Question about Frigidaire GLGT1031C Dryer
We need to replace the belt in our stacked frigidaire dryer. The first step is to unplug the machine, the second step is to take the back off the unit. This sounds very simple, but the back will not come off even though all screws have been removed. Any information on this?
the dr
  • 447 Answers
SOURCE: Stacking Instructions
You will need a stacking kit 5303937141 to stack them, Feel free to ask for any more advice.
Posted on Nov 24, 2007
SOURCE: take frigidaire dryer apart to replace bearing
Thanks Brent for asking the question.
Thanks Master Tech. Your post answered my question.
Posted on Aug 30, 2008
  • 14 Answers
SOURCE: How to Replace Dryer Motor
make sure its unplugged,pull over the pulley to losen belt,unplug electrical connector from motor,take any bolts and nuts lose.remove motor.install new motor in opposite of removal.
Posted on May 15, 2009
taran_2005
  • 10515 Answers
SOURCE: Belt replacement on a frigidare stacked dryer
Check the below link :-
http://repair2000.com/wpoolbelt.htm
Paste and copy it in other browser and click enter.
Any further help, let me know.
Thanks for using "Fixya"
Do rate the solution as "Fixya" if 100% satisfied.
Posted on Jun 01, 2009
  • 56 Answers
SOURCE: Frigidaire FEQ332 dryer: I (stupidly) removed the
well first turn the power off without those screws there is a chance you can arc the drum out agianst the element second you have to get at least one screw back in then rotate the drum slowly to line up the other holes do not run without the screws can cause some major damage
Posted on Jun 02, 2010
Testimonial: "Swift and helpful response - many thanks!"
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
I have a frigidaire glet1142cs0 top load stacked washer/dryer. the dryer turns but doesn't heat. not sure how to change the fuses or the heating element. please help
UNPLUG THE MACHINE. Take the back off the dryer, usually 4 to 6 screws. On the backside of the panel you just took off should be a schematic showing where the thermo fuses are.
Take an ohm meter and check across the prongs sticking up, you may have to unplug them to get good contact. They should show 1, open, if they show 0, short. they need replaced. There are online parts companies that can help you get the right part.
It is unlikely that the element is bad, but if the thermo fuses show open, then you should be able to see the element, and replace it.
Mar 26, 2011 | Frigidaire GLET1142CS Top Load Stacked...
Squeaking frigidaire stacking dryer
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Oct 10, 2010 | Frigidaire FEQ332E Electric Dryer
I am trying to find the right dryer belt for FEX831FS1
available through sears but the part number is
134503900
16.00 dollars
Oct 09, 2009 | Frigidaire FEX831CS Top Load Stacked...
May 15, 2009 | Frigidaire Dryers
REPLACE BELT
look to see if you have the little access panel on the back,you can remove this and have access to the belt and pulley system,if not there let me know and we'll try something else-mike
Oct 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Dec 23, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Replace belt
Before offering assistance I need to know if the old belt is still on the machine and in tact. The procedure is a little different if the belt has broken.
Dec 08, 2007 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire GLGT1031C Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
