Question about HP PSC 1410v All-in-One Printer
Not Printing; I used to be able to print without any problems. Lately, I've been seeing "TEST" under Owner in the queue. Today the printer says "out of paper." It printed the test page for alignment, but that's it.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
Print queue stops document and will not resume
Clearing the Print Queue in Windows:
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
Cancel All Documents
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
Goodluck,
Please don't forget to rate the solution.
Apr 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
Lexmark x1190 with windows 7 print queue wont clear after printing
Once you load the driver successively then don't try to fiddle with driver. Remove the printer from the system and switch on whether the printer
initialize proper, try to print one self test page.
Jul 24, 2012 | Lexmark X1190 All-In-One InkJet Printer
My lexmark x1270 will not cancel printing queue
Hello, Skellycj
What you can do is unplug the printer from the power outlet and let it sit whilst deleting the jobs from the print queue on the PC.
On a windows machine you want to got to START, Control panel, Under printers, open up the printer and click on each task and delete or cancel, then reboot the computer.
This will ensure there is nothing in the printer queue and the printer stops printing tasks. I hope this helps you, we do hope you leave positive feedback and ratings for your free answer today.
Regards,
Rulds2008
Jul 28, 2011 | Lexmark X1270 All-In-One InkJet Printer
My printer refuses to print. The Red Status light came on so I checked and found there was a paper jam - cleared that. Can get green light to come on if I press the job cancel button but still cannot get...
Perform a Factory Reset
Turn the printer power switch OFF on the right side of the printer. Check that the front cover is closed.
Turn the printer power switch ON while holding down the GO button until the Toner, Drum, and Paper LEDs are lit.
Release the GO button. All LEDs will be off.
Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the Ready LED will be lit.
Print a Test Print Page
Print the Print Settings by pressing the GO button three times.
- If the Print Settings pages do not print, check for alarm lights on the printer. Clear the printer error before trying to print again.
- If the Print Settings pages print, the problem is isolated to printing from your computer. Verify the printer cable connects from the back of the computer directly to the printer. If the cable has become disconnected, loose, or connects through another device, the printer may not be able to print.
Check the Printer Driver Properties
Follow the instructions below based on the operating system installed on your computer.
Windows 7:
Click on the Windows icon => Control Panel => View Devices and Printers.
Right mouse click the Brother printer. Left click See What's Printing. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
Click Properties from this Printer menu list.
Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
Click the General tab and Print Test Page button. The Windows test page should now print.
- If the Windows test page prints, try printing from a program.
Windows Vista:
Click on the Windows icon => Control Panel => Printers or under Hardware and Sound click Printer.
Right mouse click the Brother printer. Select Run as administrator and left click Open. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Windows XP and 2000:
1. For Windows XP Professional, click on Start => Printers and Faxes.
For Windows XP Home Edition, click on Start => Control Panel =>Printers and other hardware => Printer and Faxes.
For Windows 2000, click Start => Settings => Printers.
2. Double-click the Brother printer to open the print queue. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
3. Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
4. Click Properties from this Printer menu list.
5. Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
6. Click the General tab and Print Test Page button. The Windows test page should now print.
Nov 01, 2010 | Brother HL-5240 Laser Printer
Not printing
First how are you connecting to the printer? What do you see when you look at the printer details (in Windows, Start, Printers or Devices and Printers (Win7), open device (double left click or right click)) Does it say printer ready? Are there any documents in the queue?
First: check if the printer is connected to the computer and that the cable is good (new cables are a good test). If you have a USB connection, try a different port. If you use a USB hub, try connecting directly to the computer (esp. on a bus-powered hub). If you are using a print server, check that the network connection is up and try rebooting the network router.
If you have documents stuck in the queue, you can delete them. If straight deleting from the queue does not work, you can force the entire queue to empty from the command prompt or Start Run. In both cases, type "net stop spooler" without the quotes, then to restore the spooler type "net start spooler". Restart the computer. (You can do this with just the stop command but plan on going for coffee after the restart.)
I hope this helps.
Feb 25, 2010 | Office Equipment & Supplies
PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Mar 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
Hp laserjet p1006 printing jobs gets struck in printing queue
I know this problems in my part it was the hp driver.
My Solution is to use an compatible driver.
HP Laserjet 5 / or 6 standard windows driver.
After that i have not this problems.
The secound problem is that this printer have very less memory and big pages in a few times are not able to print.
Dec 25, 2008 | HP LASERJET P1006 Printer
I want to print new page of printing printer keeps churning out prvious printing instrctions i am 78yrs old still learning
What you need to do is clear out the printing "QUEUE".
The printer is one of the slowest devices in a computer system. If you had to wait for it to print your document before you could resume writing, you would quickly go back to using a typewriter. To eliminate the delay, Windows reserves a portion of memory for something called a “print queue” (or spooler). The queue works on a first-in first-out basis. You can continue to use the computer and send jobs to the spooler as it feeds a steady stream of data to the printer.
Print queues are nice, except when something happens in the printer to cause it to stop functioning. Sometimes it is just a paper jam and sometimes it is a bit more serious. If you need to cancel the jobs in the print queue, you can simply double-click the printer icon (in the system tray down by the clock) and open the print queue. Depending upon the length of your document and how many documents are waiting to print, the printer icon may appear briefly or for a sustained period. (Note: This would be a good time to remove the paper from the printer before continuing.) If the icon is not there, you can manually open the queue.
This should solve your problem, Let me know how it works for you..
~~Jastababe~~
Nov 19, 2008 | Lexmark Office Equipment & Supplies
Unable to stop printer from printing documents
The actual folder in Windows where spooled documents are stored just before printing is: C:\WINDOWS\System32\spool\PRINTERS. I?ve never had print jobs hanging around after the print queue has been deleted but if you clear out anything in this folder that should take care of it. Let us know how things work out and please don?t forget to rate this posting.
Mar 17, 2007 | Samsung ML 2010 Laser Printer
HP PSC 1410v All-in-One Printer Logo
Ben Johnson
