Question about Sumvision Audio Players & Recorders
I have just bought a cyclone primus V2 2T media player.my PC is not recognising it as a disc drive.any ideas?
ThaMp3Doctor
  • 8596 Answers
SOURCE: Pc not recognising my mp3 player
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 20, 2008
SOURCE: Samsung T10 Mp3 player to be recognised by pc
Heres how I solved this problem
- I was running XP SP2 with WMP10
(Windows Media Player 10)
- Windows will not recognise the T10 unless it has the right MTP (Media transfer Proticol) drivers. This is the little yellow flag you may see on the task bar adter Windows detects the device and trys to install the driver. The drivers are only found in WMP11. Therefore unless you are running WMP 11 your T10 won't sinc or be recognised.
- The Samsung software wont help- so don't bother even installing it as WMP11 has the drivers and does everything the Samsung software does + more.
- I tried to download and install WMP11 directly from the microsoft website but my PC failed the authentcation so I saved the file to my HD instead.
-I then unpacked the WMP11.exe file using WinRAR which i downloaded for free from http://www.download.com/WinRAR/3000-2250_4-10745708.html.
- I individually ran the WMP11 install file and then all of the other unpacked files by double clicking on them (it takes some time). This installed WMP 11
- I then shut down the PC, plugged in My T10 and WMP/windows recognised the T10!
I had a friend who alos did the above but had a couple of problems- he uninstalled WMP10, Installed WMP11 using the WinRAR method above and it didn't work. After uninstalling WMP11 and then reinstalling it again using the WinRAR to un pack it it finally worked after a couple of re boots.
Note: Prior to using the above method i googled and tried several other ways to get the T10 recognised and none worked. From what I can tell you Need WMP 11
Hope this helps
Posted on Nov 14, 2008
SOURCE: Sumvision Media Player not working with tv but ine with computer
Have you formatted it to Fat32?
Posted on Jan 26, 2009
  • 10 Answers
SOURCE: Problem accesing my Sumvision cyclone media player through my tv
Posted on Aug 12, 2009
  • 10 Answers
SOURCE: Sumvision Cyclone Media Player with Mac Computers
The sumvision cyclone media player is not compatible with Mac computers so you cant erase or reformat the player you will be able to put files on the player using windows xp or vista only
Posted on Aug 15, 2009
Sumvision cyclone mkv 2 enclosure will not conect to my computer the drivers are missing where can i get them from
From this and several other posts you made on this device (I assume you are the same Anonymous poster), it appears you do not have a formatted hard drive installed in the unit, or you didn't know the computer is treating it as an external drive (even if it calls it an "unknown" USB device. Your computer is looking for the file system in the enclosure. The directions for finding the unit from a Windows computer (written for the mkv, not the mkv 2, but they would probably work the same) are given in the review article linked below. Note: if you don't find any "Unallocated" disk, look in "My Computer" for a drive that isn't your internal hard drive or other usual device. Probably all you have to do is save your media files to this drive and they will be available to play on your A/V system.
Sumvision Cyclone MKV Primus 1080HD media player
Sep 21, 2013 | Sumvision Audio Players & Recorders
My ps3 120gb slim, does not recognise my multimedia hard drive, it a cyclone primus 2tb.
WOW Two whole terrabytes of memory!
The reason would be the size
The PS3's subway buses (USB) only have so much bandiwdth and the Ps3 can only read so much. It would have to breakdown over 2000 gb of data into sectors to read.
It is also possible that your harddrive isn't in the right format. Connect it to a computer and format it to FAT32
Thank you for your time, Good luck and I hope this works
Jun 08, 2011 | Sony Playstation 3 (PS3) Console
When trying to play a computer generated DVD +R DL, I get a message that says this type of disc cannont be played. please insert a different disc
The disc is probably an incompatible format for this model player. Even if the disc is finalised in your PC, or in a DVD recorder, this player may still be unable to read it. Some DVD recorder/players do not recognise DVD+R (or +R DL) media, while others won't recognise +/-RW discs (except CD-RW); this is a model limitation - not a fault with either your player, the PC burning software or the discs themselves.
Nothing can be done to fix this except purchasing a model which accepts multimedia (+R/DVD-RAM etc). The question is, does your player play ANY normal DVDs? I am guessing your player will accept DVD-R DL discs just fine since this is standard as well as proper shop-bought movies.
Feb 19, 2011 | Panasonic DVD-S35 DVD Player
Sumvision cyclone not working
i am having the same problem.
can anyone explain.
Power tries to turn on but fails to come up with screen that says HELLO.
It just flickers on for a second and then powers down straight away.
Apr 26, 2010 | Sumvision Sempra PRO Digital Media Player
Firmware for cyclone mmp
http://www.sumvision.com.cn/drivers.aspx Its the second one down where it says firmware when its downloaded extract it onto the hard drive make sure there isnt much files on the hard drive then connect to tv go to setup select firmware and press play to update.
Jun 16, 2009 | Sumvision Sempra PRO Digital Media Player
Barbie Girl mp3- application wont start up
Try restarting your PC once the software has been installed.
I bought one of these for my daughter for Christmas. I didn't bother installing the software that came with the player. Windows Media Player automatically recognised the device allowing me to transfer music to it.
Jan 07, 2009 | Mattel Barbie Girls MP3 Player
Goodmans GMP31G5 not recognised by XP PC
i have the same problem,but music can be deleted without using a computer
Aug 10, 2008 | Audio Players & Recorders
The dvd player is not working. I've tryed:-Updating online -refresh softwares online -updating Windows media player No efficient at all! No error messages.It's do not recognises even...
Have you tried other dvd's?? because you may just need the codec.
If your dvd drive doesn't recognise your dvd disks, you can try to update the drive's firmware (go to the manufacturers website to download). If this doesn't work i would say you need a new dvd drive.
May 24, 2008 | Computers & Internet
667 people viewed this question
Top Sumvision Audio Players & Recorders Experts
TO Lady
Paul Bade
Are you a Sumvision Audio Player and Recorder Expert? Answer questions, earn points and help others
