Question about LG WM Washing Machines
Lg WM2233HS leaking water
Water leaking from under machine
IB4G2008
  • 3587 Answers
SOURCE: Need Instruction Manual for LG Tromm WM2233HS Washer Machine
and it's all yours now..click here
Posted on Mar 02, 2008
jtate9
  • 68 Answers
SOURCE: water leaking from under the front of the washing machine
The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Posted on Jul 29, 2008
SOURCE: LG WM2355C water leaking under machine after washing finished.
I had this same problem and it was not the supply connections or filters! Under the machine is a rubber bellows. The bellows had sprung a leak. The part was about $10 from Sears and I repaired it in about 30 minutes. The machine is heavy so be careful. Get a friend to make sure the machine won't rock or tip when you're making the repair.
Posted on Sep 16, 2009
  • 327 Answers
SOURCE: water leaks under machine when filling
Hello, if your washer leaks only when filling then you have to check these:
Air-gap device- The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
THE TUBE - There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak
inlet spout- Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tube. If the spout cracks or breaks free of it's mounting, it can cause a leak.
Thanks
Posted on Jun 04, 2010
  • 106 Answers
SOURCE: my lg washing machine leaks
Actually, it's most likely not a clog, I've seen this rare problem before, but it sounds like your machine could be missing what LG calls a "mushroom valve". This is just a piece of plastic with a mushroom shaped top, and it slips down in the top of the machine, and it suppose to allow air to pass through, but block any water from coming through. There is a large hose called a bellow that surrounds this, and connects to the tub with a screw style clamp, and then connects the same way to the back of the cabinet.
This isn't to hard to check, if you have a Phillips screwdriver handy. You can remove the top of the washing machine with two screws, and the top cover slides backward, and then you pull it up to pop it off.
Once you have the top of the cover off, you can see the large black hose (bellow) and you'll notice the screw clamp in place, you can easily loosen the clamp up, and pop one end of the bellow off, that attaches to the tub, and see if you have the mushroom valve in place.
Posted on Mar 12, 2011
WATER leaking under LG Tromm
Any water leak presents the danger of ELECTROCUTION with machines operating at mains voltage.
Never, but never use a leaking machine until the problem is fully remedied. Call a qualified Technician and get peace of mind for but a few dollars.
Poppa
http://www.cdbaby.com/cd/poppamadison
Oct 13, 2011 | LG WM2277H Front Load Washer
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
Leaking from under washer
your rinse hose has a hole in it or has come loose from the pump
Sep 21, 2009 | LG WM0642H Front Load
HI, you will want to Inspect the water supply connections. this is a good spot to check first. there may be a loose connection here, causing the leakage. Next, Inspect the drain hose. Check to make sure that it is tightly connected to the drain pump. replace if needed. Last. Inspect outer tub/basket for cracks or corrosion.
You will find the issue in one or all of the above stated check points.
Jul 23, 2009 | LG WM2277H Front Load Washer
LG TROMM WM2233HS won't start
Obviously I switched the breaker wrong. We switched the breaker again and it worked.
Apr 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm WM0642HW washer leaking water!
I have the same problem - just a small amount of water leaking out from under the machine. I removed the top cover and found one of the water lines rubs on the vent tube and has wore completely through. Should be an easy fix, as the line runs from the #2 spigot on the water inlet to the detergent box - both connections are right on top.
Nov 02, 2008 | Washing Machines
Lg washing machine 1289 fhd
The operating pressure is 4.5 - 116 psi.
Where is the leak?
Feb 08, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
50 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
