Question about FrancisFrancis! X3 Espresso Machine
Where can I get an exploded view of the Francic Francis x3
I have removed 6 screws on top edge but the top does not come off and the nuts fall in to the unit
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
Have only worked on the X1. I don't think you will find service instructions. But if you look around carefully you should be able to find other screws which hold the machine together, and then the top will come off.
Posted on Jan 23, 2015
5 Suggested Answers
  • 1089 Answers
SOURCE: Hi I have francis francis x3 espresso coffee
Hi
You probably have a burnt out element, but there are other things that could be wrong.
  • Bad board
  • Bad thermostat
  • Bad wire to the element
There are 4 allen screw on the top outside of the machine. Make sure that it is unplugged. There is a hole in the back that you can insert a long screw driver and push up on the top. I don't recommend this if you are not handy.
Posted on Oct 18, 2009
  • 5 Answers
SOURCE: I have a Francis Francis X3 machine and would like
If you have an X3 Trio you are out of luck.
If you have the older model, you can buy 'ground coffee conversion kits' or you can use a ground coffee portafilter from an Ascaso Dream/Arc etc.
See: http://coffee-stuff.blogspot.com/2009/11/thing-of-beauty.html
Posted on Nov 06, 2009
  • 5 Answers
SOURCE: I need a Francis Francis x3 portafilter for ground coffee
If you have an X3 Trio - you are out of luck.
SOURCE: my francis francis x3 does not heat the water
Does the bottom light come on? The light is connected across the heating element and so if it is on the heating element is getting power. From looking at mine it looks like the bottom button for steam power bypasses the thermostat and uses the pressure switch to shut off the heating element. So if the light comes on when you press the steam switch but off when it isn't it is most likely your thermostat causing problems, if it never lights it is most likely the pressure switch. I do not claim to be an expert on the machine but from looking at mine that is what i would expect.
Posted on Jan 23, 2010
How to change the belt on dryer
CHANGING THE DRIVE BELT
1. Remove the top cover and the rear panel.
2. T720/780: Remove the external fan housing.
3. Remove the special tool.
4. Remove the belt from the belt pulley and take off the belt.
5. Feed the belt over the drum onto the motor shaft and over the belt pulley.
6. Install the special tool.
7. T720/780: Replace the external fan housing.
8. Replace the rear panel and top cover.
_____________________________________________________
REMOVING THE TOP COVER
1. Remove the three T20 screws at the rear of the top cover. (Keep the two star washers.)
2. Tilt the cover and pull it backwards.
25758001-gtkp3url2ghtdqenstp5bokb-1-0.jpg REMOVING THE REAR PANEL
1. Remove the top cover.
2. Unscrew the centering nut until the face of the nut is level with the end of the thread and knock out the bearing.
3. Fit the special tool (part no. 88 011 54) by fitting the tube end into one of the stamped out keyholes in the front rail. Lift the rear edge of the drum and press the drum edge onto the roller.
4. Remove the ground connection (yellow/green wire) from the input terminal block (see pages 8 and 9).
5. Take the cable bundle out of the cable clamp and pull the header block off its terminal pins.
6. Remove the wiring:
T700/T720: R1 a, R1 b, R1 13, R1 14, R1 34 on the contactor.
T760/T780: Ra, Rb, R13, R14, R34 on the contactor and F3 and F4 on the radio interference filter.
7. T720/T780: Remove the hoses to the water tank housing.
8. Remove the centering nut and the eight screws.
NOTE: Do not remove or loosen the screws around the heater housing or drum bearing.
9. T720/T780: Remove the three plastic screws at the lower part of the rear panel.
10. Lift off the rear panel.
25758001-gtkp3url2ghtdqenstp5bokb-1-5.jpg 25758001-gtkp3url2ghtdqenstp5bokb-1-20.jpg
25758001-gtkp3url2ghtdqenstp5bokb-1-27.jpg REMOVING THE EXTERNAL REAR FAN HOUSING
1. Remove the top cover and rear panel.
2. Unclip the external rear fan housing suction side.
3. Unscrew the 10 mm nut on the external rear fan wheel and remove it.
4. Lift the external rear fan housing motor side and pull it toward you.
Dado
Jun 23, 2015 | Asko T701 Electric Dryer
How to replace belt on asko t701 drier
1. Remove the top cover and the rear panel (see page 26).
2. T720/780: Remove the external fan housing (see page 32).
8. Remove the centering nut and the eight screws._____________________________________________________
Dado
Sep 22, 2014 | Asko T701 Electric Dryer
How to remove moen bath faucet handle that has no set screws and is all 1 piece
1.) its not all one piece
2.) the tower threads onto the valve body, you may need to loosen the mounting nut under the sink top with a basin wrench to relieve the pressure on the handle tower
3.) this is the exploded parts view for your faucet: http://www.moen.com/shared/docs/exploded-parts-views/s498pt.pdf
4.) this is the instruction sheet for your faucet, including a technical support number you can call: http://www.moen.com/shared/docs/instruction-sheets/ins1207.pdf
Aug 26, 2014 | Moen Showhouse S498 Savvy Two Handle...
Replacing outer cover on over the range Samsung Microwave
With the full model number, we could have linked you to the service manual.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 23, 2013 | Samsung SMH7174BC Microwave Oven
Need to remove heater A/C dash control , what is proper procedure?
Look at fig. 4 for the heater a/c dash control: HEATER CORE Altima REMOVAL AND INSTALLATION
  1. Position the steering wheel in the straight-ahead position.
  2. Turn the ignition switch OFF.
  3. Disconnect the negative (() battery cable; then, the positive (+) battery cable. NOTE: Wait for a least 3 minutes after disconnecting the battery cables for the charge in the air bag circuit to dissipate before working on the air bag module(s).
  4. Remove the driver's side SRS and steering wheel by removing or disconnecting the following:
    • Lower lid from the steering wheel and disconnect the driver's air bag module connector
    • Left and right side lids from the steering wheel
    • Special bolts from both side of the steering wheel using a tamper resistant Torx wrench (T50)
    • Air bag module and store it face up
    • Horn's electrical connector and remove the steering wheel nut
    • Steering wheel from the steering column using a suitable puller
  5. Remove the passenger's side SRS by removing or disconnecting the following:
    • Glove box door and the glove box
    • Front passenger's air bag module connector
    • 2 special bolts using a tamper resistant Torx wrench (T50)
    • 4 passenger's air bag-to-instrument panel nuts
    • Front passenger's air bag module and store it face up.
  6. Drain the cooling system into a clean container for reuse.
  7. Discharge and recover the air conditioning system refrigerant.
  8. Working in the engine compartment, disconnect the heater hoses from the heater core tubes.
  9. Remove the instrument panel by removing or disconnecting the following:
    • Kick plate and dash side finisher on the driver's side
    • 2 lower panel-to-instrument panel screws and the lower panel on the driver's side
    • 2 lower reinforcement panel-to-instrument panel screws and the lower reinforcement panel
    • 6 steering column cover screws, the covers, the spiral cable and combination switch
    • 2 cluster lid "A" screws and the cluster lid "A"
    • 3 combination meter screws, disconnect the electrical harness connector and remove the combination meter
    • Switch panel
    • Instrument panel lower covers
    • Snap out the transmission shifter finisher (boot)
    • 4 cluster lid "C" screws and the cluster lid "C"
    • 4 audio and deck pocket-to-instrument panel screws and the audio and deck pocket
    • 5 center console screws and the center console
    • 2 center instrument panel screws and the center panel
    • front defroster grilles
    • Front pillar garnish
    • Instrument panel 3 nuts/4 screws and the instrument panel
    • 8 instrument stay assembly nuts and the stay
    • Steering member assembly 5 nuts/1 bolt and the steering member
  10. Remove the air conditioning housing assembly by removing or disconnecting the following:
    • Refrigerant lines from the air conditioning housing assembly
    • Thermo control amp
    • Air conditioning housing assembly
  11. Remove or disconnect the following:
    • Heater unit
    • Heater core from the heater unit Fig. 1: Exploded view of the steering wheel and air bag module 93112gd9.gif
      Fig. 2: Exploded view of the passenger's side air bag module 93112gd0.gif
      Fig. 3: Exploded view of the instrument panel assembly 93112ge1.gif
      Fig. 4: Exploded view of the heater housing assembly and related components 93112ge2.gif
      Fig. 5: View of the heater core and heater housing 93112ge3.gif
    To install:
  12. Install or connect the following:
    • Heater core to the heater unit
    • Heater unit
  13. Install the air conditioning housing assembly by installing or connecting the following:
    • Refrigerant lines to the air conditioning housing assembly
  14. Install the instrument panel by installing or connecting the following:
    • Steering member assembly and the steering member 5 nuts/1 bolt
    • Instrument stay assembly and the 8 stay nuts
    • Instrument panel and the instrument panel 3 nuts/4 screws
    • Front defroster grilles
    • Center instrument panel and the 2 center panel screws
    • Center console and the 5 center console screws
    • Audio and deck pocket and the 4 audio and deck pocket-to-instrument panel screws
    • Cluster lid "C" and the 4 cluster lid "C" screws
    • Snap in the transmission shifter finisher (boot)
    • Switch panel
    • Combination meter, connect the electrical harness connector and install the 3 combination meter screws
    • Cluster lid "A" and the 2 cluster lid "A" screw
    • Combination switch, the spiral cable, the covers and the 6 steering column cover screws
    • Lower reinforcement panel and the 2 lower reinforcement panel-to-instrument panel screws
    • Lower panel and the 2 lower panel-to-instrument panel screws, on the driver's side
    • Kick plate and dash side finisher, on the driver's side
  15. Working in the engine compartment, connect the heater hoses to the heater core tubes.
  16. Install the passenger's side SRS by installing or connecting the following:
    • 2 new special bolts and torque using a tamper resistant Torx wrench (T50) to 11-18 ft. lbs. (15-25 Nm)
  17. Install the driver's side SRS and steering wheel by installing or connecting the following:
    • Steering wheel to the steering column
    • Steering wheel nut and torque the nut to 22-29 ft. lbs.
    • Air bag module
    • New special bolts to both sides of the steering wheel and torque the bolts using a tamper resistant Torx wrench (T50) to 11-18 ft. lbs. (15-25 Nm).
    • Both the left and right side lids to the steering wheel
    • Lower lid to the steering wheel and connect the driver's air bag module connector
  18. Refill the cooling system.
  19. Connect the positive (+) battery cable; then, the negative (() battery cable.
  20. Evacuate, charge and leak test the air conditioning system refrigerant.
  21. Operate the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Nov 19, 2010 | 2002 Nissan Sentra
How to replace side mirror
Outside Mirrors REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable. NOTE: This procedure is for power mirrors. The procedure for a manual mirror is the same with the exception of the lack of electrical wiring.
  2. Remove the door trim panel, plastic fasteners from the sound insulator and water deflector, as required.
  3. Unfasten the retainer, then remove the mirror trim panel. Fig. 1: The outside mirror has a trim panel which is secured with a screw and a retaining clip 89630g19.jpg
    Fig. 2: Unfasten the retaining screw . . . 89630p19.jpg Fig. 3: . . . then remove the mirror finish panel. Note the panel retaining clip (see arrow) 89630p10.jpg
  4. Disconnect the wiring connector and remove the wiring from the door retaining tabs. Fig. 4: Exploded view of the outside mirror cable routing 89630g20.gif
  5. Remove the mirror retaining nuts/screws, then remove the mirror with insulator and wiring. Fig. 5: Pull the sound absorber filler pad out of the door 89630p11.jpg Fig. 6: Unfasten the side view mirror retaining nuts and bolts 89630p12.jpg Fig. 7: Exploded view of the outside mirror assembly mounting 89630g18.jpg
    To install:
  6. Refit the mirror with insulator and wiring into position.
  7. Install the mirror retaining nuts/screws.
  8. Route the wiring through the door retaining tabs and reconnect the electrical connector. Make certain the wiring harness does not interfere with the window glass operation.
  9. Install the water deflector, sound insulator and door trim panel, as required.
Nov 05, 2010 | 1997 Pontiac Bonneville
Where is the blower motor located on a 91 Dodge Dakota and how do I access it?
Blower Motor REMOVAL & INSTALLATION Dakota
  2. Remove the steering column cover, intermittent wiper control and the lower instrument panel module retaining screw to the right of the steering column.
  3. Remove the center distribution duct retaining screws and panel support screw at the bottom of the module. Fig. 1: Heating/air conditioning unit components - Dakota models 88476g01.gif
  4. Remove the courtesy lamp at the lower right corner of the module and the screw near the ash receiver.
  5. Open the glovebox and remove the screws along the top edge.
  6. Move the module out and down far enough to unclip the wiring harness and antenna cable and disconnect the speaker wire (if equipped with monaural radio) and glovebox light wire. Remove the module from the vehicle.
  7. If the vehicle is equipped with air conditioning, disconnect the two vacuum lines from the recirculating air door actuator and disconnect the blower lead wires.
  8. Remove two screws at the top of the blower housing, five screws from around the housing and remove the blower housing from the unit.
  9. Remove three screw attaching the blower to the unit and remove the blower from the vehicle.
  10. Remove the fan from the blower motor.
  11. Installation is the reverse of removal. Secure all components accordingly and check the blower motor for proper operation.
Pick-Up and Ramcharger
  2. Disconnect the blower wiring. Fig. 2: Exploded view of the heater assembly components for Pick-up and Ramcharger models 88476g00.gif
  3. Remove the blower motor cooling tube. Fig. 3: Disconnect the wiring and cooling tube to access the blower motor - 1994-96 models shown 88476g06.gif
  4. Remove the screws or retaining nuts retaining the blower plate to the housing. Fig. 4: Unplug the wiring harness connector to the blower motor 88476p14.jpg
    Fig. 5: Unfasten the blower plate housing screws 88476p15.jpg
  5. Remove the assembly from the housing. Fig. 6: Lift away the blower plate housing for access to the blower motor 88476p16.jpg
  6. Remove the spring clip fastening the blower wheel to the blower shaft and pull off the wheel. Remove the blower from the plate. Fig. 7: Unclip and remove the blower wheel 88476p17.jpg
  7. Installation is the reverse of removal.
Oct 14, 2010 | 1991 Dodge Dakota
Francis Francis x5
Hi
Pull the clock out of the front. There is an 8mm nut that needs to be removed. There is a 2mm Allen screw in the back center of the machine, that needs to come out. Then pry between the top cover and the machine to release the snap pins.
There are 4 nuts by the brew head that are either 8mm or 7mm that need to be removed before you can remove the boiler.
Apr 18, 2010 | FrancisFrancis! X5 Espresso Machine
Ford expedition side mirror (instalation giude)
SECTION 501-09: Rear View Mirrors 2003 Expedition/Navigator Workshop Manual REMOVAL AND INSTALLATION Exterior Mirror Removal and Installation
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
Front Door Trim Panel —Expedition Removal and Installation
NOTE: Left front door shown, right front similar.
  1. Remove the door handle bezel.
    • Use service notch.
  1. Remove the window control switch plate.
    • Use service notch and disconnect the electrical connectors.
  1. s3j~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
    Remove the two bolts and three screws, and remove the door trim panel.
  1. Remove the weather shield.
  1. Disconnect the exterior mirror electrical connector.
  1. Remove the exterior mirror.
    • Remove the nuts.
  1. To install, reverse the removal procedure.
    • Install top nut first.
Exterior Mirror Motor Removal and Installation
  1. Position the mirror glass to obtain a gap at the top edge of the mirror and carefully pull the top edge of the glass away from the mirror housing.
  1. Disconnect the heated mirror electrical connectors.
  1. Remove the exterior mirror motor screws and exterior mirror motor.
    • Disconnect the electrical connectors.
Oct 26, 2009 | 2003 Ford Expedition
Hi I have francis francis x3 espresso coffee maker. Recently, the machine stopped heating up. It runs on, but is not heating up. It also, at one point, flipped the circuit breaker. I don't knoe if the unit...
Hi
  • Bad board
  • Bad thermostat
Oct 18, 2009 | FrancisFrancis! X3 Espresso Machine
FrancisFrancis! X3 Espresso Machine Logo
164 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
