Question about Hotpoint Dishwashers
Hotpoint FDW60 error code for 5 and 7
The 5th and 7th lights flash together on my hotpoint fdw60 dishwasher
SOURCE: dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Posted on Jul 21, 2007
SOURCE: Hotpoint FDW60 heater replacement
The heater is the black element at the bottom of the tub. you can see it when you open the door, there are 2 wires attached to it under the dishwasher along with 2 nuts and some rubber washers to keep it from leaking, It is a simple job to replace. Remove the wires undo the the nuts that hold it to the tub, and there may be some brackets inside the dishwasher that secure it in place. remove the element and replace it. Install in the reverse order you took it apart.
Posted on Feb 23, 2008
SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Posted on Mar 23, 2008
  • 3 Answers
SOURCE: Hotpoint FDW60 dishwasher - flashing lights
check the filter.
Posted on Jun 06, 2008
SOURCE: hotpoint fdw60 eco error code
I had this problem too, but discovered the cause and the remedy.
The flashing eco light signifies that the drain sump has water in it. Before the machine takes on water it checks a float located in the sump. If the float says that there is water in the sump then the machine presumes that there has been a problem when draining and decides not to take on any more water.
In my particular case, the sump collected extra water after the machine has last drained itself because the bottom spray arm has come off and allowed some water to enter the machine. Make sure that you check that!
The simple solution is to empty the sump of water. Do this by tipping the machine onto its right side. Warning! You will get wet feet! There was about a 1/4 pint of water in my dishwasher.
After that you should find that your dishwasher works perfectly again! Why Hotpoint couldn't include this simple task in their manual I'll never know! Health & Safety I guess...
HTH!
Posted on Sep 21, 2008
My hotpoint Aquarius Dishwasher starts up bu only runs a few moments before stopping with 2 lights flashing " wash " " drying "
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
Mar 18, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Dishwasher not working - FDW60
unplug it for an hour this normally fixes this problem on my machine
Jul 28, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Error code
just been told the code means heater failure. Just have to find out how to change it now.
Oct 18, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher error codes please help
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
108 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
