Coleman Furnace DGAA077BDTB fuse blows when hot is connected
I have the integrated controller board wired like the diagram. The line voltage (L1) to the switch then to L1 block on the board. The neutral lands on the bottom of the neutral bus. but when I go to connect power the 3A fuse blows.
    Genius:
  • 1,033 Answers
This can be caused be either a short in the wiring, loose connection on the board,or a low voltage connection not secure on the board. Check all connections to make sure they are tight and secure. Let me know what you find.
Posted on Jan 10, 2013
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Posted on May 30, 2008
  • 69 Answers
SOURCE: Furnace start buts shuts off
It sounds like you have an obstruction in the exhaust vent. Thats why when you bybass the pressure switch it runs ok. Steve
Posted on Dec 21, 2008
SOURCE: Line voltage Tstat installation Dayton D-F79 elctric shop heater
If I understand your post correctly....You state that you are hooking up a 240v heater and towards the end you speak of removing jumpers...W2 terminals..ect. It sounds to me your trying to us a 24v low voltage thermostat instead of a Line voltage thermostat.That's what I'd take a look at.
Posted on Jan 21, 2009
  • 29 Answers
SOURCE: Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Posted on Jun 21, 2009
SOURCE: Furnace runs on utility power but not on back up generator power
Using the Hz meter you can adjust the governor throttle screw to raise or lower the engine speed
to get an optimum 60-62 Hz setting. You may want to load your generator with the most
common load you will be using and then adjust the screw to give you an adjustment within the
60-62 Hz range. If you set it too high, then it means you are running the engine faster than
need be and will add to premature or serious engine damage to the internal parts. It is
mechanically governed to maintain the proper engine speed once it has the standard setting in
place. Do not attempt to adjust this governor throttle adjustment screw without the proper tools
available. You can not do it by ear! If you do not have a Hz meter or tachometer available, then
you can use a conventional electric clock with a sweep hand for seconds. If you plug the clock
into the generator, a proper engine speed would make the clock do a minute in exactly 60
seconds against any other timing device. If the clock takes longer to do a timed minute, then the
engine speed is too slow and you need to raise the engine speed; turn the governor throttle
screw clockwise. On the other hand, if your clock does a minute in less than a normal clock
minute, then you need to lower the engine speed, turn the governor throttle screw counter
clockwise. Now you should have a good setting for your generators frequency setting. It is best
to do a frequency setting before doing any voltage adjustment.
I did this today and my Goodman fired right up after two days of frustration!
Posted on Dec 07, 2009
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Coleman furnace dgaa077bdta
The control fuses keep blowing tells me one or more of the control that operate the control on 24 volts is malfuctioning. Most controls operate at about 5 watts and on a clamp on amp meter normally pull about 0.2 amp (p = current x voltage, 5 watts = 0.2 amps x 25 volts) I install 75 watt 24 volt transformer with a resettable overload to save on fuses. I reset the transformer and quickly go to the controls and determine the amp draw. When I find the one >0.2 amps I found the problem. The things to check is the emergency heat sequencer, fan control sequencer, reversing valve for heat pumps, main contactor on the condensing unit and any other 24 volt control loads. I have had to replace the themostat wire because the increase current for the thermostat wire can cause the entire length of wire to form a long heater and cause insulation degradationa and cause the thermostat wire to short out and blow the fuses.
Hope this helps
Aug 30, 2014 | Coleman Mobile Modular Home Gas Furnace...
I replaced my fan control board because blower would not work but now heat is not coming on
Double check your wiring on the new board, you may need to jump your thermostat line to the "R" terminal on the ignition controller. There are two sides on the ignition controller. One is for line voltage (115-120) and the other is for low voltage (24). Be sure of these connections and it should be good to go.
Feb 14, 2013 | whiterodgers White Rodgers 50A55-843...
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
Neither my AC or furnace will run I just replaced the thermostat but they still do not work. I there any other place the two are connected as they both quit at the same time.
Either the transformer of the control board fuse in the furnace went...usually this is because of a short on the low voltage wiring...but could be a bad component... both can be very tough to track down... low primary voltage can also burn out either one of them...
heatman101
Sep 27, 2011 | Coleman Mach III Air Conditioner
Hi i have a rheem super quiet 80 attic unit.. the heat is not working.. the unit will not power up and circuit board is not lit
Hello, if the furnace does not work at all the main thing to check is your line supply voltage. low voltage and fuses. Make sure the circuit breaker is not tripped and verify that you are getting 120 volts to the integrated control board at the L1 nd neutral terminal at the board, if not most likely the breaker is tripped, secondly make sure that the fuse on the unit is good, usually it will be on the integrated control board if it is a newer furnace or on the side of the furnace at the switch box if it is a older furnace, make sure the fuse reads 0 ohms with your meter. Lastly check the transformer, check Resistance on both sides of the transformer and you should get resistance, if not replace transformer, let me know if you have any further questions I will be glad to assist you.
Feb 05, 2011 | Heating & Cooling
I need help connecting black wire ( hot line wire) from safty switch. It fell off and I can't figuar out where to put it back on the control board.
On the reverse side of the door panel is a wiring diagram. It is in very small print so get a magnifying glass. Find "L1" on the Schematic side of the wiring diagram (the picture more like a road map). Follow the wire thru the door switch and then down to the control board. It will connect to a terminal possibly marked D1, T1, L1 or what ever the diagram says. Please make sure power is off to the heater prior to doing this.
Nov 06, 2009 | Goodman GMS80903BNA Heater
Need wiring diagram for a carrier 383kav11048075? im replacing the icm281 control module. gas furnace
There should be a wiring diagram on the panel of the furnace. In the box of the icm 281 is step by step instructions.
Maybe this will help
Take notes on your low voltage wires from the thermostat and condenser. W Y R C G. Write down what color wires go to above terminals.
On your high voltage wiring,
Take the black wire from the transformer and put it on PR-1.
Take the white wire from the transformer and put it on PR-2
Take the black power wire from the panel interlock switch and connect it to L1
Take the white neutral power wire and connect it to L2
Take the black fan motor wire and connect it to HI
Take the red fan motor wire and connect it to LO
Take the white fan motor wire and connect it to COM
Then reconnect your low voltage terminal wires to W Y R C G.
Thats it.
May 03, 2009 | Carrier Heating & Cooling
No problem-just want info
This unit is electronic ignition
Feb 26, 2009 | Tools & Hardware - Others
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
