Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Dishwasher pops open at 44 minutes
Pops open at 44 minutes left
5 Suggested Answers
mmoorree
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
The problem seems to be the loosening of the screws that hold the interior stainless steel skin to the door frame--not the latch.
With the door in the open position you should find a total of twelve screws (5 on each side and 2 on top at each side of the latch). The screws have a particular type of head which may require a trip to the hardware (its a $1,000 dishwasher take the time to get the right screwdriver). They are called TORX screws the size on my dishwasher was a T 15. These type of screw heads were designed to fit automated torque drivers at the factory that set the screws to the proper tension. So some care should be given when you retighten them. Turn until the screw is snug and there no movement of the inner door skin but don't over tighten. Giving it that extra 1/4 turn can be enough to strip the screw out and create a bigger problem.
Yes--you shouldn't have to be doing this to a KitchenAid appliance that cost this much--but I suspect that this will become a feature of periodic maintenance. The heating and cooling generates enough movement that overtime these screws work themselves out. My wife who was the once to make the right diagnosis noticed that the screws at the bottom were almost entirely out.
Posted on May 07, 2009
  • 205 Answers
SOURCE: kithenaid dishwasher door pops open
Your door latch may just be getting weak and the temperature and air pressure differentiation when the cycle is complete (it's hot inside) may be popping the door. If you have had the door seal replaced recently that may also be a factor, they can take awhile to settle in.
Posted on Jul 21, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: my dishwasher door keeps opening
Sorry to read about your problem, I hope this helps you out.
sorry, but you did not make the correct fix, look over your work and see where you may have made a mistake..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 27, 2010
  • 3 Answers
SOURCE: My kitchenaid dishwasher won't stay shut. It pops
Check that there isn't something still in the very back of the rack (top or bottom) that's sticking out and keeping the rack from sliding all the way in. Similarly, if the problem goes away when you take the racks out, the problem is with the racks. Otherwise, it's the latch: either the eye (attached to the top of the machine) is bent/broken, or the hook (inside the top of the door) is broken. Good luck.
Posted on Jul 27, 2011
Soap dispenser won't stay closed
Only two reasons this may happen. One is the dispenser is just bad (most likely) or that the timer is somehow malfunctioning and sending power to the soap dispenser all the time (least likely) You will usually know if its the second because the dispenser will get really warm after the dishwasher had been on for a few minutes.
Aug 15, 2012 | Asko D1716 Built-in Dishwasher
Door of detergent holder on Bosch dishwasher won't shut. It just pops open. Is there an easy fix?
Proceed with this step:
Timer
check the timer, and the linkage see it is defective.
Bi-metal switch or wax motor
test the swithc or the motor for defective.
Detergent cup, itself
can be clogged, for to open.
sincerely. God bless you.
May 07, 2012 | Bosch Dishwashers
KitchenAid KUDSO1FLSS5 - door pops open
I am an experienced techician and have tried all these solutions in the past sometimes at no avail. But replacing the tub which has a limited lifetime warranty along with hinge arms will solve the issue. This has such a margional clearance I can never see anything visible causing the door to pop open
May 27, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Soap dispenser door pops open
Try cleaning the compartment. If the latching is not OK, it could be a latch problem, or alignment, or total dispenser. Contact service provider for assistance.
May 26, 2010 | Maytag MDC4650AW Built-in Dishwasher
Mar 03, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kithenaid dishwasher door pops open
Jul 21, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Jan 09, 2009 | KitchenAid 24 in. KUDS01FLSS Built-In...
AEG Dishwasher 35080VI inbuilt - door pops open
usual door closure is onto a hook coming out of the top of ther cabinet just under the worktop. this needs adjusting to come out a little
Sep 02, 2008 | AEG Dishwashers
Dryer door pops open after running 5 minutes,close door hit start button door opens.let set 10 minutes ,run 5 minutes door pops open .dryer not overloaded. Serial #GEQ8811KTO
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Jun 14, 2008 | Whirlpool Dryers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
19 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
