Question about Canon Office Equipment & Supplies
Pixma iX6560 error 6502 - Canon Office Equipment & Supplies
printerman40
  • 170 Answers
SOURCE: error code 6502
1-- With the printer unplugged, remove the ink cart to the right ,
2--Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3--The beeper may sound once ,Then Unplug the printer ,then power back up and reset the printer electronics ,open the printer and this process is finished. I believe this should take care of your issue, it's basically a cold reset for the printer, Give it a shot...
Posted on May 11, 2008
SOURCE: Canon Pixma IP600D - error code 6502
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Posted on Jun 10, 2009
  • 97 Answers
SOURCE: ERROR 6502
Call your local Canon dealer and ask them what the code means. I find this company very helpful.
Posted on Sep 25, 2009
pineworks
  • 4041 Answers
SOURCE: canon pixma ip4300
Hello
Try
Error Code 6502 appears generally after chaging a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
All Best: Pineworks
Posted on Jan 25, 2010
walesarumi
  • 6993 Answers
SOURCE: I have canon pixma proi 9000 I keep getting an
Hello
Follow the below steps in order to clear the error:
1.With printer OFF press and hold resume
2.while holding it down push and hold Power button
3.Release resume whilst still holding down power, the light should be green (not flashing)
4.Push resume once (orange) twice (Green)and a third time (orange)
5.release power button.
6.Then power it off and on again after it's finished making any noises and settled down.
Good luck.
Posted on Aug 12, 2010
Error 6502
this error indicates a problem with an ink cartridge. this can include a bad cartridge, improperly installed, or possibly ink leaking out when installing it.
reinstall ink catridges.
Oct 17, 2013 | Canon PIXMA iP3600 Photo Printer
Changed ink cartridge and now have error 6502 - have no clue what that means, but it won't print - yellow and green light alternate flashing
Error Code 6502 appears generally after changing a cartridge.
Solution:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 12, 2011 | Canon PIXMA iP3500 Printer
Canon pixma ip4300 Stoped working, light flashes 19 times and error code 6502 displayed on screen Help please?
Hello
Try
Solution:
All Best: Pineworks
Oct 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
ERROR 6502
Error 6502 (Ink tank position sensor error) the sensor is receiving too much light. Possible causes are:
1. The printer cover is open and the sensor is exposed to the light
2. The ink tank LEDs are busted
3. Sensor or its wire connection to the logic board is busted or disconnected
Solution:
1. Close the printer cover
2. Possible ink tank replacement
3. Change sensor or repair disconnected wires
Sep 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP630 error code 6502
Error 6502 is the ink tank position sensor error. Basically means the printer can't see the inks. Try reseating them. If this fails you need to send it back.
Jun 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
When printer is turned on error code 6502 comes on screen
Solution:
All Best: Pineworks
May 05, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP500 - "Error Code 6502"
Try holding the stop/reset button down for 10 seconds to see if the error clears. If it does not repost your error message to the forum.
Jan 28, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon IP4500 service error code 6502
canon pixma 4500 service error 6502
Jul 15, 2008 | Office Equipment & Supplies
Canon mp830 error 6502
Try cleaning the print heads with the Canon software.
Jul 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6502
This might work
Solution:
All Best: Pineworks
Jun 14, 2008 | Canon Pixma MP500 All-In-One InkJet...
843 people viewed this question
old marine
old marine
