Question about Panasonic PT-51HX41 51" Rear Projection Television
Replace IC Convergance chip in Panasonic PT-56HX41PF
I'm trying to replace the convergence chips in my Panasonic PT-56HX41PF, I need to take the board itself out to sauder the chips into place. There is a four white connector that is holding the two boards together, I do not want to force them out, they may break. Has anyone done this, if so can you please help?
  • John Nelson
    John Nelson Dec 31, 2011
    Dave I have same problem with these connectors. Did you manage to get them undone? I also have a problem taking the anode wire out of the FTB.
  • Adriano Nascimento
    Adriano Nascimento Jul 18, 2014
    stk392-110 ou stk392-150 ,,,,,e se sentir free
Enter the tip of a pointed knife between the left side edges of the connector (circled in black in the attached pic) and gently tilt the knife away from the connector. Do the same on the right side. The connector should pop up.
Posted on Jan 22, 2009
Panasonic (PT-56HX41PF) rear-projection tv with no picture
The three blinks indicates a convergence IC fault. The convergence ICs must be replaced with the manufacturer replacement part. Use only the original replacement part. Your set uses STK392-110 convergence ICs.
These ICs are mounted on a large heat sink. Yes, you can replace it yourself and save few hundred bucks. But you must be knowledgeable enough on how to solder, resolder and use a multimeter.
You will need:
  1. Convergence ICs
  2. Heat sink grease or thermal compound
  3. Soldering iron
  4. Solder lead.
  5. Digital multimeter
  6. Solder pump
  7. Small side cutter
Feel free to inform me if you decide to replace the ICs yourself
Dec 03, 2009 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic PT-47WX53 has intermittant convergance issue
I would chack the solder connections at the convergence ICs first. Since the set "recovers" on its own, it suggests a connection issue rather than a defective component. Also, if the ICs were installed without sufficient heat sink compound, this could happen as well. Look at low valued resistors in the area of the ICs for signs of overheating as well.
Keep us posted on your progress.
Dan
Oct 19, 2009 | Panasonic Televison & Video
I have a PT51HX41C. The convergance is not working, and everything seems like 3D without the glasses. IC chips? How many? Where? Part number? Thanks in advance.
Ur tv nane and model,the convergence IC chips will be in that kit.U know how to solder right?Tries these websites.Tv Repair World.com or Ebay.com.
Sep 29, 2009 | Panasonic PT-51HX41 51" Rear Projection...
If you are talking about removing old ICs use a cap of Alcohol to pour on top to loosen. Or use needle nose plyers to pull from hole on top side of ic s.
Aug 21, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic pt-47wx42f
Yes you can get replacement IC STK392-110 convergence ICs at the following link and they provide free instalation instructions with pictures. The Ics are located on the board on the left side attached to a large heatsink. You will need to replace both ICs heres the link.
http://servicemanuals.vstore.ca/
May 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Convergance chip
Thats the regulator chip for the convergence circuits thats the one youre most likely needing, as your chassis doesnt have convergence ICs. You can get that IC at the following link and they will provide free installation instructions and free on line tech support just in case you need assistance. Here is the link.
Apr 23, 2008 | GE 46GW947 46" Rear Projection Television
Repeated chip failure
are the resisters ok?
i might suggest sending the board into ptscorp.com
Feb 04, 2008 | Zenith Z60Z83R 60" Rear Projection...
Need part # for convergance IC chips
they should be stk392-110. if you look in your set they are located on the left side of the chassis on the huge heatsink. you can get the numbers off the ics its big enough to see. you can get them at the following link for about 9.00
http://www.yahoo.com/
Dec 28, 2007 | Panasonic PT-47WX51 47" Rear Projection...
IC Convergence on a Panasonic PT-51HX43
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Sep 19, 2007 | Panasonic PT-51HX43 51" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
390 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
