Question about Panasonic PT-47WX49 47" Rear Projection Television
No power I have no power from Hot side. The power supply board is taken off from tv.When plug into a variac, power up, white wire(goes to fuse) measure normal. The black wire measured low(0.6v). TPD6 w.r.t. hot ground measured nothing.The only thing I've done is to de-solder Q801 becuase it diode tested abnormal in circuit.But tested correct out of circuit so I solder it back.What can be wrong? Thanks in advance.
  • 1 more comment
  • peter wong Jul 04, 2007
    Thanks for the reply.I just borrowed a service manual this afternoon so thanks for the offer.Is Q551 the horizontal output transistor? The one attached on the heatsink by the flyback?
  • peter wong Jul 09, 2007
    I reinstalled the SMPS to the tv.Checked the output transistor,it seemed ok. Did not check the rest of the components you mentioned as yet. But no B+ anywhere.Including TPD14 which should read 140v. I am thinking ,correct me if you will, that the problem might be in the hot side of the circuit.TPD6 should read 140 or so but nothing in there.
  • peter wong Jul 17, 2007
    When you say horizontal output transistor might be shorted I want to know what you mean by that and how do you test for that. I recalled that I loosed the screw on the heatsink and did a diode test on the transistor previously.I might have put it back incorrectly. "shorted"?
    I did checked the rest of the components as mentioned but find no readings.This is expected as pin14 of T801 reads no power.TPD6 is where power should goes into T801 but it reads no power.I can not check C830 as it is too big for my meter.
    Scholar:
  • 151 Answers
    President:
  • 3,130 Answers
Ypu will first have to check the horizontal output transistor and make sure it is not shorted. The voltage for the horizontal output transistor comes from pin14 of the SMPS transformer. Then it goes through the coil,L815, then to the diode for B+,D825. Then the B+ goes through coil L816. Be sure after D825 you check the capacitor, C830, as this is a very common fault with this set. Then the B+ flows through L817, then through two One ohm resistors, R857 and R858 to pin8 on the flyback transformer. If you get B+ on pin 8 of the Fly, and none on the horizontal output transistor, the fly is open and is bad. I have a schematic that is very close to this set but not an exact one, but most of these sets are about the same, and if you know anything about Panasonic TV sets, you should be able to repair them with a schematic from another set. BTW, this Horizontal and fly circuit is on the D board. If you wish to have a copy of the service manual for a set close to yours, I will send you a copy. If you follow these instructions, you should be able to find the fault with this TV set. If the SMPS is not working, you will not get any voltage also on the HOT. Good Luck
Posted on Jul 03, 2007
  • 5 more comments
  • Larry  Dillon
    Larry Dillon Jul 05, 2007
    Yes it is.
  • Larry  Dillon
    Larry Dillon Jul 09, 2007
    Did you follow the directions or did you fix it , amd what was the problem?
    I bet you found something I mentioned?
  • Larry  Dillon
    Follow the trouble shooting to the leter, and you should find where you lose the voltage. If you do not, you will not fix the set.
  • Larry  Dillon
    Larry Dillon Jul 15, 2007
    If you do not have the 140 volts, you have an open trace or the power supply is not working.
  • Larry  Dillon
    Larry Dillon Jul 17, 2007
    Do you get any voltage on pin 8 of the flyback? No check R857, and R858, no voltage there? Check L817 and L816, no voltage there? Check for voltage on D825, no voltage there?, your power supply is not running, check all components in SMPS.
  • Larry  Dillon
    Larry Dillon Sep 07, 2007
    Check for voltage on D825 like I said before.
  • Larry  Dillon
    Larry Dillon Sep 10, 2007
    Take out the horizontal output transistor and see if the 140 volts returns. If not, replace the regulator IC in the main SMPS, and check all the small diodes as well as the zener diodes on a high scale for leakage.
SOURCE:
60PN5000 LG turns off after about 3 mins. Power supply board?
Could be, but other boards can pull down a voltage too. To find this measure all the different voltages on the power supply board. If they are all present and correct then the problem is elsewhere. If you have a lower voltage, remove a wire connector going to another board and re measure the voltage. If the voltage returns to normal, then the board that that wire connector goes to is the problem. Do this again with each of the other connectors on the power supply board. If, after you have all the connectors removed and the voltages don't come back, then the power supply board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jul 28, 2017 | LG Televison & Video
What's the most likely problem with my 50" LG 50LN5100 LED LCD TV. The standby light illuminates when plugged-in but the screen doesn't come on nor is there any sound when the TV is turned on.
Thunderstorm over the coax or /and the power supply measure the power supply by a defect cannot be measured anymore over an analog hand adjustable power Variac transformer from 0 to 240 volt. because a protection can be given by a defect t-con board (as suggestion) but the variac its good to bypass/ overhaul the build-in safety protection circuit inside the power supply board then sometime if there else are broken or bad components hard to find they can be sometimes intentional burning out or become warmer by twist the variac power slowly up from of zero volt until the max necessary voltage T-con boards that can have a problem with smd components sometimes they can burning out the defects but its only to do if there is no equipment to measure repair or nothing was to find without a service manual or other optical defects , an short-circuit tuner also by thunderstorm sometimes only the little ceramic capacitors what hangs to earth (chassis) if the thunder energy was coming over the antenna coax cable. the power supply can stand in a safe protection mode. then a refurbished board somewhere can be necessary that will give a reset to release the protection mode in the power supply.. Thunderstorm can be strange and much different and i have had 2 times repairing when there was only 1 ceramic short-circuit ceramic capacitor to find thats was with one leg is( on cold-earth) on the chassis. as the one and only defect component. A time in a TV and 1 time in a radio , sometimes its realy strange but comes it over the power supply its hard to find because of more recurring complaints if partial repair in smd circuits. hard to do without necessary tools.
Jul 26, 2017 | LG Televison & Video
Getting 120 v to white plug where it first plugs into board should i have power reading at fuse?
yes after to the fuse you must have a reading of 120vac if none the fuse get busted. if the 120v is present then it will goes through the rectifier bridge diode and primary capacitor of the power supply board to have an stand by voltage at the power supply board. when you press the power button it will send signal voltage coming from the main board to turn on the power supply board. the you will need to get an output voltage at the power supply board of 5v dc, 12v-16vdc and 24v to turn on the all the circuit, the main board sound amplifier and the inverter board for screen back light.if you can get those supply the tv unit will not turn on.
Nov 09, 2012 | Vizio L37 Television
TV won't come on.
Is the red light on? Does it change to blue when you press the power button?
If the red light is lit, part of the power supply is working to provide the standby voltage. If it is not lit at all, check to make sure power cord from the mains power (wall outlet) cord is securly and fully inserted in the back of the set. If it still remains dark, the power supply is the primary suspect.
If no light, initially check the fuse, it is 5 Amps and a little smaller than a mini marshmallow. It is located on the right side of the board as you face the back of the set. It will be in the vicinity of the connector comming up from the power cord adapter. To test this, check other voltages as described below first, as the power supply board must be removed to get at the bottom leads of the fuse.
If the light simply remains red no matter what button is pushed, the power supply board is the first place to check for faults. If you have a voltmeter, unplug the set and remove the center plastic panel of the set, this reveals a metal plate, which is retained by three more screws along the bottom. The base can remain in place.
With that plate removed, use care when it is plugged in as there is lethal v voltage potential on the right side of the opening as you are facing the back of the set. There will be two boards, the one on top with the metal plates visible is the power supply. The lower board processes the inputs into video and audio components and is the "A&D board", These are important to know if you are buying them off of Ebay or other internet vendor.
With the set unplugged look for a mounted connector on the left side near the top where 2 sets of multiple wires come out of it and plug into a pair of connectors on the lower side of the power supply board (Black,red and another color) There are multiple red and multiple black wires- in the mounted connector, there is just enough room to insert a probe tip with a little bit of force, just enough to ensure the tip is in contact with the conductive connector in 1 each of the black; insert the black test lead from the meter, and the red test lead of the meter to one of the red in the larger mounted connector. The several red wires attach to the same copper pad on the power supply board so only one measurement needs to be taken to determine if power is available for the inverter board or boards. The black wires attach to one pad as well. With the meter set to it's highest DC voltage scale, plug the set back in and switch to lower scales as needed to ***** a avoltage measurement. see if you have a voltage in the area of 24 volts. If you do- check the fuse(s) on the inverter board or capacitors of same boards (depends on production run.
If you have 24 volts, the blue pilot lamp should be lit on the front. You can see on the face of the set if the tubes are lit or not. If you have 24 volts but no light- the fault is with the inverter or the CCFL tubes. The inverter should be pretty obvious if it is the issue because the capacitors will have bulging tops. The chip fuse for each section should checked for continuity If there is, the fuse is good. These require a high ripple current type of electrolytic capacitor. A general purpose type will not last in this location.
If the set has the CCFL's lit, but no response to an input signal, move the test leads carefully, or unplug set to move them to the corresponding red and black wires of the bundle that plug just above the paired sets that go to the inverters, the upper set has 3 red, 3 black, and 2 other colors on the connector. You should see a voltage measuring between the red and the black. If no voltage, or less than about 3 volts, the power supply board is at issue. If the voltage is greater than that, the A&D board is likely at fault, this is the board that is below the power supply board..
Dec 11, 2011 | Polaroid Televison & Video
Double image, top part bowed
This is an ITC 222 chassis and what happens is the flyback High Voltage transformer develops bad solder connections and blows a small fuse located next to it. To repair, first UNPLUG THE TV and after taking the back off the set look for the board that has the big red wire coming out of it and going toward the inside of the tv. The big red wire originates from the High Voltage transformer. Care has to be taken to remove the board which is clipped in by plastic tabs. Also remove plugs that hold the board back from turning the board upside down. Be careful with the two ribbons and remove and put back carefully. When you get the board turned upside down look at the connections at the bottom of the High Voltage transformer...they will appear to have rings around them which look like the solder it not connecting on some of the pins. After soldering the pins if you look just to the right of the transformer (looking at the component side) there will be a couple of small brown boxed shaped components. These are fuses. If you have an ohm meter and turn the board to the solder side again and measure continuity across each of these fuses and one of them could be open and not measure continuity. Since it would take a while to get a fuse like this I use a trick: I get an AC power cord and strip it back with my knife and get just one small strand of the copper wire and solder it over the bad fuse. I strand like this is about 5 amps. After doing all this put the board back in its place and plug up whatever you unplugged and turn the set on and the double image and bow should be gone. If not then you have a convergence power supply board bad which is directly above the board you fixed to the far left. But most of the time it is just as I mentioned: the solder connections and the fuse
May 21, 2011 | RCA HD52W59 HDTV Projection Television
I have a combination single pole switch. Light switch and receptacle. In have running in the old box 2 white, 2 black and a ground. How do I install the new switch to have power to the light switch and...
You are replacing old switch-receptacle device.
New device also has switch and receptacle.
You want switch to control light, but not receptacle.
You want receptacle 'hot' all the time.
You have 2 cables that enter box.
Each cable has white, black and ground wires.
Ground wires are twisted together and attached to green ground screws and not discussed more.
Screws on new device:
Side 1 of device: New device has dark screw(s) or brass screws on one side ... these screws are connected together by brass plate. This side is the Hot side of device.
Side 2 of device: Other side has 2 separate and unconnected screws. These screws are not connected in any way. Each of the 2 disconnected screws sits opposite the switch and opposite the plug.
Cables.
One cable comes from breaker box. This cable has a Hot and Neutral wire. The Hot is black. Neutral is white.
The other cable goes to Load (light). Black supplies power to Load (light), and white connects to Neutral.
If you are uncertain which is which, testing is shown below.
Connect the device:
Side 1 of device: Black Hot goes to dark colored screw(s) that are connected by brass plate. (This is only wire connected to this side of device)
Side 2 of device: Black that goes to Load (light) connects to screw that sits opposite the switch.
Side 2 of device: White Neutral connects to screw that sits opposite the plug
One wire is left .. the white from light. This white wire connects to white Neutral wire. Since white neutral is already connected to device, look on back of device to see if there is a quick-connect hole for you to shove wire into back of device. If device doesn't have quick-connect, then twist white wires together, and add a short jumper wire to device, and then all the whites are connected to neutral. Circuit is complete.
How to test for Hot and Neutral
Separate wires.
Turn on power.
Test each wire to bare ground.
Tester lights up on hot wire.
Now test hot wire to other wires.
Tester lights up on neutral
Nov 17, 2010 | Leviton COMBINATION SINGLE POLE TOGGLE...
Unit will not turn on.
CAREFULLY Measure the voltage on both sides of the fuse to make sure that the fuse is actually good.
No fix?
disconnect and reconnect the wires from the low voltage and control side of the power supply board.
No fix?
Throw it in the garbage.
Feb 24, 2009 | RCA DRC8320 DVD Recorder/VCR
Where to hook up com neg. lead to check dc volts on tv????
Most TVs today use a "hot-chassis" design and a switch-mode power supply. You should use an isolation transformer when doing any service work on a TV. This helps protect you and your test equipment, and can prevent accidental damage to the TV by grounding parts to the wrong point.
Hot-chassis sets use two different grounds. The power supplies have one ground reference for the primary side (hot ground) and a different point for the secondary (cold ground). The point you pick will depend on what part of the TV you're measuring.
If you are troubleshooting a dead set and working on the primary side of the power supply, use the negative lead of the large electrolytic capacitor you'll find near the AC input connection. There's almost always a bridge rectifier and filter cap (300 to 400 uF range, 180 to 250 volt rating, so physically pretty large) in that area to make the raw DC. That's a guaranteed good hot ground. Sometimes the set will have a labeled hot ground point right on the circuit board for you.
For measurements on the secondary (output) side of the supply, almost any shield can is ground. The tuner cover is a good choice.
Jan 29, 2009 | Sanyo DS25390 TV
Power supply
you are so lost... a short in anything after the power supply will shut down the horizontal driver signal. first check to see if horizontal output transitor is shorted. If not it should have about 110 volts dc on it. if not go back to Power suppy ...many things start here...check to see if you micros got power a 5v heatseeked regulater is common bad. also the startup circuits can be tricky...in the power suppy. I look for a kit online for power supplies ...they give you about every that fails. or you can start buying boards...best bet it is take to a professonal for you my freind havent a clue. CrazyLarry
Jun 27, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
104 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
