Question about IBM ThinkCentre Computers & Internet
Error during starting no processor bios update found
No processor bios update found during starting
  • IBM Master
  • 7,627 Answers
Try replacing the CMOS battery.
Posted on Jan 11, 2013
rockitman187
  • 2559 Answers
SOURCE: No processor Update Bios Found
Go here and scroll down to detect bios version and follow the instruction on the page.
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=ibm&lndocid=MIGR-4MBUDT&velxr-layout=print
Please rate this solution.
Posted on Jan 17, 2009
nkprl
  • 54 Answers
SOURCE: Bios Problem
if you still can enter bios setup look for the advanced menu in the BIOS for "processor updating" or something like this and set to "disabled". Save the changes.
otherwise your motherboard perhaps is incompartible with cpu
for example cpu 133 and motherboard 100 or 66MHZ
please let me know the result.
Posted on Nov 27, 2007
SOURCE: 167 bios update not found! i want to replace my
you will have to find out for sure if you can put that 1ghz into tha mhz slot first,because you just cant inchange mhz and ghz unless the mb. supports it.
Posted on Jun 15, 2009
leusnerdus
  • 54 Answers
SOURCE: Removing Micro code update error
download the microcode update from hp.com http://forums13.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1232885043213+28353475&threadId=1294996
you'll need a floppy unit
Posted on Apr 19, 2010
Denya_bit
  • 15 Answers
SOURCE: 0167 no processor bios update found
Could be that the bios itself is corrupted, You could try reloading that latest bios. Update the BIOS using flash from OS. link: http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_bios/24jy55usa.exe
Posted on Jul 13, 2010
How do I fix the Internal CPU error?
It's not glue it's heat transfer paste and gives the best way of getting the heat from the processor to the heatsink and then blown away by the fan.
You don't need a great amount as long as it is an even coating on the top of the processor, and the heatsink is securely fastened down.
Just found ths link to someone with the same error and other people suggest removing the processor and then replace it with another compatible one maybe a 2 core, updating the bios, then replacing the 6 core procssor.
Bios files to update are here: BiosFlash
Jan 26, 2012 | Asrock Computers & Internet
RESPECTED SIR, SIR MERE PASS IBM KA PC HAI. MERE PC MEIN 1.86 GHz KA PROCESSOR THE USKI JAGAH MAINE 3.00 GHz KA PROCESSOR CONNECT KER DIYA HAI. AFTER CONNECT MY PC SHOW A ERROR WHAN I START THE...
As I understand it, you tried to upgrade the CPU from 1.86GHz to a 3.00GHz. The error message is stating that the BIOS (Basic Input Output System) cannot recognise the CPU because it is not in the list of supported CPUs. You need to download an updated BIOS (if available) for the particular motherboard in your PC. You will need to get the model number of the motherboard which is usually written on the motherboard. Then go to this web site: http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do
Search for an updated bios for your motherboard. There should be instructions on how to update the bios.
May 25, 2011 | IBM NetVista PC Desktop
ASUS K8V-MX motherboard "UNKNOWN PROCESSOR"
There is a processor installed that the BIOS cannot recognize. Update the BIOS in the motherboard.
http://www.asus.com/Motherboards/AMD_Socket_754/K8VMX/#download
Also make sure the CPU is in the CPU support list, on the same page. If it is not a supprted CPU, you will get that error.
Apr 21, 2011 | ASUS K8V-MX Motherboard
End of the POST "Error
After a month you have probably found a solution. The Power On Self Test is looking for a Basic In Out System update. There is likely hardware on the machine that the system cannot recognize. The bios firmware update can usually be found at the chipset manufacturer's website or at a computer store that sells the NetVista machines. It comes on a CD that installs as a boot disk. Hope this info is still relevant.
Feb 15, 2011 | IBM NetVista PC Desktop
Everytime i start my pc there is always an error say cpu ucode error f1 to resume
You need an other BIOS driver.
Intel
P6 and NetBurst micro-architecture microprocessors may contain design
defects or errors known as errata that may cause the product to deviate from
published specifications. Many times, the effects of the errata can be
avoided by implementing hardware or software work-arounds. Errata and work-
arounds are documented in the appropriate processor specification update,
which can be found at www.intel.com. Intel P6 and NetBurst micro-
architecture microprocessors include a feature called "reprogrammable
microcode"
, which allows certain types of errata to be worked around via
microcode updates. The microcode updates reside in the system BIOS and are
loaded into the processor by the system BIOS during Power-On Self Test, or
POST.
Jul 10, 2009 | ASUS Computers & Internet
Sounds like you need to flash the BIOS (UPDATE the BIOS).
Do you know how to do this? The way I do it is by setting up a USB key as a boot device and have the FLASH utility on there....
HERE IS A LINK
which contains files to create the FLASH utility either on:
FLOPPY
CD (via ISO IMAGE)
... as well as some guides on what to do and other helpful stuff.
Its worth noting that if you have made any changes to BIOS, they will be restored to the 'factory' settings when you FLASH in the updated BIOS.
This should work, let me know if it doesn't.
Mar 27, 2009 | IBM (09N5424) Motherboard
Dec 13, 2008 | IBM NetVista PC Desktop
I have problem with celeron processor 2.4MHz with hp 5000 board
just go to microsoft.com and go to security and updates,you'll need your model# and they will check your computer for important updates.
Dec 06, 2008 | Gateway 500 S PC Desktop
Need to download updates for IBM Netvista 2gh Processor
to use your computer you need to put back your old cpu in .
then download the upgrade, and apply i.
after your bios is updated, your new plugged processor will be reconized.
Nov 21, 2008 | IBM NetVista A40p PC Desktop
Bios Problem
Nov 27, 2007 | IBM NetVista A40p PC Desktop
Computers & Internet Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
