Question about GE GSH22JFT Side by Side Refrigerator
The freezer is freezing up every 3-4 weeks
The refrigerator was purchased 02/07. In the last couple of months the freezer has frozen up every 3-4 weeks. The coils have always been kept clean. My only guess is that the defrost cycle is no longer working. But I can not find any information, other than general discussions, regarding the defrost cycle.
  • miltc47 Jan 26, 2009
    I haven't received a solution for the problem. Just someone who has the same problem. Does anyone have the part number for the control board - I actually believe this is the problem.
Likewise, sorry no solution but have the same problem. freezer develops ice build up and also stops fans from going. solution would be welcome - tried defrsting and yes works but oly for a while.
Posted on Jan 21, 2009
Had a fully cooked ham and heated it up with the dressings for it. can tjis ham be frozen
hi Verene.
If you have leftovers, you can easily store ham in the refrigerator for up to a week. However, if you have a lot, or even a whole cooked or smoked ham left untouched, youcan keep it in the freezer for longer storage. ... 2 Place your sliced or cut-up ham into airtight freezer bags.
How to Freeze Cooked & Smoked Ham - Living The Bump
living.thebump.com/freeze-cooked-smoked-ham-7911.html
Can you freeze a cooked ham?Experts recommend freezing uncooked, uncured and fresh ham for 6 months or less. If the ham has already been cooked, it should be frozen for 2 months or less. If you plan on freezing a ham for more than a couple of months, you should buy it uncooked, put it in the freezer and then thaw it when you are ready to cook it.Can You Freeze Ham - Dereezedereeze.com/food-and-cooking/can-you-freeze-ham/Search for: Can you freeze a cooked ham?
if you need to read up some more then go to this link.
CAN COOKED ham be frozen Google Search
Nov 25, 2017 | The Kitchen Appliances - Others
LG LMX28988ST freezer at 30 degrees
What it the reason that my fridge is freezing my food. The temp. IS set to 37 F. Why
Mar 14, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
My Kenmore refrigerator defrost drain freezes over.
There is a heat probe kit available to help prevent the drain hole from freezing shut. Part # 819043.
Jan 29, 2010 | Kenmore Refrigerators
My freezer doesn't keep ice cream frozen more than a couple of hours. Other foods are frozen, but some slightly 'soft' frozen. Up until a couple of weeks ago it would produce ice cubes regularly. Now if I...
YOUR DEFROST TIMER MAY BE BAD OR THE HEATERS ARE BAD. WHAT HAPPENS IS THE EVAPORATOR IS FROZE OVER WITH ICE AND CAN'T TRANSFER THE COLD . UNPLUG THE FRIDGE FOR A FEW HOURS (HAVE RAGS AND MOP READY) AND IT WILL WORK AGAIN TEMPORALLY . THE LESS YOU OPEN THE DOORS THE LONGER IT WILL LAST.. BACK IN THE DAY IT WAS CALLED DEFROSTING THE FRIDGE AND WAS DONE ONCE A MONTH OR SO
Jan 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refer not cold and freezer frozen in the back but not keeping things frozen in the front. I have shifted the controls from high to low with no apparent change. This is a month long endevor. The fan in the...
Without the specific refrigerator model, it's difficult to say but generally...
  1. If the coils inside the freezer are frozen solid with ice, the air can't flow.
    Also, the air needs to flow from the freezer to the refrigerator, but can't because of the ice.
    Defrost the freezer completely, if it freezes up again, check #2 or #3.
  2. The refrigerator control module or timer may be bad, and isn't telling the freezer to defrost at the regular interval.
    The control module/timer will have to be replaced.
  3. The heater wire in the freezer may be burned out, and would have to be replaced.
A control module could be $35-$100, around $30 for a heater wire, plus labor.
I'm not an appliance repair technician, these are only estimates from previous experiences.
Best of luck,
-Greg-
Sep 13, 2009 | Refrigerators
Coils on Side by Side Refrigerator keeps freezing
sounds like you need to replace your defrost timer it is in the front underneath the fridge if you pull off the front kickplate you will see it in there
May 01, 2009 | Refrigerators
Contents of crisper drawers are frozen
may be a faulty compressor. ours went out last week, covered by 5 yr warranty though.
this might cause over-cooling and frozen water dispenser as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
GE GSH22JFT Side by Side Refrigerator Logo
165 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
