Question about Vizio VO47L 47 in. LCD TV
Vizio speakers make a buzzing noise
Our Vizio speakers make noise the entire time the t.v. is on. What can we do to fix this problem?
VIZIO VX37L backgroud buzzing noise constatly (audio) increasing as volumne increasing. My knowlege is limited but tried looking at audo conttol setting,(nothing in which I could relate) also I found under advance picture adjustment DNS (noise reduction). it didn't seem to realate to aduio. If audio is fine and new speakers would cure all, I'd be a player. I have a Vizio 47. It also has buzzing noises. Both speakers. Have cable, but no HD cable box --- no box at all just direct hook up to wall.  I have an internet modem with a splitter for the cable but no direct connection to internet and TV.  Buzzing noise stays pretty much the same in volume even when you increase the volume.  I can't find anything in the audio set up to help out.  But seems to definitely be speakers as I turn them off on the audio set up the noise disappears. Of course then all sound turns off.
  • 3 more comments
  • siffony Feb 07, 2009
    i have the same problem but different tv.
  • Anonymous Feb 16, 2009
    Same issue different TV, except my buzzing subsides after about 10 minutes.
  • Anonymous Mar 14, 2009
    i just got my tv the other day and iv been going crazy to try to figure why its doing that....
  • Anonymous Mar 16, 2009
    I just got mine yesterday and the speakers are doing the exact same thing. Its a buzzing noise but when the volumes off the buzz is off. Does this happen often.
  • sky2walker Apr 05, 2009
    my problem started jsut after adding a HDTV dvd box. The volume is very low, hed to turn it up , way up in order to hear conversations. Then a buzzing noise started. Today, I have a clicking noise. The tv is only a few months old!
    New Friend:
  • 56 Answers
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Posted on Feb 17, 2009
2 Suggested Answers
  • 142 Answers
SOURCE: Vizio speakers make a buzzing noise
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
Posted on Apr 09, 2008
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
Vizio VX37L HDTV black rectangle in lower right corner
Turn off or modify CLOSED CAPTIONING settings
Audio buzzing
check where your pluging the red sounds like your pluging a video signal into an audio jack or your red cable ha an open ground
Dec 22, 2009 | Vizio L37 Television
My vizio 37 is buzzing from the back. not from
try to unplug some cables from the T.V like PS3/PS2/Xbox ect, or check your VCRs or DVD players cables by taking them off to see if the noise goes away. My crappy t.v makes a buzzing noise when i connect external speaker or VCRs or my PS3
Aug 25, 2009 | Vizio L37 Television
Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
Jun 02, 2009 | Vizio VX37L Television
Good Luck.
Mar 08, 2008 | Vizio L37 Television
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
Vizio VO47L 47 in. LCD TV Logo
2,476 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
