Question about Miele 5289391 - BOTTOM DOOR GASKET
HOW TO REPLACE MIELE DISHWASHER DOOR GASKETS - Miele 5289391 - BOTTOM DOOR GASKET
dragonsthatk
  • 547 Answers
SOURCE: Change miele dishwasher door seal
http://www.partstap.com/ please go to this site for diagram please rate me thank you for useing fixya
Posted on Feb 25, 2009
SOURCE: Obtaining Miele Dishwasher parts
Miele's US website lists a toll free call in # for parts under the customer service heading. I found them to be helpful and informed. See below:
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
Posted on Dec 24, 2009
SOURCE: Miele G858 Icognito replace bottom door seal...how to remove door
Kelly --
Since you wrote your question 13 months ago, I'm guessing the problem is solved. Still, for others experiencing the same issue, here's my answer.
We also experienced leaking on our Miele 858 Incognito dishwasher and were able to replace the bottom door seal (today) without removing the door.
First, call the Miele Parts Dept @ 800-999-1360 to place an order for the door seal, which is part #3920725.
Remove the defective seal by loosening the four screws at the bottom of the door. Pull the black rubber seal out and discard. Install the new part in the same spot (underneath the green flange). Tighten the screws and you'll be in business.
Posted on May 08, 2010
  • 177 Answers
SOURCE: the door on my miele G481 built in dishwasher won'...
hi,
what you need to do is slack off the spring tension on the door hinges. each side of the unit at the base on the plinth there is a screw with a spring symbol next to it. turn this anti clockwise to reduce the spring tension.
Hope this helps
Posted on May 24, 2010
  • 177 Answers
SOURCE: 23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
Posted on Jun 13, 2010
Door on my miele built in dishwasher is broken
First thing you need to do is SEARCH for "spares"
for your Miele G685sc
We don't seem to have "parts" for your G685sc here
in the USA...
but a casual look over BOSCH hinge and spring costs
show the hinge at $20 USD
AND
SPRING at $10 to $19 US Dollars...
Lower door gasket $20 to $30 USD
AT those prices I would attempt to avoid a "new"
dishwasher... When you are done trying to get a HEATER,
silence and stainless interior...
You are looking at BIG MONEY.
Check the FIT of the door... and health of the gasket(s)....
I'm just saying... I would
(it is the ULTIMATE in recycling).
http://www.appliancepartspros.com/bosch-dishwasher-gasket-seal.html
Apr 11, 2017 | Dishwashers
MIELE G646 Wonderful machine, but now 10 years old ! I noticed a small leak on the floor which appeared to be coming from the bottom of the door, on both sides. This was noticed after a programmed wash...
Clean gasket with clorox to remove any funk, and apply vasoline to gasket to improve seal. If you still have water leaking, you will need to replace the seal on the dishwasher. Should be able to order from an appliance parts dealer, or they may provide a univeral gasket that would fit your machine.
Jan 07, 2012 | Dishwashers
Can I purchase a new door for my Miele LaPerla dishwasher. The current door has 2 dents.
You certainly can replace them, one would require the model number La Perla G28XX (eg) as it also comes in assorted colours, downside is that its mostly only available from Miele or an agent.
Jun 18, 2011 | Miele Dishwashers
I need to replace the thin white door panel on a MIELE G832SC touchtronic turbothermic dishwasher
you want the replacement to be white as well? Check out ApplianceArt.com, they have over 200 different panel options including stainless steel, black, and white.
Nov 11, 2010 | Miele 24 in. G643Vi Plus Built-In...
Door has small leak. Needs new gasket around the door.
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Aug 20, 2010 | Miele 24 in. G865 Built-in Dishwasher
Bottom door gasket is caked with gunk of 1996 Miele dishwaher model G 880. Is this the gasket getting old and disintergrating, or is it just debris build up? Is it advisable to replace gasket on older...
This does sound like debris build up.You can try and clean it off but be careful you dont damage the rubber.If after cleaning it still looks pliable and does not leak then it will be ok.
Hope this helps.
May 16, 2010 | Dishwashers
Kelly --
Apr 03, 2009 | Miele Incognito G858SCVi Built-in...
Miele Touchtronic G892 SC Water leak at base of door
check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Dec 09, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Parts
You could buy a no name door seal gasket from any dishwasher parts supplier but you will loose your warranty with Miele. And extended warranties reach up to 6 years if you bought it from a factory authorzed dealer with a factory authorized installion! Call Miele direct. Miele's number is 1-800-843-7231
If you would rather call your local Miele dealer, they'll be more than happy to do help you!
Oct 13, 2007 | Miele 23 in. Novotronic G841 Built-In...
Miele 5289391 - BOTTOM DOOR GASKET Logo
130 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
