How do i disconnect my HBH PV703 Headset from a damaged phone and connect it to another Phone
  • 34 Answers
Step 1 - To reset your Bluetooth headset:
  1. Press and hold down the volume keys "+" and "-" on your headset at the same time, until your hear a beep and the light flashes red and green alternately.
  2. Press and hold down the volume keys on your headset until it is turned off. The headset is now reset as it was when purchased.
Step 2 - To pair the headset with your phone:
  1. Make sure the headset is turned off.
  2. Turn on the Bluetooth function and Bluetooth visibility in your phone (This makes the phone visible to other Bluetooth devices).
  3. Place the phone within 20 cm (8 inches) from the headset.
  4. Press and hold down the call handling key on the headset until it beeps, shows a steady green light and then flashes red and green alternately. If the indicator light only flashes red or green, simultaneously press and hold down both volume keys until the headset beeps and flashes red and green alternately.
  5. If your phone supports auto pairing, press "Yes" when you are asked to add the headset to the phone. If not, check your phone User Guide on how to pair the Bluetooth device. If required, the headset passcode is 0000.
  6. The headset beeps and flashes green when successfully paired.
Posted on Jan 29, 2009
Pair my Sony Ericsson bluetooth HBH-PV703 with Pantech Impact cell phone
You must put your headset in pairing mode first. Starting with it turned off, press and hold the call handling key until the indicator light flashes alternately in red and blue. Then, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the headset should enter the stand-by mode, and there should be some indications on your phone too.
The pairing process between any two bluetooth enabled devices should be done only once. All subsequent connections should be achieved by turning both your headset and your phone's bluetooth radio on and bringing them both into each other's range. At most, a single press on the headset's call handling key should do.
Hope it works for you.
By the way, if your headset's user guide seems to be missing, feel free to download it from this location.
Please, let me know if you need further informations.
Regards, Carlos
Sep 25, 2010 | Sony Ericsson Genuine Bluetooth Headset...
I cant pair my headset with my new phone htc .lost manual
If your new phone cannot find you hedset the easiest solution is to hold the button volumen when the bluetooth in your phone is activated. After that phone should to find your headset
Jul 18, 2010 | Sony Ericsson Bluetooth-Headset HBH-PV703...
Why doesn't my HBH-PV703 bluetooth not connect with my ps3?
We've just received some new information. Let's see if we can FixYa!
Nov 17, 2009 | Sony Ericsson HBHPV708 708 Bluetooth...
My F006 can not detecting any bluetooth hansfree (Ericcson HBH-PV703)or (Bluedio N76 selld by distributor as an original acsessories from china)
China F006 ...I got this phone from ebay...for 139.00 it has not been nothing but a NITGHTMARE...it keeps shutting off...I can't do anything with it...........CHINA CELL PHONES ****
Sep 16, 2009 | Dual Electronics CECT P168 Cellular Phone
Can't connect with my n97 (or other Nokia phones). The phone doesn't detect the HBH-IV835.
Read the manual of the HBH-IV835.
Page 15 "Prepare the headset".
This solved the problem!
Aug 25, 2009 | Sony Ericsson HBH-IV835 Bluetooth Headset...
How do i connect my HBH-600 bluetooth headset to my phone?
hi thanks for using fixya!
Connecting a Bluetooth headset or hands-free speaker unit to your phone involves setting the headset to “discoverable” mode; check the headset manual for how this is done, as it varies by type and model. You’ll also need to find the headset PIN code in its manual – this is usually 0000 or 1234, but again it varies.
Go to Bluetooth menu – from the main menu highlight Settings (Figure 1), click Select, and scroll right to highlight the Connectivity tab. Highlight Bluetooth (Figure 2), click Select and then highlight Handsfree (Figure 3) and click Select.
When prompted to ‘Add a handsfree device’, choose Yes (Figure 4), and your phone will look for all discoverable hands-free units (Figire 5). Select the one that you want from the list that appears and enter the hands-free unit’s PIN code when prompted. The pairing will now be complete.
Once paired, you’ll find the headset listed under the My devices menu in the Bluetooth settings area, from where you can connect and disconnect it.
Hope it will help you. If you need further assistance, let me know!
Regards!
Apr 30, 2009 | Sony Ericsson Akono HBH-600 Consumer...
Sony blue tooth hbh-pv703
you need to press and hold the buton until the light stays on to get into pairing mode, when on, go to your phones bluetooth settings, search for bluetooth devices, then when it finds the headset a code will be requested, this is 0000, enter this and the light will flash intermittently telling you its paired with your phone.
Sep 03, 2008 | Sony Ericsson HBH-PV702 Wireless Headset
333 people viewed this question
 Grubhead
Grubhead
