Question about Miele Washing Machines
Miele washing machine w1714 displays technical fault F64
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: 'washing machine miele w1714 lock on Message demo programme how i do unlock?
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
Posted on Nov 04, 2012
Miele washing machine W3725 is coming up with Technical fault F51 ?
F51: Pressure Sensor
Symptom
In the operating mode, the display indicates Technical fault.
The program is stopped, the water intake valve is closed, and the drain pump is
switched on for 120 seconds.
Cause
Electrical defect in analog pressure sensor (ADS). The values are out of range.
x
Note
The pressure sensor is integrated into the power/program electronic (ELP)
This will usually require a professional to repair.
Dec 10, 2016 | Miele Washing Machines
How do I fix a Miele W 2653 Wasker.
Hi dear. You did not mention what fault code but regards rest of your information, I would say 3 factors play up with it.
1- Tacho generator or it's plug faulty on motor
2- Motor Carbon brushes worn out or
3- Power/control unit ELP151-KD faulty.
I can advised to contact your local Miele center to diagnose your machine.Thanks.
Mar 17, 2016 | Miele Washing Machines
Start button light flashing will not start
Hi dear.
You need to contact Miele to assist your machine repair. Description as blow. Thanks.
Start LED flashes rapidly
The drain pump (M8) is activated, level-controlled, for up to 1 h.The buzzer sounds intermittently for 2 min irrespective of its setting.Digital display: - - -
Cause
Technical fault.
Feb 01, 2016 | Miele Washing Machines
Model pw6065. Why is 'technical fault' displayed?
Hi dear. Machine display that message because,there is a problem with machine's components - drive system etc.. Which is not rectified by user. (You can check the fluff filter but you can not test the motor or electronic board.)You need to get professional help from Miele for proper diagnose and solution for it. Thanks.
Jan 30, 2016 | Miele Washing Machines
Restart the program.
If the fault message
appears again contact
Technical Service.
Jan 08, 2014 | Miele Washing Machines
- Close the door.
Note
10 seconds.
Accessing
the On/Off Button.
LED turns off.
Deactivation
Note
Nov 04, 2012 | Washing Machines
My Miele 1374 washing machine just had a fehler f63 error. What does this mean and is it fixable?
heres your problem..
3.33 Fault code F63, water path control unit In normal operation mode the display shows Technical fault. The Check inlet LED flashes rapidly. The programme is interrupted. The drain pump is activated for 120 s. Cause Water path control system faulty. The power-programme module (ELP) cannot register a valid position of the water path control unit within approx. 80 s of it being switched on.
Note: Water intake monitoring is not active if a valid position of the water path control unit cannot be registered.
Remedy Check the water path control system. tool1.gif?leaf=true Check the water path control system circuit for an open or short circuit, and correct insulation.
Jun 05, 2011 | Miele W 4800 Front Load Washer
How do I fix a F53 fault ona Miele W1712 Washing Machine
A call with the Miele tech helpdesk got me an answer: The tacho unit (coil) should have about 500 Ohm resistance, so they told me. My unit only had about 78 Ohm's, so I ordered a new brush unit (which includes the tacho). The new unit actually measures 250 Ohm, but since it was a new one I did fit it. It works like a charm again. No F53 fault code anymore.
The part no. is 6799642 - Module BSTV Mrt40 RK473. It cost me about 70 euro's including shipping. My machine is a type W3821, but the motor and brush unit with tacho is used on a variaty of models.
Cheers!
May 01, 2011 | Miele W1926A Front Load Washer
Miele w1113 alarm buzzer
do you have 3 dashes across the dispaly?? you need to get into service mode to access the fault
Aug 17, 2008 | Miele Touchtronic W1113 Washing Machine
Washing Machines Logo
121 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
