Question about Dyson Vacuums
Dyson dc04 pluged in but no power i have changed the fuse on plug stil not going
I have dyson 04 but stopped working for no reason
Agent Don
  • 310 Answers
SOURCE: brushes not going round
The brushes on my dyson have stopped going round. I have checked it and they move freely by hand. The belt is intact. What could the problem be? The Hoover is about 10 to 12 years old.
My dyson is a dc04
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
One of the main problems with vacuums are that the flat belts on the vacuums stretch and should be changed every 4 to 6 months or 3 or 4 times a year – you can tell by taking off the belt or belts on the vacuums and compare them to the old belts on the vacuum the new belts will fix inside of the old belts and you will be able to see the difference on how much they have stretched – if the belt is a geared belt – they stretch as well but should be changed about one a year – the cost is not that expensive and you cleaning will improve almost double – this also applies for the Dyson DC04 and the Hoover vacuum as well – some of the Hoover vacuums have two (2) belts and they both should be changed @ the same time.
Posted on Apr 15, 2008
grandadfixer
  • 99 Answers
SOURCE: why does my dyson dc04
thermal cut out in coils of motor,you have not been keeping filers clea,I THINK.
motor is avaliable
Posted on Oct 11, 2008
  • 55 Answers
SOURCE: Dyson dc04 motor runs but has no suction.
I would make sure it is the motor first by isolating the sounds to just the motor. Take off the dirt cup, both filters, and belt, then run it and see if the sound is still there. If it is, you need a new motor. If it isn't, you need to look for a clog, or bad roller bearing.
To take the motor out first undo the wiring running down the backside of the unit inside of the switch housing. Then take the four screws out that hold the outer motor housing on, and the rest pops apart. Once you get inside, the gaskets make it a really tight fit, so you might have to hit the motor shaft with a rubber mallet to get it out and use penetrating oil on the bottom gasket to get the new motor to slide back in.
I guess there is no easy explanation. Let me know how it goes.
Posted on Dec 01, 2008
rustysheriff
  • 344 Answers
SOURCE: Dyson DC04 not working
Have you trod on the cable at all, sometimes the cable breaks inside the sheathing, test by switching on and wiggling cable where it enters machine, if it starts then thats your problem, easy to fix, disassemble switch, cut off and discard 6 inches of cable then reattach the reamaining.
Posted on May 29, 2009
Samyfam
  • 378 Answers
SOURCE: How do I dismantle my dyson dc04
http://www.dysonmedic.com/DC04%20Folder/DC04%20Cable.html
Posted on Nov 23, 2009
Dyson dc04
Hi there, it's Jack at Dyson.
Like most Dyson vacuums, DC04 is equipped with a thermal cutout, which will shut the vacuum off for protection if it starts to overheat. This could be due to a blockage - the pre-filter may also need a wash. It should automatically reset after it's had at least 2 hours to cool down. You can prevent this from reoccurring following the steps below.
To wash the pre-filter, use cold water without detergent, as shown in the video below. Allow at least 12 hours for both parts of the filter to dry completely before replacing it.
To check the vacuum for blockages, just follow the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc04/dc04-standard/my-machine-is-not-working/machine-won-t-switch-on-or-cuts-out/machine-won-t-switch-on-or-cuts-out/my-machine-cut-out-whilst-i-was-using-it/how-to-wash-filters/machine-not-sucking-picking-up-as-well-as-usual-dc04/wand-suction
If you'd like further advice after giving these checks a try, please give our experts a call directly on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
Jul 29, 2014 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Dyson dc04 my dyson dc04 wont turn on at all, it was working yesturday and now its just not switching on please can anyone help?
Follow the power from the plug to the switch through the vacuum until you reach the motor. Somewhere along the path you will likely find the problem. The most common problem is the cord or switch.
Mar 05, 2014 | Vacuums
Dyson DC 04 has just switched itself off! is this normal? has it just overheated or is there a fuse to change?
Hi Andrew,
I'm sorry to hear you're having difficulties with your DC04. If the machine shut itself off during use, it sounds as if it may have overheated due to a blockage - the filter may also need a wash.
To locate and remove any blockages, please follow the steps shown in our online Support guide:
http://support.dyson.co.uk/support/dc04/dc04-brush-control/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/wand-suction
In normal use, the filter needs to be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely somewhere warm before replacing it.
This should resolve the issue, but if you'd like any further assistance or advice, please call us on 0800 298 0298 - our Helpline is available from 7am until 10pm, 7 days a week.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 17, 2012 | Dyson DC05 Cylinder Bagless Canister...
Dc04 does not power up!
I need a directional manual for dyson animal
Sep 20, 2009 | Vacuums
May 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson dc 04
Hi.
Which machine have you got Dc04 or Dc05 ?
Jul 01, 2008 | Dyson DC05 Cylinder Bagless Canister...
Brushes not going round
My dyson is a dc04
Apr 15, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
24 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
