Question about Sharp 20L-S100 20" TV
I need to find the 4 digit code for my sharp tv
I don't know how to find the four digit code for my sharp tv so I could program a one for all remote control.
  • 8,197 Answers
2 Suggested Answers
  • 5 Answers
SOURCE: unlock the 4 digit code on the tv control?
how to unlock v-chip
Posted on Feb 21, 2008
I have a new sharp aquos tv LC 60LE633U. Remote is broken but have a universal Phillips remote anyone know the code ? Help please
Hello
Three digit universal remote codes for Sharp tV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit codes are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 28, 2012 | Sharp Televison & Video
Looking for th remote codes for sharp tv model, 25r-5100
Hello
Three digit universal remote codes for Sharp TV are:
Direct Code Entry
Oct 07, 2011 | Sharp 25R-S100 25" TV
We have also lost the manual for the RCA DTA800B1 converter box and need instructions to program the remote to work with a Sharp TV.
Press PGM on the remote control. The signal indicator on it remains lit.Enter the 3-digit program code with the number keys. Press OK The signal indicator will be o when the program is one.Press the volume keys on this remote control to check if they can adjust the volume of your TV set.• If you fail to control your TV set,repeat steps 2 to 4 to program again. Try another program code if there is more than one for your TV brand.• If the signal indicator remains lit after blinking four times, you may have
entered the wrong code. Repeat steps 3 to 4 to program again. Make sure you have correctly entered the code.• You can still use your TV remote control to turn on your TV set, select input source and control the volume.for conrmation.your sharp tv code is 005, 021, 071, 085, 087, 092, 128, 183, 208, 274, 298
Sep 16, 2011 | Televison & Video
What is the remote control code for the Sharp VC-A410 VCR?
Hello
Four digit universal remote codes for Sharp TV are:
Direct Code Entry
OK
Aug 03, 2011 | Sharp Televison & Video
Remote control code for comcast for lc-42SB48UT 42
Hello
Four digit universal remote code for Sharp are:
Direct Code Entry
Four digit universal remote codes for Sharp TV with RCA RCR311W are:
1004, 1007, 1009, 1015, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1158, 1182, 1195
OK.
Jul 02, 2011 | Sharp Televison & Video
What is the code of sharp tv model 2V-FW75M
Hello
You are asking about the universal remote code for Sharp I assumes, and place this solution before you.
Three digit universal remote codes for Sharp are:
Four digit universal remote codes for Sharp are:
Direct Code Entry
May 16, 2011 | Sharp Televison & Video
I need the code for an RCA remote model RCR311W for a sharp tv
Hello
Codes for Sharp TV with RCA RCR311w are
Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Direct code entry method
1. Manually turn on the component
you want the remote to control.
2. Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
one of the Code Search methods to
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
component key at any time
during the Direct Code Entry
procedure, the illuminated
ON•OFF key blinks four times,
and the process is exited.
4. While holding down the
component key, consult the Code
Lists for the four-digit code that
corresponds to your component's
brand and use the number keys
(0-9) on the keypad to enter it.
While you are pressing the
numbers, the illuminated
ON•OFF key turns off.
5. After the fourth number is
entered, the illuminated ON•OFF
key turns on. At this time, release
the component key. If the
illuminated ON•OFF key turns
off, you have entered a valid code
and have followed the correct
procedure for Direct Code Entry.
If you enter a code number that is not
in the Code Lists or you do not follow
all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks
four times when the component key
is released. This is an indication that
a programming error has occurred.
In that case, repeat the Direct Code
Entry process from step 3.
of each key, be sure to keep the remote
pointed at the IR sensor of the
component you are currently
programming the remote to control.
6. To confirm that the component key
is programmed with the correct
code for maximum functionality,
test the component. Attempt to
control a variety of the
component's functions with the
remote. If some of the features of
your components do not work, try
programming the remote with a
different code in the list until you
find the code that allows the
remote to control the majority of
your component's functions.
Different codes can provide
different levels of functionality
OK
Mar 04, 2011 | Televison & Video
Universal remote I need the code to a Sharp TV
Hello
Three digit universal remote code for Sharp TV are:
Four difit universal remote code for Sharp tv are:-
Direct Code Entry
NB: Switch OFF and switch ON your TV with its front panel power ON/OFF switch each time before trying an other code.
Mar 01, 2011 | Televison & Video
Looking for the four digit code for my sharp tv
Hello
Four digit universal remote code for Sharp Tv are:-
Direct Code Entry
NB: Switch OFF and Switch ON the TV by its front panel power ON/OFF switch [NOT BY THE REMOTE CONTROL HANDSET] each time before trying an other code.
Jan 08, 2011 | Sharp 19L-M100 TV
I need the remote code for a Sharp 27F541. I tried the codes provided by Charte Comm for their universal remote and none of them work. Thanks.
Hello
The Universal remote code for Sharp are [01 and 02].
Four digit remote codes for sharp are
[0079- 0123- 0063- 0020- 0004- 0009- 0226- 0266- 0006- 0095- 0122]
Nov 07, 2010 | Sharp 27F541 TV
Sharp 20L-S100 20" TV Logo
1,246 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
