I have a keroheat cv 2230 ,i replace the wick but is not burning properli ?
My keroheat do not work good ,i have changed the wick but does not turn on correctly, what can I do,the flames are too small
anderza
  • 41 Answers
SOURCE: wick not burning properly and smells
You need to use pure kerosene do not use died or color kerosene it depletes the wick faster and causes a distinct odor. Pure kerosene should be clear.
Posted on Dec 19, 2009
Buffalo12980
  • 625 Answers
SOURCE: Dyna Glo 95-c flame height
check your air passages for a blockage. the wick just aids in burning your fire.
Posted on Nov 04, 2007
  • 883 Answers
SOURCE: wick trouble
yes,
the wick is held onto the moving mantle with pointed pins protruding from mantle. remove the mantle assembly and remove wick. then, if wick looks charred black on top, clean top of wick by trimming evenly all around with very sharp scissors; otherwise, use stiff brush... then assemble wick to a location that will be about 1/4 to 1/2 inch higher than when removed. may as well flush out kero tank before final assembly.
Posted on Jan 25, 2008
SOURCE: kerosene heater will not wick up fuel from tank properly
Have you checked the length of wick. May not be long enough to get down into fuel. RON
Posted on Jan 27, 2008
  • 77 Answers
SOURCE: Burning correctly
since the unit is new I would contact customer support at the we site or by calling phone number in owners manual.
Posted on Jan 22, 2010
Bought kerosene heater in middle of November and seem to have a wick issue. It will not burn properly and makes me wonder if wick was place in upside down. Can I fix it myself?
Trust me you can not install a wick upside down, the bottom of a wick is like an old mop. It has loose wove string and knots, it's job is to **** up fuel. Things to remember about wicks are, they need cleaned some times, I use an old tooth brush and gently brush the wick with it set down low so it does not get damaged. A wick must also sit and soak for at least a half hour before attempting to light it. A good practice to get in to is about every fourth tank of fuel let the heater burn out, this also cleans out the wick and burns off all of the impurities from dirty fuel. Yes you can check your wick but the entire heater does have to be tore down and you should do it only with an empty tank of fuel. This takes time , patience, and a little mechanical know how. When burning out a heater please remove it from your house and let it burn the smell is terrible, if you do this in your house it will smell like a semi truck is running in it.
Dec 28, 2010 | Heating & Cooling
My dynaglo kerosene heater will not continue to burn. It is full of fuel and will light but will not burn. what could be the problem?
Many things can cause this to happen and here are a few of the most common. The wick could be dirty, wicks should be brownish black in color, soft to the touch and flexible. Wicks will get hard and full of soot, my solution is to clean the wick with an old tooth brush gently brush it and I do this with the wick up about half way so I do not damage it. Then I take a shop vac and **** out all the stuff from the wick, make sure it still moves from high to low easily. Now soak the wick for roughly a half an hour and then light it. If the cleaning does not work you will have to change out the wick and remember that soaking the wick is the most important thing to getting good life out of it. Another practice is to burn out your heater each four to five tanks of fuel, this does stink bad so when you do this do it outside. Once you notice that you are about out of fuel take the heater out side and just let it burn out, this does clean the wicks on these heaters. Fill with K1 kerosene soak for the half hour with the wick completely turned down, then set to high and light it up. This cuts down on smell, helps it burn hotter,and in turn burns more efficiently.
Dec 26, 2010 | Heating & Cooling
WILL NOT START BURNING. REPLACED BATTERIES, GOOD SPARK. CLEANED. NO FIRE
When is the last time you cleaned your wick? A dirty wick will not light, wicks should be soft to the touch look burnt but not hard. Are you burning K1 kerosene? Other grades of kerosene have larger amounts of parafin in them this creates a crusty black hard carbon on the wick making it hard to light and also makes it smell like a semi truck running. I use an old tooth brush and clean the wick, let it set and soak for at least a half hour then try to light. Just a tip if you let your heater burn out every third tank this cleans your wick. Only burn it out in a well ventilated area as this stinks something bad never do this inside. Don't forget let the wick soak for at least a half hour. If your wick is over three years old replace it. Good luck hope this helps!
Dec 10, 2010 | Northern Tool 10,600 BTU Radiant Kerosene...
Need to know how to replace wick in heat mate HMHC 2230 AW25, would like a manual
Your search process and instructions process need a lot of work. This is a polite way of saying " " I'm just too polite to say this.
Jan 07, 2010 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Jan 02, 2010 | Dyna-Glo Heating & Cooling
Wick not burning properly and smells
Dec 16, 2009 | Heating & Cooling
Burns unevenly and smokes
try emptying your heater of fuel,and lighting it letting burn for several hours. This will burn all of the deposits off of the wick. Make sure your heater is outside when you do this. when done lower the wick,fill with fuel,and let the wick soak for fifteen minutes before lighting.If this doesn't work try brushing the top of the wick a light brush of some sort and light.If still no luck,change the wick.
Oct 01, 2008 | Corona 23-DK Compact Heater
Kerosene heater will not wick up fuel from tank properly
Jan 26, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
Heating & Cooling Logo
116 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
