Question about Ingersoll Rand Tools & Hardware - Others
3/4 ir 2145qimax gets stuck in reverse - Ingersoll Rand Tools & Hardware - Others
Paper stop at duplex fliper in ir 6000
Dear
Pl. check the toner clogged at the surface of duplex (reversing) flapper.
Check the sensors PS4-PS35-PS36-PS-37-PS38-PS46
Check Reversing flapper solenoid.
THE SENSOR ARE TO BE CROSS CHECKED.
THANKS.
Feb 21, 2015 | Canon Office Equipment & Supplies
Replace reverse valve ir 2135
Did you ever get the 2135 reversal valve installed?
Jan 24, 2014 | Ingersoll Rand 2135Ti Air Impact Wrench
Ws550 eletric. i need the forward and reverse switch for my ingersoll electric wrench
Ask your IR dealer for this part > IR 201718 SWITCH, last price I saw was around $38.00
Sep 12, 2013 | Ingersoll Rand Ingersoll-Rand 1/2 in....
STUCK TRIGGER
The I.R. 2135Ti or TiMAX has some known issues with the trigger o-ring (item# 22A) swelling, the throttle valve (item# 28D) bending or breaking, and the throttle valve seal (item# 28E) wearing out or deteriorating. Procedure wise you should not be able to remove the trigger without first removing the inlet bushing assembly (item# 26) the reason is that the reverse valve (item# 24) keeps the throttle valve from tipping forward and releasing the trigger, there is a slot for the stem of the throttle valve to slide into.
Follow this link to the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
When reassembling the tool first install the inlet bushing assembly and then install the trigger, make sure to lube the o-ring before inserting.
Oct 17, 2012 | Ingersoll Rand 2135Ti Air Impact Wrench
Hi, we run a canon ir 2016i in our office, and frequently the paper feed doesn't work properly. Especially the paper out of tray 3 and 4 gets stuck almost all the time. But quite often the paper f
The only thing I can think of, without actually seeing it work, is the feed rollers. I've never liked the feed system on this model, seems to be very temperamental. It could also be the feed clutches. There was a modification that should have done years ago dealing with the feed system. I don't know if this applied to the extra two cassettes but the two upper paper pick-up assemblies were to be replaced. Gears were updated.
May 08, 2017 | Canon iR 2016i Black and White Copier
Car is stuck in Reverse
It sounds like a bad shift indicator switch on the shifter. Kind of a pain in the *SS to get to those console's get real brittle.
Hope you get it in gear!!!
Oct 23, 2009 | 2004 Jaguar XJR-Series
TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
May 16, 2009 | iLO 3200 32 in. LCD Television
JVC HD-61G787 IR receiver location
I took the front of the tv off. the IR receiver is beside the lens. I stuck the IR emitter directly on the receiver and reinforced it with hot glue and then fed the cable out through the back off the tv. Not a hard job just lots of screws.
Dec 13, 2008 | JVC HD-61G787 61" Television
Tools & Hardware - Others Logo
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
