Blenders Logo
A
Anonymous Posted on Jan 09, 2013
Replacing a vitamix VM0109 blender blade
How do you replace the wet blade
5 Related Answers
Anonymous
  • 114 Answers
  • Posted on Jun 16, 2008
SOURCE: replacement blades
You can go to their website to get replacement parts:
http://www.focuselectrics.com/catalog.cfm?dest=dir&linkid=82&linkon=category
Anonymous
  • Posted on Jun 10, 2009
SOURCE: Can't find replacement parts for my Thunderstick Pro blender
I can sell you part of mine. I getting a new one to replace a part for mine.
Anonymous
  • 563 Answers
  • Posted on Jun 18, 2009
SOURCE: blender turns off
I work for Black & Decker appliances and have more than 10 years experience with small appliances.
Anytime you smell something burning while using an appliance that isn't suppose to heat food, something is wrong. You shouldn't smell any foul odors emanating from a blender. The fact that it shuts off while pureeing something as simple as oatmeal indicates that particular blender is defective.
If you contact the manufacture they will be able to inform you as to your warranty eligibility.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Anonymous
  • 38 Answers
  • Posted on Nov 09, 2009
SOURCE: Blades on inside of kitchenaid blender jar won't turn.
look on ebay for a replacement second hand unit
Anonymous
  • Posted on Aug 11, 2010
SOURCE: Krups 239 blender drive gear.
Like you, I am all for repairing and keeping the world free of blenders that only need one part replaced. The rubber coupling was easily ordered online, the challenge I later found was to remove it without losing my sanity. After messing up the side grill of the blender pretty good, I realized there is an opening on the motor casing that allows access to a "gear" that is firmly attached to the axle where our little friend will hopefully screw on and restore the contraption to a working state. In order for you to see (which I must warn you, it's not much of a view) through the grill you will need a flashlight or book light. Towards the top of the aforementioned gear (not the rubber part) there is a groove in which a flat screwdriver can easily fit immobilizing the axle and allowing you to easily unscrew it. Oh, but wait, I forgot this is the faulty part and it will spin without the slightest torque on the axle thus never loosening or getting it unscrewed. My solution to this problem was to surgically remove as much rubber as possible to allow me to attach my vise grip to the nut and finally put this thing out of its misery. Using the same procedure of inserting the screwdriver to immobilize the axle I was able to screw the new part and voila the blender is fixed!!!!
Vitamix blender recalls.
If you ask which Best Vitamix model is the finest this year, certainly I would recommend going through this guide to know about which Best Vitamix blender are actually market leaders. More to follow ...
10 Best Vitamix Blender, see Reviews every single Vitamix Vitamix 5200, Vitamix 7500, Vitamix 5300, Vitamix 750, Vitamix 5000, Vitamix 6300 Vitamix 6500, Vitamix 780, Vitamix E310, Vitamix S55, Vitamix Professional Series 750,
Read more Vitamix Vs Other Brend Comparison Blendtec vs Vitamix, Vitamix vs Ninja, Vitamix vs Nutribullet.
Also See Comparison Vitamix 5200 vs 5300, Vitamix 5300 vs 7500, Vitamix 5200 vs 7500, Vitamix 7500 vs 750, Vitamix 6500 vs 7500, Vitamix 5300 vs 6500,
If you want to Read Best Blender Reviews you can visit The Electric Blender Website.
Where can I get a manual for the said Vitamix?
Go here to download it as a PDf file. The 5200 is what I think is most similar to yours.
https://www.vitamix.com/Owners-Resources/Product-Support/Owners-Manuals
What can I do about my Vita-Mix Blender which leaks at the bottom?
You will need a special wrench to remove blade assembly.
then the gasket/seal is inexpensive.
you can check here:
Contact Us Customer Service Vitamix
or check here:
Vitamix Wrench
Can you repack the blade bearing on Vitamix Blenders?
On the Vitamix blender models we have here in NZ it is not possible to repack the bearings, you just purchase a new blade assembly complete with bearings and the driving clutch.
I have a vitamix VM0109 and the spindle that the drive socket attaches to has sheered off, is it possible to replace it, if so where can i get the part from, whats the part number and where can i find...
Drive socket meaning the clutch drive on top of the motor? If the shaft that part fits onto has sheared off then prepare to empty your wallet because that is the motor.
2answers
I have a vitamix VM0109 and the part that the
check my viideo on vitamix sprocket repare https://youtu.be/Dq-kDO6H6N4?list=PLHtEamyrXElkiax86_fZYWR5UmgmevL2_
Vitamix TNC 60 oz container leaks when in use. how to replace seal and or bearings?
If it is not the HUGE blade retaining ring under the beaker a bit loose then you will be buying new parts to repair it. The only other possibilities are beaker cracked and leaking (new beaker) or bearings & seals worn (new blade & bearing assembly)
Vm0109 Vitamix
Your local Vitamix service agent will be able to order one in for you.
2helpful
The blade in my Super 5000 wet container turns very stiffly.Should I take it off and lubricate it? There also seems to be water visible under the bottom of the container.
Stiff or stuck blade problems can be fixed by replacing the two bearings and seal inside the blade assembly. Care must be taken in installing the new bearings as not to damage them. Ideally they should be pressed in, on a press, but they can carefully be tapped in using a sockets to match inner and outer races so your not tapping on the balls.
4answers
Vita-Mix 5000 blender shuts off under heavy blending loads.
first check the blades on the container thay should turn easy by hand if not thats your problem , you will need blades . blades turn easy ? you will need to replace the motor . the temp /overload has changed and is tripping to easy . this is common with people that use there vitamix for tough chores a lot . a lesser blender would just burn up a motor in a puff of smoke .a vitamix dies this way . in the end its the same you will need a motor
Top Vitamix Blenders Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
