Airwell air / con model GC24RCC/S HOW TO OPERATE CONTROLLER
2 Suggested Answers
NiHaoAirwell
  • 7 Answers
SOURCE: We have just purchased a universal remote for our
Airwell remote controls (RC) are not coded (so not listed) for universal use.
The only way of using a universal remote control is to learn the new RC by sending the commands piece by piece with a original Airwell RC.
Posted on Aug 10, 2010
I have a airwell con and it won't stay on it comes on and off I'm trying to get it to stay on cold
some types of AC have a filter. It's possible the filter is to replace. An other possibility is a defective thermostat, also to replace.
Oct 19, 2014 | Heating & Cooling
Living in Burlinjgton Ontario Canada. Looking for owners manual. How can I get one?
Henry, unfortunately Fedders as you knew them is now out of business, A company by the name or Airwell bought parts and manufacturing and it's now call Airwell-Fedders. You particular model is no longer available. However, if you contact Airwell-Fedders Customer Service 866-829-2440 or email them customerservice@airwell-fedders.com they should be able to help you with the manual.
Good luck. I hope this helped you.
May 24, 2011 | Fedders SFPEB08F2B Air Conditioner
I got an Airwell ducted air conditioner unit with 4 outlet model: GC24RCC-S and Remove controller 4 and PCB unit is Storm 2. When turned on, the green operation led of the display controller unit is...
Check the unit that's located outside .You need to open it to get to the control board ,there you will see a couple of buss fuses. Check to see if fuses are fine. Do this with the power OFF on disconnect
May 19, 2017 | Heating & Cooling
We have just purchased a universal remote for our ducted airwell air con - we need a code for it and airwell isnt listed on the remote
I am sorry if ask wha may seem like a few silly questions, but I need some clarification to assist you better.
-Is this a Residential AC Unit?
-If it is a residential AC unit, where is the thermostat located for this unit?
-Do you know if there is a wall mounted thermistor located on the wall in another room or in the room it cools?
I ask these questions, because generally if the fan coil is mounted in the ductwork, then there isn't always a way of controlling it remotely. Generally, it's controlled by hard-wired thermostat.
If you know it was controlled remotely, then you will need to go the website for the Airwell Fan coil and do a search on programming the remote. I'm sorry there is no short cut for this, you will need to obtain the code from Airwell.
Hope this helped... :D
Jun 27, 2010 | Heating & Cooling
I need to know where i can get a manual on how to set the remote controll for the air conditioner. right now we are turn them on and off every day or when it gets to hot or to cold. i would like to set...
If its for the unit pictured go to http://service.airwell.com.au/airwellsanyoparts/Website%202007%20update/airwell/XV26RCA/ and click on operation instructions.doc. Even though this is an airwell manual, they both use the same control.
Hope this helps
Mat
Jul 15, 2009 | Sanyo 18KHS72 Air Conditioner
Where do I get filters for my Airwell Airconditioner?
take down the dimensions of the air filter. like 16" wide x 20" long x 1" thick. the go to your local hardware store. or lowes, home depot hope this helps.
Jun 13, 2009 | Heating & Cooling
Have purchased premises with a sanyo sap-k302ah split system air conditioner and the previous tenant cannot locate instruction book on how to operate can you help me out with one please Maxine
There you go
http://service.airwell.com.au/airwellsanyoparts/Website 2007 update/sanyo/SAP-C302AH/sm700568-00_11 service manual.pdf
If you cannot veiw please let me know and i will re post the link or email it to you
thanks for using fixya
Apr 22, 2009 | Heating & Cooling
My fujitsu inverter does not cool below 18deg C
Heya Mark,
Fujitsu air cons are factory set at 18degs you cannot change it without going through all the controller programs. Normally air cons are serpose to run around the 20deg point, is the air con not running effectually or do you just really like it cold.
I could check with tech help and see if I can send you the derictions of changing the minimum set point but it will not be good in the long run for your unit
Jan 07, 2009 | Fujitsu 36CS Air Conditioner
No Display on controller
Try replacing the battery but if it wont work you need to replace the remote control itself, but for the main time you can operate the unit by pressing the emergency switch button to operate the unit manually.
Jan 09, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
