Question about Hoover CH50100 Insight Upright Vacuum,13 In.,10a,120v 11W085
Hoover ch50100 keeps shutting down
Vacuum keeps shutting down
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Hoover wind tunnel vacuum cleaner shuts off during use
Check the inlet down by the brush roll to make sure it isn't clogged. If not and the hose isn't clogged, then probably the thermo protector (part #28382093) maybe bad. It is mounted near the motor. Could be motor Part #43576188. But I would suspect a clog in the inlet or hose, or the thermo protector has gone bad.
Posted on Jan 22, 2008
IFIXALL
  • 868 Answers
SOURCE: hoover vacuume
Check the cord ,it may be loose at the wall.
Posted on Jun 24, 2008
SOURCE: Hoover Cyclonic Fusion Vacuum overheats and shuts off.
If it gets too hot it will shut down for about an hour...it does that to protect the motor. A lot of tools and work appliances seem to have that feature nowadays.
Posted on Mar 24, 2009
carlsbiz
  • 1124 Answers
SOURCE: Hoover Windtunnel shuts down after 15 minutes
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
Why is it my vacuum cleaner keeps shuting off after ten minutes. i have a Hoover wind tunnel uh70086
Sounds like it has an overheat problem and is shutting down to protect itself. Make sure the exhaust filter is clean and that there are no blockages. Hoover UH70086 WindTunnel Cyclonic Pet Rewind Plus Upright Vacuum Parts...
Sep 17, 2015 | Hoover Vacuums
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
Uh70600 hoover keeps shutting off
Most vacuums contain a high temperature circuit that will shut off the motor if it gets to hot. Thoroughly clean or replace all filters so the machine can "breathe" easier and stay cool.
Nov 20, 2013 | Hoover UH70600 WindTunnel Max Vacuum,...
I was vacuuming and my hoover vacuum died
they have a thermal shut off on the motor so if it gets too hot it shuts down
can take up o 30 min to reset check all filters make sure nothing is blocking
Aug 15, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Jan 09, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Hoover vacuume
Jun 24, 2008 | Hoover U8147-900 WindTunnel V2 Bagless...
Hoover Sensory 2200W Overheating and Shut-Down
Did you ever get to the bottom of your overheating and shut-down problem? Just got the same problem :(
regards,
Mar 31, 2008 | Hoover Vacuums
U5180-910 vacuum shuts off on own
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Nov 18, 2007 | Hoover U5180-900 Vacuum
Vacuum shuts off
It sounds like the hose from the bottom part is plugged. The motor has a high temperature protection that will shut the motor off if it overheats but will come back on once it cools. The motor will overheat if any restriction of airflow occurs. If the overload sensor reacts too many times, it will eventuall start to shut off before it should, so you should address the problem asap. Check the area behind the roller and the hose leading up to the connection to the attachment hose for blockage. Also, make sure you are not setting the machine height adjust too low. This will make the bottom plate sit down too close and cause a restriction in air flow to the motor.
Nov 17, 2007 | Hoover U5753-900 WindTunnel Bagless...
Hoover CH50100 Insight Upright Vacuum,13 In.,10a,120v 11W085 Logo
70 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
