Question about Compaq Presario 700 470024-192 Notebook
Compaq presario c700 keyboard mulfunction
My keyboard keys are not working properly , when i press for small letter but it typed capital letter though my cap lock is off.
some other disturbance are there.
    Problem Solver:
  • 10 Answers
First U Uninstall your Keyboar driver if U install on your computer.
Restart it.
Posted on Jan 21, 2009
  • 184 Answers
There are 2 common problems for this.
1. Something got stuck under the keyboard of your laptop. Food scraps or Dirt and Grime build-up due to sweaty palms or fingers clean the keyboard.
2.The Membrane on your keyboard that act as a switch cold be shorted due to wear and tear or heavy key presses. Have your keyboard replaced.
Other problems could be cracked board if you happen to lean or put heavy stuff over the keyboard and cracked ribbon connector.
Caps are on all the time
Press the
"caps lock" key once to take it off capital letters. If that doesn't work, get an external keyboard and plug it in and try it. That should do it.
Apr 08, 2014 | Compaq Presario CQ56-115DX Laptop
Keys not working
Either the keyboard or the ribbon cable connecting the keyboard to the mainboard is damaged or not fully connected.
The most likely problem is the keyboard is defective. They are not very hard to replace. In most cases you have to remove the button cover above the keyboard and then the screws for the keyboard will be accessible. You can get a new keyboard off the Internet (EBAY or such) or direct from HP.
Aug 22, 2012 | Compaq Presario CQ62-112TU
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
Keys on keyboard not working properly
Go to control panel, regional and language settings, ensure that the correct keyboard is selected (A UK keyboard and USA English selected or a USA keyboard with UK English selected is often a cause)
Feb 24, 2010 | Compaq Presario C700T Notebook
My C700 laptop built in keypad doesnt work properly. Other letters generate when i press a certain keypad. For example when i press the letter "m" the number "0" comes out. I suspect the problem started...
open a word processing program and type the word jump, if it types 140* locate and press the function key and numlock key(FN + NUMLOCK) type the word jump again,that should solve the problem.
Feb 21, 2010 | HP Compaq Presario C700T
Letters are num locked. pushing num lock key does not resolve
Number lock, a situation where numbers instead of letters are typed is as a result of the digital lock being active. to deactivate pressing the Fn+Numlk or Fn + Shift +Numlk key combinatioins
Jun 18, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Compaq Presario C700 numbers showing up instead of letters
Either address your "Num Lock" Key keyboard or your "Fn" Key on your keyboard. Either of these, or a combination of both should solve the issue.
Please let us know if you need anything else.
Apr 25, 2009 | Compaq Presario 700 470024-192 Notebook
Keyboard functions are not worki g properly
have you tried a new Keyboard? Or pop off the shift keys and give it a good cleaning
Sep 10, 2008 | HP Compaq Evo Notebook N600c
Compaq laptop keyboard mulfunction
try having your laptop checked by a competent technician... there might be an obstruction in your keyboard (like dust) which causes the key to stuck and have it cleaned
Aug 09, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Compaq Presario 700 470024-192 Notebook Logo
215 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
