Question about Philips HDD1630 MP3 Player
MP# IS MESSED UP
My mp3 shows please connect player to pc. i do it an it isnt read and i went into my computer and foramtted it an now when i click the thing for it in my computer nothing shows up. idk what to do this is gettin me very stressed can i get a lil help here
  • 8,596 Answers
Refer to FAQ on this issue on the Philips website. When this fails,
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
SOURCE:
My coby mp touch isnt connecting to my pc
Turn on MP3 player
Go to Setup > System > USB MODE
Put the USB MODE to MSC
Reconnect to the computer
Your computer should then recognize the MP3 player.
Apr 12, 2010 | Coby MP-705 Digital Media Player
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
Coby MP-610 MP3 Player froze up wont turn off or connect to my computer
If it just froze up, there's a reset button at the back/bottom, I used a staple if a paperclip isnt available. The reset button did nothing to solve my problem of only getting a screen showing "COBY" but maybe it'll help you.
Dec 26, 2009 | Coby MP-610 MP3 Player
MP305 showing do u want to format it now..
I'm assuming you actually want to format the mp 3 player. To do that plug into computer click computer right click the drive the mp is plugged into and press format. All data would be deleted.
Nov 25, 2009 | Coby MP305 MP3 Player
My RCA Opal M4204A is stuck on Intialize...and my computer won't read it.
you can try fomatting it.to do so plug it and open my computer.go to the drive of the mp3 and right click it.in the sub menu click format(to foramt it you have to be administrator)(also be sure backup all of your music,videos,pictures,and anything that you want to save.)
hope it helps-
Aug 14, 2009 | RCA OPAL M4001 MP3 Player
Cant upload songs to the mp3
I can help you with you Coby 610 mp3 player.
When the firmware inside the Coby 610 becomes corrupt, it doesn't communicate with your computer properly, so your computer can't see it.
Replacing the firmware in your mp3 player should have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Jun 17, 2009 | Coby MP-610 MP3 Player
I put pictures in a coby MP-C853 and i can't get them out.
Sounds like to me you got yourself in a bit of trouble, but luckily I maybe able to help you out ;)
Connect your mp3 player to your computer. Go to My Computer and look for the mp3 player, it should show up as a removable disk. Next, right click on the removable disk and select explore. This should open a folder containing the contents of your mp3 player. You will see folders labeled music, images, videos, ect.... Find the images you want to delete, which should be in the folder images. Click on the image(s) and right click it, then select delete.
Hope this helps <(^_^)> thanxx
Apr 19, 2009 | Coby MPC756 MP3 Player
Wont show anything but white screen
hello,
try connecting the device to your computer, go to 'start' button, go to 'my computer' right click the 'removable disk' drive, click format, and follow formatting instructions. this will erase all the data on the device, disconnect mp3 player ,reset the device with reset hole on the back of the unit. reset whole actually renews the firmware on it, so it should restore the screen.
Aug 22, 2008 | Coby MP-C7085 MP3 Player
It's stuck
please format the mp and after formtting then right click the mp icom in my computer, then click on tools then click on the check box of scan for and attempt recovery of bad sector and lastly click on start button
Jul 26, 2008 | SanDisk Sansa e250 MP3 Player
Photo upload??
1. Turn on Mp3 player, goto Settings, make sure USB mode is set to MSC or USB Device
2. Connect MP3 player to the computer
3. Go to Start button, under Start, go to My Computer
4. Under 'My Computer' there should be a drive labeled 'Removable Disk', double click on this drive.
5. Inside this drive (mp3 player) there should be a folder labeled (PhotoDIR). drag your photos *JPEG only* to this folder.
6. Disconnect MP3 player
photos will show in the Photo location on the MP3 player
Jun 04, 2008 | Coby MP-C7085 MP3 Player
Philips HDD1630 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
