Question about GE WDRR2500K Washer
How do i remove hose from clothes washer
Hose is cracked and needs to be replaced...cannot figure out how to remove it from the washer
5 Suggested Answers
  • 152 Answers
SOURCE: My Ge washer keep leaking at the drain hose where
I would replace both pieces WH41x10096 and WH41x374.
Posted on Feb 28, 2010
heatman101
  • 43501 Answers
SOURCE: My washer will not rise
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on May 11, 2011
  • 6277 Answers
SOURCE: Washer is flooding the floor
FixYa is sorry but this Forum does not normally supply parts, part numbers, prices or other details direct; it's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web. Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained on many makes and models, probably over many years ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Sep 01, 2011
SOURCE: Washer is not draining properly - clothes are soaking wet. Took hose off back and ran water thru - no clogs.
it could be your pump take the hose off and clean it out
Posted on Aug 12, 2012
The black hose that drains the water out has come off and draining water straight out as it fills. I cannot for the life of me figure out where it connects to. Any help would be great!
The black discharge hose (the J shaped one) is connected to the output side of the discharge pump inside the washer. It's likely the hose has come off.
  • first, unplug the washer.
  • Shut off the hot and cold water faucets to the washer.
  • Pull the washer away so you have access to the back.
  • Remove screws holding the back panel in place.
  • Remove panel.
  • Examine the hose where it attaches to the pump. Look for cracks, holes or broken ends.
  • Examine the clamp attaching the hose. Is it broken or worn?
  • Replace any of the above hoses and/or clamps if faulty with hardware comparable with your model. Re-assemble in reverse sequence of dis-assembly.
  • Attach hot/cold water lines.
  • Ensure ALL excess water has been removed before plugging washer in. Ensure ground wire is attached!
  • Plug washer in and start cycle. Examine for leaks.
Feb 01, 2016 | Washing Machines
Tip
The washing machine leaks during both drain and spin cycle?
The most common possibility for this problem is as follows:-- Check the drain pump.if it looks loose then it needs to be refitted.if the drain pump looks bit worn out or cracked then it needs to be replaced.but if the drain pump check out OK.then its the fault of drain hose .Remove the hoses connected to both ends the pump.The hoses are cracked and it needs replacement. But if the pump is clean and clear and hoses are also seen clean then the other part to check is outer tub part, for that you will need to open the washer's main access panel and remove the rubber material hose connecting the pump .the hose is exactly connected to the bottom area of the outer tub. If you notice any blockage/clogging in that area you can remove it with the help of pliers.
If you are not able to remove the clog or if you can see but its seen in very inner area then you need to take the agitator out, after removing the agitator remove the top of the outer drum shield, and inner clothes tub. You will require some special tools to do the job in this case.
This will help.Thanks.
on Mar 18, 2010 | Washing Machines
Why won't my Maytag washer A48t drain? Replaced belts when it also wouldn't spin. Now it spins, but does not drain.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed. Also check drain hose.
Apr 24, 2014 | Whirlpool Washing Machines
Electrolux dishwasher won't drain. Not a clog in the outlet hose or drain pipe.
The drain hose on a washing machinemag-glass_10x10.gif connects the drain pump to a stand pipe, a U-pipe under the sink, or another place for draining dirty water into the sewer. If your washer won't drain properly, the problem is sometimes an object blocking the drain hose, like a pair of underpants, a child's sock, or pieces of something that broke up in the washer.
  1. Unplug the washer and put the plug on top of the machine to keep it out of any spilled water.
  2. Step 2 Take any wet clothes out of the washer and bail the water out of the drum with the bucket. The washer may be too heavy to move if it's full of water and wet clothing.
  3. Step 3 Pull the washer out from the wall enough for you to get behind it.
  4. Step 4 Remove the plate from the back of the washer by taking out all the screws. Different brands and models of washers vary in how many screws hold on the back plate, and not all models require removing the plate to get to the pump where the hose is attached.
  5. Step 5 Locate the drain hose. Of the three hoses coming out of the back of the washer, the drain hose is the largest in diameter and is attached to a drain pipe instead of a faucet.
  6. Step 6 Check the drain hose for kinks and bends. These are often the cause of a blocked or slow-running drain hose.
  7. Step 7 Remove the drain hose from the washer by detaching it from the drain pump. You will need a screwdriver or a slide-lock wrench to open the clasp that holds the hose to the pump, depending on what type of clasp it is.
  8. Step 8 Keep the bucket nearby to catch any water that comes out of the drain pump when you remove the hose.
  9. Step 9 Remove the other end of the house from the pipe it drains into.
  10. Step 10 Bend the clothes hanger open so you can use it to poke inside the hose. Push or pull out the material that's causing the blockage.
  11. Step 11 Replace the hose and run the washer to check if it's clear.
Nov 13, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Water will not drain. The hose is not bend.
If your washer won't drain, check these:
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
t doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Regards
PCmania
Sep 26, 2009 | LG WM1814CW Front Load Washer
FTW445ges2 Washer won't drain, buzzes during drain cycle
Hi...
You need to check this parts.
Inspect the drain hose for kinks
Test the timer control
Test the lid switch(some models)
Inspect the water pump
Inspect the driver belt(belt drive only)
Inspect the motor coupler
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Hope it will help you.
Regards
ICmanServer
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer is full of water and wont drain or spin
hi friend,
hoses
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Dec 03, 2008 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washer not draining water
It won't drain If your washer won't drain, check these:
May 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Replacing drainage hose
You need to remove the two screws that hold the front panel in place. Remove the hose from the drain pump and pull it out through the back of the machine. You will need to release the clip that holds the hose in place where it exits the back of the washer. Important. When installing the new hose, ensure that you put it back in the clamps inside the machine or it will get caught in the pulley.
Oct 27, 2007 | Amana ALW480DA Top Load Washer
GE WDRR2500K Washer Logo
13 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
