Question about Bionaire Humidifiers
MANUAL FOR BIONAIRE ULTRASONIC ANTIMICROBIAL HUMIDIFIER
BUL2612
SOURCE: Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Posted on Jan 23, 2009
SOURCE: My Bionaire Humidifier
From the user manual (which is online)
2. Clean the base by partially filling
it with one 8-oz cups of undiluted
white vinegar or by using Cleanse
CleanTM Solution (DMS216) by the
manufacturer. Leave this solution
in the tank for 20 minutes, while
cleaning all interior surfaces with a
soft brush.
Posted on Jul 09, 2008
  • 114 Answers
SOURCE: I have a bionaire model w-9 humidifier. the
currently through the information that i have seen right now, the regulators are out of stock. the best thing that i can suggest is try the manufacturer or local hardware stores. now if your in canada you can always try canadian tire. i will keep looking just in case you aren't able to find one locally.
Posted on Aug 20, 2009
  • 114 Answers
SOURCE: Instruction manual required for Bionaire BCM7305 Humidifier
http://dl.owneriq.net/4/4fe95eae-f9fb-4074-81ac-eb5ba1586517.pdf
here is the manual to help you get through on operating your unit. if you have any more questions please let me know.
Posted on Aug 21, 2009
  • 114 Answers
SOURCE: replace humidifier filter
turn the unit off then take the tank off then the base which is the fan portion and the filter fits right there.. if it's a round filter then it slips right on. now if it's the squares they will slip into some slots and usually they will take about 4 if that's the case. if you have any other question please feel free to let me know.
Posted on Aug 29, 2009
Bionaire BT-200 ultrasonic humidifier have stopped misting, though I can hear a hum as though something is still working. I have two of these in the same state.
I have the same model; it has a little disk about the size of a dime at the bottom of the well where the mist comes out. That metal disk gathers white scale on it, Clean that off. The best way I have found is with a Waterpik turned all the way up. The scale keeps the disk from vibrating.
Jan 24, 2017 | Bionaire Humidifiers
When I turned on my ultrasonic humidiifier it worked for 10 sec, then I observed the water coming through the bottom. When I removed the tank and the bottom full with water. How can I fix this?
Bionaire BWM401 leaking - YouTube
? 0:39
https://www.youtube.com/watch?v=Gy7VKJJeb3o
Jan 20, 2013 - Uploaded by urhorh
My Bionaire BWM401 leaking through the bottom. ... Review ofBionaire Cool Mist Humidifier BCM7932P-CN from Costco HD - Duration: 1:41.
Nov 28, 2015 | Bionaire Humidifiers
Looking for a manual for BU4000 Ultrasonic Humidifier.
It took much longer than I thought it would but your manual is here:
http://homeappliance.manualsonline.com/manuals/mfg/bionaire/bu4000.html
If it does not come up make sure that you choose the BU4000 only in your search. The BU4000-UC will not bring up the manual.
Thanks for choosing FixYa.
Kelly
Sep 16, 2010 | Bionaire BU4000-UC Humidifier
Need product manual for bwm2600 humidifier - red light is on
http://www.bionaire.com/Manuals/MANUALS/BWM2601-U_43_27612514.PDF
here is the website that you can download the manual if you have any other questions please let us know
Jan 31, 2010 | Bionaire BWM2600-UC Humidifier
I need help
amazon.com has the manual for you to download or purchase. and also does the bionaire website. which is www.bionaireproducts.com
Apr 22, 2009 | Bionaire W7 Humidifier
Feb 21, 2009 | Bionaire BCM5520RC Humidifier
White dust coming out of humidifier
A concern is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck
Apr 05, 2008 | Bionaire BU4000-UC Humidifier
Noisy ultrasonic humidifire
The grey circle (diaphram) needs replacing. Try Maplin electronics.
Mar 31, 2007 | Swiss Air-O- 7135 Warm Mist Antimicrobial...
Humidifiers Logo
504 people viewed this question
Top Bionaire Humidifiers Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
