My samsung 13kg wa13v9 washing machine is blocked with black dirt. How can i clean it?
Samsung washing machine WA13V9 fills water and drains what could be the problem
problem program board going from fill to empty with out energizing the wash cycle
Nov 04, 2017 | Samsung Washing Machines
I have a Samsung WA13V9 top loading washing machine, the water is not flowing into the machine when turn on. Inlet hoses and filters are clear.
It's possible to be the door switch fault.
Teoretically if the door is not close, the water isn't flowing into machine.
Jun 03, 2017 | Samsung Washing Machines
I have a Samsung WA13V9 top loader washing machine the water is not stopping when the cycle starts I have to turn the water inlet tap off for it to stop.
If the water keeps running all the time whether the machine is on or off, the water solenoid valve in the machine has failed. If it only fills when the machine is on, it is likely to be something with the water level control. The pressure hose could be blocked or disconnected or the pressure switch or water level sensor has failed. I'm not fully conversant with the Samsung but the same principals apply.
Mar 20, 2017 | Samsung Washing Machines
My samsung top loader of 13kg shows code dE
Many Samsung top loader washers are recalled due to a severe unbalance issue that causes the top of the washer to become dislodged and fly off. Enter exploding Samsung washers in your search engine. Since your machine may be recalled, you may have a free service call coming your way anyway!
Nov 10, 2016 | Samsung Washing Machines
Looking for a list of errors and recommendations on SAMSUNG WA13F5S2UWW 13KG WH T LOADER Washing Machine
Hello. The user manual is located at http://www.samsung.com/za/support/model/WA13F5S2UWW/FA. It has some of the error codes listed in the troubleshooting section.
Aug 21, 2015 | Samsung Washing Machines
My Samsung WA13V9 washing machine doesn't drain or spin, but I think the pump motor is working. where can the problem be?
Check that the wiring inside is not damaged, if ok check that the start timer is not stack, if ok check that the drain pump is not blocked eg a coin stuck in it, if ok check that the start capacitor for the main spin motor is ok if not replace with same rating, if ok check if main spin motor is ok eg using continuty tester to check windigs or simply smell it and if burnt expect a pungent smell from it.
Aug 03, 2015 | Samsung Washing Machines
Where to clean filters on Samsung 13kg top loader?
Sounds like you need to have your machine looked at by a professional. You should not be finding rubber pieces in the machine.
May 08, 2014 | Washing Machines
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
