Question about Pioneer DEH-46DH CD Changer
How do you check the fuse resistors on Pioneer DEH-46DH?
The Pioneer DEH-46DH CD changer is not powering up
Using a continuity tester on the wiring harness:
-Main supplied power(regardless of ignition switch position) is good.
-Lighting switch power is good up to the fuse resistor, but not after it.
-Ignition switch controlled power is good up to the fuse resistor, but not after it.
Is the current through the fuse resistor too small to illuminate the light in the continuity tester, or is a volt-ohm-meter required?
  • 8 more comments
  • rwp2004 Jan 21, 2009
    What setting on a multimeter is used to check a fuse resistor on the wiring harness and what type of readings will show if it is not faulty?
    What is the purpose of the fuse resistor?
    Why didn't the factory just use a fuse?
    Thanks for all the good advice.
    Ok, checked the fuse resistors, with a volt meter and they are good. So, every power supply in the harness checks out, but still the unit will not power up.
    Does this mean I have to get a new unit?
    Or, can I take the cover off and look for something internal that would be obvious?
    I'm in the process of taking it out of the dash.
    what are the common problems with these types of units?
    The symptons before this were - occasionally the unit would just shut down while playing a CD.
    The nest day it would turn on and then shut down, and then it would not turn on at all.
    Will the new units accept the same wiring harness?
  • rwp2004 Jan 22, 2009
    Does anyone know what would cause this pioneer unit to stop working even though all the power supplies are good? It is dead.
    The Vehicle is a 1995 Chevy 1500.
    Thanks, the discussion led me to research areas that helped increase my knowledge to diagnose the problem with the DEH-46DH.
    Scholar:
  • 39 Answers
A fuse resistor should have a low resistance to allow power to flow the electronics. If you measure voltage from the electronics (load) side of the fuse to ground with a meter you should see voltage at the measurement point with the load turned on or off. If turning on the load causes the voltage to drop to zero then replace the fuse.
Sometimes electronics have a high inrush current when first turned on for just a split second. A regular fuse will blow out on a brief overload. To prevent this problem some fuses are rated slow-blow where a brief overload is tolerated but a sustained overload causes the fuse to open. Your "fuse resistor" may in fact be a slow-blow type fuse.
In that case the fuse should be replaced with an inline fuse (they come with inline fuse holders) of the same amperage with slow-blow rated.
Posted on Jan 22, 2009
    President:
  • 1,952 Answers
Check the multimeter
  • 535 Answers
U will nee the multimiter
or see the link
http://articles.techrepublic.com.com/5100-10878_11-5034314.html
    President:
  • 2,559 Answers
I think you may be refering to the rectifier
diode,and should be checked as followed.
Rectifier diodes How do you check the fuse resistors on Pioneer DEH - diode.jpg block the flow of current in one direction.
This type of diode is used for converting AC to DC because it will only allow electricity to enter in one direction and the current continues to flow through it to the output side of the diode.
You would no longer get the "alternating current" in the output circuit because now the current is flowing in one direction only (DC).
To test out a diode, first you will have to
set your digital multimeter
to the diode diode.jpg setting, which is usually part
of the Ohms (resistance) section on the meter.
If you are using an analog meter, then set it to the lowest Ohms ω setting. You should disconnect at least one side of the diode if it
is still in the circuit. First check resistance across the diode,
then check again but swap your leads to the opposite side
they were on for the first reading. If you get an open
(meter doesn't move) one way, but some kind of reading
the other way, then the diode is good. If you get a reading
(meter moves) both ways, then the diode is shorted. If you
get an open (no movement) both ways, then the diode is open.
Posted on Jan 21, 2009
    Sergeant:
    Novelist:
  • 326 Answers
The new unit will not have have the exact wiring harness as it will not wsupport the old.so it has to be repaired replacing the harness with exact will work.new unit harness will not work. thanks.
    Sergeant:
  • 378 Answers
It will be near to same but if its of same model number it will be exact but if of same company but different model number it will be near to same.so you can adjust as you want but check out the voltages of both the wirring harness before continuing.
  • 350 Answers
I don't know for sure but if you have one try it!
Make sure the Volt-ohm meter is the fuse type!
  • Jack Iaria
    Jack Iaria Jan 22, 2009
    Most in dash Music Players are unique to the manufacturer so...
    I'd go to a small store that specializes in installing car music and video systems. There are quite a few of them these days!
    I have been to the one in my town and they explained to me about the connections being non-compatible.
    Since you already have it out or are planning to take it out they will guide you through it at the store and even install it there for a minimal fee!
    Good Luck!
    Hope this was helpful.
  • Jack Iaria
    You must really love this unit to go through so much with us at FixYa here.
    If you want a faster answer consider asking the Experts by starting all over and asking for the Premium Guaranteed Answer which is awesome and guaranteed!
    Hope this helps.
    Good Luck!
    Please rate this answer thanks
    Sergeant:
  • 221 Answers
You can use multimeter for checking the resistor as the value of partcular fuse must be written on the fuse on its side .if it shows the perfect value with a multimeter as on the fuse then the fuse is perfectly getting its resistor.only for just checking out if the fuse is proper just check out with continuity as if the light comes on in the continuity its proper if no light comes that clears the fuse is faulty.also you can get the required fuse at local electronics shop.and for required parts for checking as well for the unit you can get at
www.radioshack.com
    Brigadier General:
  • 5,158 Answers
Fuse resistor i would suggest would blow slower then an actual fuse...not sure if the multimeter question was asked.... checking continuity would be on the resistance scale
Robert
Please rate this solution thanks
  • 1 more comment
  • Roberta Smith
    Roberta Smith Jan 21, 2009
    Ummm is that a ford by chance ?
    Robert
  • Roberta Smith
    Roberta Smith Jan 22, 2009
    i still need to know and i asked earlier is that stereo mounted in a FORD
    Robert
  • Roberta Smith
    If you are getting power to all the connectors on the stereo that require power.... and the stereo won't power up.... you have to face the fact the stereo is defective... repair or replace it
    Robert
    Brigadier General:
  • 8,619 Answers
Hi!
You can download the manual and see the location of fuse resistor and other components in the exploded views shown in the following manual
http://rc5.ru/upload/Pioneer_DEH-2130R,2100.pdf
Ask for any clarifications
  • 11,896 Answers
Use an Ohm or volt meter to check for continuity. If there is little or none, then you either need a new or bigger fuse resistor
  • 2 more comments
  • Nate Stansfield
    Nate Stansfield Jan 21, 2009
    the ohneter should be set directly in the middle. If the fuse is good the meter will jump all the way to the right. The fuse regulates higher voltages and protects the system. I always take mine off but I bought a regular fuse link thats like the one on the power wire. If your stereo has another fuse like a car fuse in the back of it you need necessarily need the other one. That's what I do, but that's just me
  • Nate Stansfield
    If all your fuses and wires check out ok, then ya it's the unit. Probably shorted resistor. Unfortunately about $200 to fix unless your good friends with a tech shop owner.
  • Nate Stansfield
    Nate Stansfield Jan 22, 2009
    Just wondering if you purchase the adapter for the wire harness? This adapter helps you connect ANY stereo to your truck without cutting your trucks wires. This adapter slips onto your factory harness so you don't have to cut your factory wires. You just have to wire the harness to your stereo. ALSO CHECK THE PLASTIC CONNECTOR THAT IS ATTACHED DIRECTLY TO THE BACK OF YOUR STEREO. THEY CAN SOMETIMES HAD BAD CONNECTIONS AND SOMETIMES TO STAY ON OR VIBRATE LOOSE.
  • Nate Stansfield
    Nate Stansfield Jan 24, 2009
    HEY THAT'S WHAT I SAID FIRST!
    President:
  • 1,990 Answers
Welcome to Fixya! you will need a Voltometer. Replace the Fuse links with a Larger Fuse and Casing. These are usually 20 Amp. Just go 25. Sometimes the Fuse Resistor will go bad on Pioneer units and will need to be Replaced. I only use Pioneer and have had to change them quite a Few Times.
  • 2 more comments
  • Travis Humphries
    Travis Humphries Jan 21, 2009
    They are Faulty if you tested Before and Have no Continuation after them. You can get these at Radio Shack.
  • Travis Humphries
    There are Hundreds of Multimeters and they all have different settings.
  • Travis Humphries
    They are the Same thing as a Fuse. You can get an Inline Fuse and Case from Radio Shack and replace these. If think that they should be 25 to 30 Amp Fuses.
  • Travis Humphries
    You can always check But, If you ever need to get it repaired at a Repair shop they might refuse Since it has been Opened up. Just a Heads up!
  • 4,472 Answers
You will want a multimeter. Have you tried changing the fuse resistor?
Thanks,
Lee
2003 explorer cd player
try runnning a len cleaning cd .
Jun 24, 2008 | Pioneer DEH-46DH CD Changer
Can a pioneer DEH-46DH super tuner be hooked up with subs? using its pre out?
Yes you can use the pre out to hook up an amp and subs. Probably the best way to send the signal to an amp to run the subs.
Sep 20, 2010 | Pioneer DEH-46DH CD Changer
Need plug wiring diagram pioneer deh-46dh
Orange-12v all the time
Red-igintion switch
Yellow- to lighting switch terminal
Black- chassic grd
Green-front L spk +
Green/black -front L spk -
Gray - F R +
Gray/black- F R -
Green/red- R L +
Black/green- R L -
Gray/red- R R +
Black/gray- R R -
Blue- Control to power amp if using.
Apr 10, 2010 | Pioneer DEH-46DH CD Changer
Pioneer Deh-2000 cd changer wiring schematics
here is the link to the manuals for your deck:
http://www.pioneer.co.uk/uk/support/manuals/DEH-2000MP/index.html
see installation manual page 4 for the wiring diagagram
Cheers!
Nov 11, 2009 | Pioneer DEH-2000 CD Changer
PLAYER WILL NOT TURN ON AT ALL
There is a fuse on the back of he player usually right above where you attach the wiring harness.
May 21, 2009 | Pioneer DEH-245 CD Changer
Now what
take the cd out and use a len cleaner
No AM!
A possibility is that the antenna cable/plug is shorted. You can try verifying this with a continuity tester or simply unplug the antenna and stick a piece of insulated wire with the tip/end stripped into the antenna. Try the AM with the wire as the antenna. Just be carefully not go that far as the wire may reach the PCB/electronics.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Pioneer DEH-1000 CD Changer
Wiring color codes for pioneer deh-425
Yellow: battery power Red: switched power Black: ground White: left front speaker Gray: right front speaker Green: left rear speaker Violet: right rear speaker Wires with stripes are the negative speaker leads.
Jan 21, 2007 | Pioneer DEH-425 CD Changer
Car Audio & Video Logo
799 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
