Question about GE Profile PSS29NHS Side by Side Refrigerator
Only receiving crushed ice
I have a few problems, 1- I caan no longer get cubed ice from the door, only crushed, a couple of days a ago I noticed the floor is wet. so the refrgertor is leaking from somewhere, I assume it's the icemaker, it has slowed down in making ice. I had to go and purchase a bag of ice yesterday. Can you help me with the problems that have. I just moved in the home and don't want to purchase a new refigerator at this time if i don't have to.
  • 65 Answers
SOURCE: Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Posted on Jan 27, 2009
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
SOURCE: Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
rylee_smith
  • 8619 Answers
SOURCE: can not get cubes from the front, just crushed ice and water?
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 23, 2009
MNTECH
  • 1543 Answers
SOURCE: ice maker only crushes/does not cube
Remove the ice bin. Look at the back wall, behind where the bin was. You should see a rectangular hole, about 1.5 x 1 inches near the bottom of where the ice bin was. There should be a white plastic part inside the hole. This plastic part should be able to be lifted up with your finger, and drop down again when you release it. If is does not move, it may be frozen, or the electrical solenoid connected to it may have melted. If the part moves freely, just replace the ice bucket and try to dispense cubes again. (the metal arm sticking out the back of the ice bucket might have gotten on the wrong side of the white plastic part in back)
Samsung RFG298AARS is cylcing between crushed and cubed ice several times a minute and chimes each time it does that!
\it could be that the switch for the ice selection is stuck or just went bad and shorted out. You can check with appliancepros.com to get price of switch and trouble shoot the problem
Apr 07, 2014 | Samsung RFG298HDRS 29 cu. ft. French Door...
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
My samsung rfg297aa dispenses crushed ice whether its set on crushed or cubed. why will it no longer dispense cubes?
This answer probably comes too late for you (you posted the question 9 months ago), but I want to record it here for posterity, since I had the same problem, and searching on Google for it brought up your question.
Anyway, I managed to fix this very problem by removing an ice cube that was wedged in the ice dispensing mechanism. The way this unit works is that it pushes the ice cubes through the mechanism, which always rotates the "crushing blades". When you select "cubed" ice, a lever opens up the exit chute wider, which causes the blades to simply push out the ice cubes as they pass through. When you select "crushed" ice, the lever closes the "exit" for the ice cubes to be narrower, so that the ice cubes can't be pushed through by the blades, and instead get crushed by them. I had an ice cube wedged in there that had the same effect of closing the exit to be narrower. Removing it fixed the problem.
You might want to collect all the ice cubes that have accumulated in the ice bucket in a container, empty the ice bucket, clean out the mechanism from any obstructions, and then put the ice cubes back into the ice bucket.
Feb 16, 2011 | Samsung RFG297AA (285 cu ft) Bottom...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Freezer wont dispense cubes, only crushed ice
I had this same problem for a few days. I opened the door & played with the ice dispenser hole and it ended up working again
Dec 19, 2008 | Frigidaire FSC23F7D Side by Side...
MZD2666KES will no longer crush ice. The dispenser light is on however it dispenses cubes only.
Did you pull the icemaker out and then have the problem?
If so, select 'Crush' and Slide the ice maker out and slide back in. You will notice a rod on the end (bottom left of the unit) slides into a little cubicle that moves up and down to provide either crushed or cubed.
May 21, 2008 | Maytag Refrigerators
Side by Side Refrigerator Always dispenses crushed ice regardless of setting
I know it will be a pain but take it apart again and lube the metal shaft in the solenoid and the plastic slide with petrolium jelly, that should keep it from freezing up. It's what we do...
Dec 25, 2006 | GE GSH25JSRSS Stainless Steel Side by Side...
GE Profile PSS29NHS Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
