion model 1100 ? It has got charging problem.The Stylus is a cordless tool.
Do you mean a capacitor? Is it the charger or is it the battery? The capacitor are plain types can be found at any electronic parts store. I think the main one is 220uf. Be sure an check each for problems.
Jan 18, 2015 | Dremel Tools & Hardware - Others
Dremel stylus 1100 (No Charger)
First you need to get an equivalent charger and some type of male/female or contact harness. This will have to have at least three pins as that is what is already on the Dremel. Now the difficult decision, do you want to open up the Dremel if it's still under warranty? If you don't mind opening it then my solution will work. Open up the Dremel and look at the inside of the contacts. As this is a DC charger it can only have positive and negative terminals. You say there are three contacts, so there will either be two positive and one negative or two negative and one positive. Most likely there will be a bridge wire between the two terminals with the same polarity. Strip a little of the insulation from the terminal wires and solder new leads to your contact harness. Noting the polarity of each pin/contact on the new harness wire the other part of the contact harness to the charger. You will most likely have to make a small hole in the Dremel's outer cover to allow the wires to pass through. As you own a Dremel I'm sure you are capable of attempting this easy bit of DIY. There is only one problem, If the third contact plate is a return signal to the charging base it might be to inform the charger when the battery is full. In this case the terminals inside the Dremel will not be bridged and I suggest you buy a new or secondhand charger. Hope this helps
Nov 15, 2013 | Dremel Cordless Stylus, 7.2V, 5, 000-25,...
Truck is draining charge and not charging battiers
I just went thru same thing with my 2003 f-350 diesel. I hooked up my horse Trailor and drove to Von's parked went in came back out and truck was dead. I tried to jump it didn't work. Then over next two hours two tow truck Drivers hooked up to both batteries full power charge direct to my truck and would not start.
End story required two new batteries alternator and cilanoid discussed above. In other post. Also contributing to the cause was really badly coroded cables they looked good at the connection point but wher discovered to be coroded inside the tubing just above the end connections so bow it has all been replaced and I have had no trouble since. Hope this helps. Tanya
Jan 23, 2013 | 2003 Ford F350 Super Duty DRW SuperCab
Dremel Stylus only charges for 2-3 minutes then stops
This is the charger, its getting a reading from the battery that its charged when it isn't. I don't know exactly how that charger is wired but, to be suroe it is the charger, as I have had similar problems beforehand.
Jun 17, 2011 | Dremel & Stylus Lithium Ion Cordless...
My relatively new stylus runs for a short while and then turns itself off! Any small restence on the tip while in use also seems to turn it off. Please tell me what the possible cause is.
Battery is flat or has a problem, the dremel does monitor voltage/current and shutdown to prevent battery damage, failure or fire. First step is to ensure the charge is working properly.
Dec 11, 2010 | Dremel Stylus Rotary Tool
Change the capacitor 220uF and it will most certainly work again. I got the idea from FixYa and it solved my problem!
Easy to change just 2 soldering points and a component costing around 0,2 Euros. If you do not know how to operate a soldering tool ask someone for a quick assistance. The switch takes around 2 min (1,5 min to open the charger and 0,5 min to change the component!).
/Johan
May 05, 2010 | Dremel & Stylus Lithium Ion Cordless...
Replace the docking station-charger of dremel stylus
ebay.com or www.craigslist.com
Try to find a used one maybe?
Sep 13, 2009 | Dremel Stylus Rotary Tool
Apr 01, 2009 | Dremel 8000 01 Cordless Rotary Tool Kit...
Useing a dremel stylus
Jan 28, 2009 | Dremel Stylus Rotary Tool
Dremel Stylus Rotary Tool Logo
Top Dremel Tools & Hardware - Others Experts
Mike
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
