Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Thin line across the screen
My older television (19 inch Broksonic) had started taking a long time to come on. Now it only has a thin line across the screen. It's as if someone painted the screen black, then took there finger and ran it horizontally across the screen. It still has audio.
  • 4,234 Answers
I'm guessing that this is a CRT based TV, not an LCD. That being said, the problem is a failure of the vertical circuit. Usually this is a small flat IC (LA7837 or similar). Try resoldering the pins if you can first. If that fails to resolve the problem, replace the IC. Please be aware that there are potentially dangerous high voltages present even when unplugged.
Keep us posted.
Dan
Posted on Jan 21, 2009
  • wendiejk
    wendiejk Apr 06, 2012
    This happened to an older TV of mine. I cannot tell you how to fix it internally, only what I did to make mine work. It had something to do with the bottom front of the TV. I took a deck of cards and placed it under the front of the TV. I had to adjust until the picture became clear. This worked for a year and a half.
Thin vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Samsung Televison & Video
Why does my SAMSUNG PLASMA have thin black line? horizontal line How to fix?
Sustain board fault. Contact any service technician. This is not a user repairable fault.
Aug 02, 2014 | Samsung PN64D7000 3D Plasma TV
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
My toshiba 55pd8800ta now has horizontal lines of picture across the whole screen. The picture and menu are out of sinc. Help!
These lines are called vertical retrace lines. Thin white lines are seen across all over the screen, at about an inch apart. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. One among the posts has details about this fault.
Apr 05, 2013 | Televison & Video
My tv sony kv-xa21m61 display too bright and many horizontal lines. no picture
Vertical retrace lines is the problem. Thin white lines runs across the entire screen, at about an inch apart to each other. Check its video output supply voltage. Reduce the screen voltage to a little bit down and check. If you still wish to know more about this fault, check this site. Pull up older posts there.
Feb 09, 2013 | Sony KV-XA21M61 21" TV
No audio and have a thin white verticle line across tv
Always suspect a bad EEprom...very common on this TV! See a tech, he will have to select one of six eeproms to fix this!
Jan 10, 2010 | Philips Magnavox 27MS343S 27" TV
Screen is black with a thin horizontal line
Change the vertical IC and check the electrolitic capacitors near them
Aug 28, 2009 | Televison & Video
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
458 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
