Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
BIOS Problem I have getting problem like. When i am Strat my computer I get some Massage Like " Serial ATA AHCI BIOS, Version UPSD Src 04-20-2007, ** This Version Support only Hard Disk and CDROM drives pleas wait. This will take few second."
You need to update your BIOS and reinstall the BIOS by using bootable this u simple search ur model of ur laptop then download ur new version of the bios that u have..
and set the boot process to CDrom OR If u use USB just click USB then it may takes 3 to 5 minutes
Posted on Jan 21, 2009
Acer aspire 5515 blue screen
hi
yes it may be related to bios setting . Just enter your bios in the laptop (F2)
and for HD change the SATA to ATA or vice-versa. SAVE and retry boot.
(it can also be AHCI to ATA or ATA to AHCI.)
Aug 12, 2012 | Acer Computers & Internet
Blue screen when installing os
If you are trying to install the Windows XP from scratch on the computer, please BE SURE that you put the Hard Drive on "Compatibility" mode in BIOS, which was defaulted to "AHCI" (Compatibility is also known as IDE).
Otherwise, you will experience the "blue screen" issue. To change that setting, you need to do the following:
1. Press F2 when booting up the computer
2. Select 'Config', then 'Serial ATA (SATA)'
3. Change controller option to 'Compatibility' / 'IDE'
Jun 21, 2011 | IBM NetVista PC Desktop
I have a HP Asterope Motherboard The Sata HDD or the Sata CD/DVD cannot in not detected in the BIOS and the computer can not boot-up When I use a IDE drive on the Ide port, It works But I have a...
Reasons a sata device might not be recognized in BIOS:
(1)Serial ATA disabled, enter bios and enable SATA.
(2)Serial ATA cable defective
(3)Serial ATA drive defective
(4)Serial ATA cable defective
(5)Serial ATA device not plugged into power.
(6)Serial ATA power adapter defective.
Feb 26, 2011 | Computers & Internet
I have replaced the HHD with a WD250 (Origional HD was damaged). Problem before and even now is... CANNOT install XP Pro. After a few mins, it brings up the BSOD and shuts down... Why, Whats wrong?
Difficult to say without any more information than that.
First of all, verify the hardware, the memory in particular, using a "burn in boot CD" (memtest86 supplies one, if memory serves).
If you get the OK there, it may be that LG E500 requires special AHCI drivers (many laptops do). To be able to install, you need to turn AHCI off in the BIOS, install the OS, then install the AHCI drivers, reboot and turn AHCI back on again.
Also, you may try a test install of a user-friendly Linux distribution such as OpenSuSE. In case of troubles even in Linux, which is probably a clue of some hardware issue, you may well find some hint in the /var/log/messages file, or directly in the system console (Fn-F10 or Ctrl-Alt-F10).
Jun 07, 2010 | LG E500 Express Dual Series Notebook PC
Error while trying to install windows xp Stop: 0x0000007B on a dell Optiplex sx270
The most popular Blue Screen of Death error in Windows is the STOP 0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could mean that there's a serious hardware problem with a hard drive controller, a driver issue, or even a boot sector virus.
In your case though, this is most likely one of 4 capacitors that are known to blow out on any SX270. Slide the bar at the back of your PC to the remove cover side and look inside for swollen caps. Remove the fans and cpu cover as well and check around there. Replace any bad ones you can find with old caps borrowed from an old motherboard if you have one, or new ones from any decent electronics parts warehouse. This fix has worked for me on every SX270 I have ever had.
Mar 10, 2010 | Dell OptiPlex SX270 PC Desktop
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
Motherboard has two built-in Sata connectors. after installing controller I can either use the onboard connectore or the controller but not both.
Check the BIOS settings. You may want to try AHCI settings or RAID settings and turn off LEGACY settings. The ports are controlled by the board itself, which is handled by the BIOS. So, the best place to start is there.
Oct 01, 2009 | Adaptec ASH-1205SA PCI 2 POrt Serial ATA...
Epox Ep-af550g mobo
If AHCI is not enabled by the motherboard and chipset, SATA controllers typically operate in "IDE emulation" mode which does not allow features of devices to be accessed if the ATA/IDE standard does not support them. Windows device drivers that are labeled as SATA are usually running in IDE emulation mode unless they explicitly state that they are AHCI. While the drivers included with Windows XP do not support AHCI, AHCI has been implemented by proprietary device drivers.[1] Windows Vista[2] and Linux with kernel version 2.6.19 onward[3] have native support for AHCI.
Jan 15, 2009 | Computers & Internet
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
149 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
