Question about Maytag Washing Machines
Maytag LAT9700 Washer won't spin
We have a Maytag LAT9700 Washing Machine that stopped with water in it, and won't spin. No humming, nothing. My husband is a great do-it-yourselfer if you have any ideas on what to check?
  • Maytag Master
  • 17,129 Answers
Check on the voltage to the motor when the program goes to the SPIN mode. If there is no voltage the fault lies with the program controller unit. If present then check the motor capacitors and drive.
Posted on Jan 10, 2013
SOURCE: Top loading Maytag washer Model
When the machine worked would the machine stop in the wash cycle when you lift the lid? If so you might check your lid switch.
Posted on Jul 16, 2008
gil1714
  • 4 Answers
SOURCE: Motor Hums on Top Load Maytag Washer
Hi, this is gil1714 in Scotland. Motor not starting properly, and humming. this machine has an induction
motor which has a starter capacitor on the side(the cylinder shaped object). these age out, so try replacing
with one of the same rating (printed on it ??mu). if that doesn't solve the problem, check to see if anything
is partially jamming the drum, or if the machine is overloaded . the other possibility is that the coils in the
motor are starting to fail, which would entail replacing the complete motor. hope this is useful gil.
Posted on Dec 17, 2008
SOURCE: Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Posted on Jan 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: maytag washer will not drain the water out after spinning
If you experience a problem where the washer does not drain and the drain pump does not run at all, here’s the information you need to replace the drain pump:
Symptom: PUMP IS NOT RUNNING, NOT DRAINING AT ALL.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. Sometimes objects get caught in the pump impeller and stop it from running. We’re going to assume that you have already done this and that the pump no longer runs. It is strongly recommended that you remove all residual water from the wash tub & drain line at this point or you will have about a gallon or so inside your washer and on the floor to clean up.
5. HINT: Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
7. Locate the electrical connection to the pump and disconnect.
8. Now locate the two drain lines and remove them. The hose clamps can be released by squeezing with a pair of pliers. NOTE: I would not recommend removing the hose from the bottom of the wash tub unless you really have to. This one can be difficult at times to get back on.
9. Remove the torx type screw at the front center of the pump and it should slide right out of the mounting grooves on the bottom of the washer case.
10. Your new pump comes with several adapters to place on the feet of the pump in order for it to properly fit your washer. These are rubber bushings that help get rid of vibration and noise. If you become confused, there should be installation instructions that come with your new pump. You can also look at the pump you just removed to see how the bushings are mounted.
11. Reinstall the drain lines to the pump. HINT: It is much easier to do this with the pump still OUT, rather than installing it. When you squeeze the clamps to open them up, make sure you slide the clamp completely over the hose AND the inlet/outlet tubes on the pump housing in order to get a good seal.
12. Reinstall pump by sliding the feet of the pump into the mounting grooves on the bottom of the washer case. Tighten the center screw and reattach the electrical connection.
13. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
14. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
15. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump is supposed to energize and begin to drain.
16. If the pump works normal and there are no leaks detected, reinstall panel and tighten screws.
CAUTION: Use care when reaching inside the washer case not to damage the small wire harness that runs along the front of the machine.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
NOTE: My initial symptoms describe a drain pump that is NOT running. It is actually possible for the drain pump to be running and STILL not drain. If the pump impeller becomes damaged, or if the motor shaft is stripped, the pump will run, but will not drain properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
TheMobilian
  • 8220 Answers
SOURCE: My Maytag Bravos washer stopped on the spin cycle
You might have items between tubs. Are you using HE soap in the correct amount?
Service manual
Posted on Oct 29, 2011
Won't spin out and makes a humming noise
Wait for your handsome husband to come home and have him fix it. jk
Nov 09, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Maytag washer mav4757aww was agitating a little then would stop and make a slight humming sound. Now it won't agitate at all , it just hums and starts to smell like something is getting hot. It will...
Unplug the unit and remove the front panel and look at the space between the motor and transmission find the coupler that connects the two together this could be broken. You may have to lay the unit on it's back to check this out. It's a cheap fix if its the coupler. Let me know.
Sep 27, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
My Maytag diswasher legacy 300 does not drain . Water back up & spill overt the kitchen counter top. What shall I do ?
There are several reasons why a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Find some possible cause and how to solve the problem:
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
I hope the above helps;
Good luck.
Apr 14, 2011 | Maytag Dishwashers
WONT SPIN OUT WATER. HUMS
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Dec 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
73 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
