Question about Toys
Fast lane rc helicopter top rotor won't spin
The top rotor won't spin, even after the set screw has been tightened
micromend
  • 748 Answers
SOURCE: my rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
Posted on May 13, 2010
  • 35 Answers
SOURCE: is there anywhere to order replacement parts for
Hi odonnellsara,
What you need to do is to use your email account to contact Support@iwave.com and give them a description of your problem.
They are probably going to have you go to http://www.iwaveaudio.com/support.asp and fill out an RMA request which is just your address and the like.
I went through this and my RMA request was denied because I did not have a reciept to attach to the form as I had recieved the Copter as a gift.
I sent them another email saying that I just wanted a parts manual to order from but have not heard back from them.
Have Heart! it is my thought that if you do have a reciept, they may give you an address to send the machine to for repair or possibly send you a replacement. IMO, the helicopter is a very good "transition" or "Stepping stone". My background was with the small indoor models so I was prepared to address issues such as trim adjustment and had good luck with my copter right out of the box. This model is much faster and more sensitive and will be a great trainer for my first three or four channel model.
Posted on Jan 18, 2011
SOURCE: hi i have a S031
i have the same problem and the button is in the off postion
Posted on Apr 02, 2011
Don3542
SOURCE: My helicopter won't take off,
This issue is the "Drive Gear Unit" It is the small gear just above the motors which is attached to the very large gear. You will have seen several posts indicating that sometimes this gear shifts and does not engage the larger gear. In my case I looked and say that it was indeed trying to engage the larger gear, however the gear is stripped (the teeth are nearly gone). The sound that you are hearing is the sound of the gear slipping against the Bigger gear. I have a UJ365 which is a newer model. To my disappointment I cannot find a "Drive Gear Unit" anywhere on line. The copter will not function without it. This issue is that it takes the lift of both rotors to lift the copter into the air. There are two motors (one for each rotor) and each motor has one of these drive gear units. Each of these attach to the larger gears which turn the rotors. The rotors each turn in the opposite direction. This is what keeps the copter from continually turning in one direction. When one of the "main Gear Units" becomes damaged it seems to have three noticeable effects. (1) There is a noise that is the gear grinding against the bigger gear. (2) Because many of the teeth are stripped the drive gear engages the bigger bear only some of the time, this causes the rotor to turn slower and in-turn causes there not to be enough lift from the rotors to lift the copter. And finally (3), someone noted that copter wants to spin in one direction. Understanding the above, you can now understand that if one of the rotors is not reaching its full potential to turn, it is also not reaching its full potential to counter act the other fully functioning rotor. Thus the fully functioning rotor is forcing the copter to spin in its direction and the malfunctioning rotor is not spinning fast enough to stop the spin.
So this is the answer to your questions, hopefully on the older models there will be parts available for you to replace it. The copter cannot work until the part is replaced.
Posted on Jul 11, 2011
SOURCE: I recently purchased a Fast
I have the same one, i have searched long and hard for parts for this without much sucsess, allthough i have found this on ebay, the blades and rotor look very simular
http://www.ebay.co.uk/itm/Metal-3-Ch-RC-Mini-Helicopter-Main-Tail-Blade-SET-G-/140315300745
Its slightly diffrent but i think the blades should fit the hawk 4. In the mean time i shall keep looking.
Posted on Sep 21, 2011
Why won't the top rotor of my phantom rc helicopter spin?
must be not tight enough when attached to the metal shaft connected to motor, metal shaft may be spinning but not the top rotor, find a way to tighten it down on the metal shaft.
Nov 11, 2013 | Toys
Lower rotor does not turn
There should be a very small screw to tighten it up. Be careful, these things seem to be MADE to break!
Dec 31, 2012 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Bought Nano Hercules RC Helicopter. Flew it once and now lower rotor won't turn. Tried to call World Tech
I, too, have the Nano RC heli. Mine spins and spins faster if I try and take off.
Yours is a relatively easy fix. There are SCREWS under the rotor blades on the bottom. Tighten those.
Dec 28, 2012 | Toys
I recently purchased a Fast Lane Hawk 4 rc helicopter. After a few small "crashes", it shakes and doesnt fly well. Does the top rotor need replacing, and if so, can I get the parts for it?
Sep 20, 2011 | Toys
Top blade wont spin help.
the top blade should not spin unless the main rotors are turning as this gives the copter forward and sideways movment it should be secured with a small grub screw to the main shaft
hope this helps
Aug 08, 2011 | RC Remote Control Rc Helicopter
Crashed hard and now the bottom rotor is not spinning as fast as the other two. What should I do?
loosen the body screws. lift the right side front so you can see the engine gears, The little gear has slipped on the shaft and is not making contact with the big gear (white plastic gears). Slide the little gear down the shaft so it meshes with the bigger gear. Close the body back up (don't tighten screws yet). Turn the Heli on and make sure all is well (while holding the body closed). Tighten screws...Enjoy...
Dec 25, 2010 | Team International Hawk Talon V3 RC Indoor...
Yiboo AH-64 3D RC Mini Apache Helicopter, out of the box, charges, but will not do anything, channel C
Mine worked good for 3 days then died..Top blades wont spin.. It worked really well. The guy at (as seen on TV) shop that sold it to me actually seemed to tell me "Do not buy this!" But I bought it anyway at his word that I cannot bring it back no matter what after 24 hours..spent 90 bucks on this junk and there is NO SOLUTION
Oct 02, 2009 | RC Toys
Toys Logo
80 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
