I purchased a washing machine, model: HV7F 140 P/G/A/K in June 2012, recently when washing on the cottons cycle (1) approx 30 mins into the cycle the machine will start beeping and flashing H2O on the display even though their is water in the machine and washes fine on every other cycle, i have tried restarting the cycle but the same thing happens, can you help please?
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    Its stops when it reaches in 39 minute the function set on cottons what is the problem
    Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    How long does it take in a full cycle of wash to dry
    Depends on several things. How big the drum is eg 6 kg or 7kg .the spin speed... The material ie. cotton drys faster than woollen items.is it a washer dryer or do you have a separate dryer.normal full load 6kg on a 1200 rpm spin of mixed fibres takes 1 hours 30 mins at 40 c then the dry time can take roughly 1 hour to 90 mins.
    Dec 23, 2014 | Washing Machines
    I start the wash cycle timer reads 1:02 machine runs and timer counts down to 54 mins. then resets to 1:12 mins. which inturn adds approx. 18-20 mins to wash cycle why the reset??
    I had a similar problem with ours and had a repair guy come out and look at it. He suggested running a couple of heavy bleach cycles through the machine. He said that sometimes if you use too much detergent (especially if you're not using the "High Efficiency" type of detergent) detergent builds up on a sensor in the machine and causes longer than necessary wash cycles. We actually ran 2 cycles of bleach and then a couple more with no bleach or detergent and the problem cleared up.
    May 02, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
    I have just purchased an 8KG Siemens front loader
    Time to call the selling dealer for warranty service.
    Aug 01, 2009 | Dryers
    Need instruction manaul for bosch wfl 2260
    Programmes appear to be taking excessively long time to complete even with the quick wash button pressed - 2 hour 15 min for 30 Cotton wash cycle. Is this right or is there a fault? 30 Easy-care seems to be taking almost as long.
    May 17, 2009 | Bosch Washing Machines
    Tank temp
    check to see if your element is scaled up or your element may be damaged
    Nov 21, 2008 | Hobart AM15T Dishwasher
    Bosch WFL 2872 washing machine has just started beeping (3 beeps) at approx 1 minute intervals at end of program until I turn machine off. washer is 3 years old & has never done this before - does it...
    A similar thing happened to mine. I think it starts when there is a power cut or something similar mid cycle. The solution (which you would never guess!) is the following:
    Select any programme - say 30 Cottons
    Press and hold any function button - NOT Start Signal will sound at varying levels - release button when it gets to the level that you want, off in your case. De-select programme Good luck!
    Jul 24, 2008 | Washing Machines
    Printed wash cycle info missing from front of machine
    Quick wash cycle for the Hotpoint FEW12 is 'K'
    A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
    B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
    C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
    D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
    E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
    F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
    G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
    H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
    H...(Wool mixtures with cotton or rayon.....2.5 kg)
    J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
    K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
    L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
    M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
    N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
    P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
    Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
    Hope this helps
    Sue
    Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
    Long wash times
    I've had this problem, particularly with towels - it's quite annoying & not energy or water efficient at all. According to the manual, the unit has a sensor that senses if there is too much soap & it will continue to wash until the soap is removed. I found that this happened frequently on the "cotton" cycles & max spin. I've tried to make sure I use less soap, but I also use the perm-a-press cycle & the spin 1 down from max. Hope this helps
    Sep 07, 2007 | Bosch WFMC 3200 Front Load Washer
    Washing time & quality
    Look for wash cycles in your users'manual. It is best the read the manual well before operation.
    Apr 05, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
    Washing Machines Logo
    37 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
