Question about Midland 75-822 40-Channels Handheld CB Radio
Can't remove battery pack from radio
Push release button up, try to slide to left as instructions say, won't budge..Help!!
    New Friend:
LOL funny thing i had the same trouble. When you press the spring button you dont down or away it slide on a tack of sort. Slide to you or away either way you will see it slides off not pull off. Hope this helps
Posted on Jan 14, 2013
75-822 can't remove battery pack push button
Does it have screws? If so try to remove them an take pack apart. You can always put it back together.
Mar 24, 2014 | Midland 75-822 40-Channels Handheld CB...
I just need to change my batteries on my nsg-mr1, but every time I do this I spend 2 days trying to pry the back open. Is there some magic trick to this? I try to push down and slide as the icon suggests,...
Hey I just now got the darn thing opened. Placed remote in left hand then with left thumb pressure pushing down and sliding downward as the back indications show it released on the catches and lifted off.
Oct 11, 2013 | Sony Nsgmr1 Remote Control
Battery release latch won't open
If you push the battery in and try to release? Try a little silicon spray, mind not to over spray.If you hold open the release switch and manually pry out the battery with your finger nails?
Nov 12, 2012 | HP Computers & Internet
Nikon f601 won't rewind
needs repairing at a qualified shop
Sep 06, 2012 | Nikon F601 35mm SLR Camera
Tried to get hard top off my 1999 SL320. Rear points released but front ones stuck. They seem to be slightly released but roof won't budge. Rear points now out of their points and won't go bac
you need to release front points, they are partialy ceized, penatrating oil (wd40) keep working them, plenty of patience needed. good luck
Mar 18, 2012 | Cars & Trucks
By mistake, when removing the water to replace it, I turned the cap and it came off. realizing my mistake I replaced the cap, pressed the button and tried to pull it straight out per the instructions on...
the directions state To change the filter you would 1.) remove the cartridge cap (counterclockwise to a vertical position) and pull the filter out through the base grille. Directions state there will be water in the cartridge so some spilling may occur. 2.) remove the cartridge cap by sliding it off the end of the old cartridge. The cap will slide to the left or right. Do not discard the cap. 3.) Take the new cartridge out of the package and remove protective cover from O-rings. 4.) Slide the cartridge cap onto the new cartridge. 5.) With cartridge cap in the vertical position, push the new filter cartridge into the base grille until it stops. Rotate the cartridge cap clockwise to a horizontal position. Its the first part of doing this thats a real pain but after you get by the first instructions the replacement becomes easy if you have any further questions message me back Thanks again Rick
Jun 14, 2011 | KitchenAid Superba Architect KSCS25INSS...
Have tried following instructions but cannot get back off to insert battery - nothing budges and am reluctant to push/slide cover too hard. Is there a trick to this?
There is three tangs that hold the battery cover in place. You can push with 2 fingers on each side at the bevel area on both side of the camera len. You could also bring you phone to your local service provider to ask them to remove the cover for you.
Oct 11, 2010 | Nokia 2720 Fold Cell Phone
Water filter won't come out when I push the button
Push button? It should be a turn to the left to remove if it is a whirpool located at the bottom. These are twist out not push to release. The only push to releases are made by electrolux.
Mar 07, 2010 | Whirlpool ED2FHEXN Side by Side...
Midland 75-822 40-Channels Handheld CB Radio Logo
80 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
