Question about RCA Thomsom Dhg535-2 Residential Voip Cable Modem Docsis 2.0 With Cables Used
How do i reset a rca/thompson dhg535-2 cable modem?
Trying to connect macbook pro directly to modem. Modem had been previously connected to a PC
Yehudama
  • 3 Answers
SOURCE: My connection fall
Please describe the leds in front of the modem which led lights or blinking ?
Posted on Aug 23, 2007
dbarchitect
  • 150 Answers
SOURCE: RCA DCM425 modem ethernet connection won't work
In short, you have to either
  1. renew your ip on Computer 1, or
  2. hard-reboot your cable modem and then reboot or renew your ip on Computer 1.
Details below.
The modem is communicating with the servers at your ISP (Internet Service Provider) to give your computers an IP address. The ISP may have your modem set up to be issued only one IP address. Thus using both USB and Ethernet could be restricted by your ISP.
The IP address is most likely a dynamic IP that expires after a few days or weeks, unless you bought a business account that has a static IP (which is used for hosting permanent websites).
When a computer is not communicating with a Cable Modem or you shift between the connections on the modem, it may be necessary to re-establish configurations. The following can be steps to reset all components to re-establish configurations:
  1. Do a hard-reset on the modem. On the back of the modem is a reset pinhole. If you press the button quickly, this can soft-reset the modem, just restarting the modem. If you press the button and hold it for more than 10 seconds, this can hard-reset the modem, thus resetting and re-establishing configuration with the ISP servers.
  2. Restart the computer or at the command prompt (Start | Run | Cmd | Enter) issue two commands ... "ipconfig /release" and then "ipconfig /renew". This will release your IP and request a new one from your ISP.
These steps are required when adjustments occur especially when shifting between connections on the back of the modem.
Posted on Nov 26, 2007
  • 4 Answers
SOURCE: DCM 425 Modem
check your wap, or wep keys. these can be checked on your wireless connection options or the wireless utily setup
Posted on May 02, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RCA Cable Modem DCM315R Problem:
Who is you service provider and do you have a router connected to it as well?
Posted on Oct 20, 2008
frcs68
  • 1605 Answers
SOURCE: Reseting "Bridge mode" in RCA DCM 305R cabel modem
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
Posted on Dec 30, 2008
Cannot restore factory settings
You need to consult a qualified Technician.
Apr 17, 2017 | NetGear WGR614 Router
I have a Belkin Wireless G Plus Router connected via Ethernet cable to a Scientific Atlanta cable modem supplied by Virgin. I can't currently get any signal from the Belkin to my MacBook Pro (I've got it...
Make sure the IP of the Router and the IP of the MAC is in the same scope.
E.G. Router: 192.168.1.1 Subnet 255.255.255.0
Mac: 192.168.1.5 subnet 255.255.255.0
Typically the router acts as DHCP-server and distributing ip-adresses automatically, when a computer is connected. But the the IP can also be set manually.
Mar 13, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Have broadband connection but forgot wifi security phrase on rca thompson modem
unit should have its code printed on sticker on side of it.
or you can use a wired connection to read security settings if you know the modems IP address. RCA website should have this address if you dont see it on the ID sticker.
Oct 12, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
My Thompson RCADCM425 will not connect to my new HP computer with 64 bit Windows 7 installed
IS THOMPSON HARDWARE COMPATIBLE WITH WIN 7 64BIT? IF SO TRY REINSTALLING THE DISC THAT CAME WITH THE HARDWARE.
Aug 07, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Thomson rca cable modem dhg 535-2
Here is the usb driver it is directly from the disc for the Thompson 535-2 cable/voice modem. I know this is not on the internet anywhere so please share.
http://rapidshare.com/files/303844631/RCAThompson535usbdriver.rar.html
Jun 24, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Apple AirPort cannot get IP address from cable modem using DHCP
go to applications,utilities and go to airport set up and check the settings, it could need the DHCP setting up or the old settings deleted
May 24, 2009 | Apple AirPort Extreme Router
Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
May 19, 2009 | Zoom X6 Adsl Modem/router Rohs...
RCA Thomsom Dhg535-2 Residential Voip Cable Modem Docsis 2.0 With Cables Used Logo
90 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
